Remote start and heating the interior
Discussion in '3rd Gen Tundras (2022+)' started by kamaaina1, Dec 3, 2024.
  1. Dec 5, 2024 at 11:59 AM
    Rockpig
    Rockpig You did what?
    08 Limited
    So I ran the test again...
    Seat heater on high (3leds). Also turned on the passenger front seat to the same.
    Steering wheel heater on.
    Blower set to high, temp high, defrost/foot setting, recirculate.
    Lastly pushed the mirror defrost also for shits and giggles.
    Remote started the truck, let time run out, minute later restarted a second time, let that expire and checked the truck.
    Seats were mildly warm, nothing on the steering wheel, forgot to check the mirror. Warm in the cab. So my seat heaters do heat without anyone in them but only ever so slightly. For running the truck for 20 minutes I'd think that they would be blazing hot. In order to make sure my mind wasn't playing tricks on me I had to touch the back seats then the front to actually tell they were warmer, which they were.
    I'm wondering if mine aren't heating up so well because my truck is a hybrid. Perhaps the systems shut down when the battery kicks in and the engine shuts off to conserve battery. I'm sure the seat heaters draw a good amount of power.
  2. Dec 5, 2024 at 1:00 PM
    Maine TRD PRO
    Maine TRD PRO New Member
    2023 Ice Cap Tundra TRD PRO(Rioja Red interior)
    mine is a hybrid
  3. Dec 5, 2024 at 7:09 PM
    Lbc1794
    Lbc1794 New Member
    My 2013 ford f150 lariat that i traded in for my '24 1794 had a setting of items to turn on when remote started. I miss that
    And no subscriptions for remote start and navigation
    You can warm up your seats, warm the cabin, defrosters
    In the winters, you got into a toasty car or a frosty car in the summer
    Raven67 likes this.
  4. Dec 6, 2024 at 6:57 AM
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Bridgestone Dueller Ascent tires
    Ok, so I tested this on mine this morning - '22 Canadian, LTD TRD OR, not hybrid.
    Parked the truck last night, settings when I turned it off.
    Seat Heater on High (3 bars) and steering wheel heater on. HVAC on manual, set to 20C windshield & foot setting and rear defroster turned on.
    A few Cm of snow overnight & morning temp at -6C - Mirrors left in the folded out position.
    I started with phone app this am, and got to the truck about 6-7 mins later. Looked in window & lights were on for the seat & steering wheel heater. Rear window defrost light was off.
    Opened & checked - seat cold, snow fell in on it a bit & no melting at all - felt with back of hand and felt cold. Steering wheel also felt cold. Mirrors appeared to have been defrosting, so maybe it comes on based on outside temp when remote started? When i started it after opening door, turned Rear defroster on and started cleaning window, the windshield was thawing under the snow load. 5-7 mins of snow clearing & got in the truck - seat was hot, steering wheel was hot.
    So it seems for mine, the seat & steering only work on actual start & not on remote start even though the lights are on. I need a better check on the rear defrost, but the light is off on remote start so ill need to get a frosty mirror morning and try and watch to see if any melting is happening.
  5. Dec 6, 2024 at 8:03 AM
    2wheelsforfun
    2wheelsforfun New Member
    Foothills AB Canada
    Kia's response to why there seat heaters don't come on with remote start was the elements burn out without an occupant. Absolute BS and doesn't explain why some trucks are heating properly and some not. I guess people need to start checking their software versions?
  6. Dec 7, 2024 at 2:48 AM
    Lorris910
    Lorris910 New Member
    2022 BlackTunda 1974 Edition
    I have tried leaving setting in both Auto and Manual and the truck is still cold every time. I will try leaving it in window/foot mode with the fan on high. Its just ridiculous you would have to sequence it like you're restarting the module in Apollo 13 to get it to work right.
  7. Dec 7, 2024 at 6:19 AM
    2wheelsforfun
    Foothills AB Canada
    It's not working. And good luck with a dealer, you have to leave it with us over night so we can test it cold in the morning...
  8. Dec 13, 2024 at 6:02 PM
    Gonefishingdave
    Gonefishingdave New Member
    Dave
    Central New York
    2024 MGM Tundra TRD OR Limited
    Bakflip cover, AVS vent visors
    MTP, I did same setup as you in my Limited OR.
    Made sure climate control not in Auto.
    Next morning, I remote started from the phone and let run till it shut itself off (about 10 minutes).
    Steering wheel and seat were ice cold.
    Maybe they changed something in 2024 model year?
    Or maybe a hybrid vs non-hybrid thing?
    Tania Hugs likes this.
  9. Dec 13, 2024 at 6:41 PM
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    I use an electric box heater sitting on the console & the electric cord goes out the back seat door to an extension cord. I have an outdoor timer that starts the box heater about an hour or 2 (depends on the temperature) before I get in the truck. It takes me approximately 25 seconds to unplug the cord, open the back door, toss the cord inside and when I hop in the drivers seat, I start up the truck & move the box heater to the back seat area. Saves on gas & my truck is nice & toasty when I head off to work. It also melts the snow off the windshield. I just drive the first hundred yards at a slow speed the get everything in the engine up & running.
    22whatwedo and Raven67 like this.
  10. Dec 13, 2024 at 7:00 PM
    obgod3
    obgod3 New Member
    NC
    2023 Tundra Limited
    I leave the system on auto, but set the heat to a temp I wish, turn on the seat heater and steering wheel heater and everything is warm after I remote start and get to the truck 5-10 minutes later.
  11. Dec 20, 2024 at 7:13 AM
    2wheelsforfun
    Foothills AB Canada
    Question: How long does your truck take to respond to the remote start app commands? My wife's Kia Telluride takes about 20-30 seconds to respond to the door lock command (at home on our acreage so doors aren't normally locked), then it again takes 15-30 seconds to respond to the actual start command.
    I know, first world problem, but inconvenient enough that I don't use it that often, plus the shutting off after 10 minutes is again very frustrating. These randomly assigned values don't make any sense.
    If the Tundra behaves similarly then I would look for an aftermarket remote start, but will these even work with these new "connected" cars.?
  12. Dec 20, 2024 at 7:21 AM
    Breathing Borla
    Northern Illinois
    it depends on the cell signal in the area you are in on both ends.
    around Chicagoland its fast, but we have ultra cap 5G everywhere. When I go up fishing in northern MN, not so much but it does work
    so nobody is going to be able to tell, but take a test drive from the dealer and have them try it where you will be using it
  13. Dec 20, 2024 at 8:08 AM
    Maine TRD PRO
    mine probably takes 10ish seconds to fully go through and notify me the truck has started. I only have to hold it down for like 2 seconds and then the progress bar auto loads the rest of the way on its own. Door lock is probably 5 seconds.
  14. Dec 20, 2024 at 2:04 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    This is my experience too. In fact, I actually drove 20 minutes with the driver and passenger seat heater on. No one was sitting in the passenger seat. My seat was nice and toasty, and the passenger seat was totally COLD!
  15. Dec 20, 2024 at 7:16 PM
    Ero2
    Ero2 New Member
    This is so weird to me that it's so complicated...no vehicle I've ever owned have I even had to think about this. If it's X ambient temp, it cools, if it's X ambient temp it heats AND turns on both seat heaters when remote starting. GMC, Ford, VW, etc. Making me question trying to pick up a 25 tomorrow, lol.
    Tundraman479 likes this.
  16. Dec 21, 2024 at 5:02 AM
    Hella Krusty
    Hella Krusty New Member
    Probably a country thing cause in CANADA your ass has to be in the seat. Same as the stupid tow mirrors platinum and above
  17. Dec 21, 2024 at 5:04 AM
    Hella Krusty
    The shut off thing is for carbon monoxide. If you accidentally start it in your garage you don’t off the family.
    VCheng likes this.
  18. Dec 21, 2024 at 5:53 AM
    2wheelsforfun
    Foothills AB Canada
    Wow! That's right up there with the back seat reminders. The dumbing down of society is complete.
    VCheng and TundraDan723 like this.
  19. Dec 22, 2024 at 4:23 AM
    msubullyfan
    msubullyfan New Member
    Robert
    2024 Tundra i-FORCE MAX 1794 Edition
    It’s more nuanced than you think. I know someone that had this happen. His fob had a press-and-hold-to-start key fob and something was placed on top of his keys. His carbon monoxide alarm went off and he went into the garage and found his vehicle running.
    it’s actually being reported a lot more now:
    https://www.wbrc.com/2019/11/06/remote-start-vehicles-present-carbon-monoxide-danger/
    The family next door to me in 1986 died from CO poisoning when the flue to their water heater got blocked. CO is no joke.
    New tech introduces new risks. Companies learn and adapt. Chrysler had people being run over when exiting their vehicles because their dial-type transmission shifter wouldn’t provide enough indication if it didn’t go all the way into Park. They changed the design.
    raylo likes this.
  20. Dec 22, 2024 at 5:34 AM
    #50
    2wheelsforfun
    Foothills AB Canada
    I get that and not trying to diminish if anyone was hurt and yes I guess it's possible for a remote to be accidentally pressed. Don't most remotes need a multiple press? And seriously, it's sad that 28 people have died, but in 19 years. So, because 1.47 people have died every year, the millions of us who have lived our lives with a little common sense, and functioning CO detectors! have to put up with essentially a useless feature now due to that very small number of fatalities.
    It's regularly -30C (-22F) for months at a time. Running a car for 10 minutes doesn't accomplish much. Or in the summer it can get up to 40C (100F). We have to leave our dogs in the car occasionally so leave the car running with the air conditioning on, how long do you think the dogs are going to survive in 100 degrees with no air conditioning? And yes we normally start the car manually and make sure the air is running and lock the doors with a second fob (Tundra related content) before leaving the dogs but have on occasion thought we would only be minutes somewhere but ended up taking longer so would then remote start the car.
    All this to say, I stand by my first post.
  21. Dec 23, 2024 at 10:28 AM
    #51
    Tania Hugs
    Tania Hugs New Member
    2024 Toyota Tundra Crewmax Hybrid
    I am wondering if the vast differences in this thread account for hybrid vs non hybrid? We have the hybrid and cannot figure out how to heat the truck beforehand. Heat is on, seats are in, steering wheel is on. After a short period of time the engine shuts off and so then what the heck is the point if a remote starter at all in the hybrid? I feel like we have to be missing something.
  22. Dec 23, 2024 at 10:30 AM
    #52
    Breathing Borla
    Northern Illinois
    if the hybrid model doesnt run the ICE motor at start up, then your not going to build heat, its that simple.
    otherwise , seems odd
    my truck, seats, wheel get warm
    Matt2015Tundra and Maine TRD PRO like this.
  23. Dec 23, 2024 at 7:13 PM
    #53
    onehundredLL
    onehundredLL New Member
    2025 Tundra Limited
    I wouldn't be so sure about that actually. I don't know anything about the Tundra hybrid but my wife has a BMW hybrid and it kicks on environmental (heat or A/C depending on what's required) under a remote "start" command and does not start the ICE.
    Hella Krusty likes this.
  24. Dec 24, 2024 at 1:58 AM
    #54
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    You ever watch Idiocracy? It has been accelerated.
    22whatwedo and Hoody like this.
  25. Dec 24, 2024 at 5:33 AM
    #55
    Hoody
    Hoody Member
    Kommiefornia
    '23 Platinum 6.5 bed
    Idiocracy is probably the best predictive programming out there. Still have hope for Starbucks.
    But back on topic, all my heated stuff works fine with remote start. Maybe it's just too cold where some of y'all live and it needs more time like 20 min or more where an aftermarket starter might be worth it.
  26. Dec 24, 2024 at 8:05 AM
    #56
    Hella Krusty
    Just build a heated garage, and BOOM all these problems go away
    TundraDan723 and Raven67 like this.
  27. Dec 24, 2024 at 8:23 AM
    #57
    Breathing Borla
    Northern Illinois
    heated garages rule , love mine
  28. Dec 24, 2024 at 4:26 PM
    #58
    Hella Krusty
    I had a 2010 F350 that had an OEM electric heater. Blew instant warm air when started
  29. Dec 24, 2024 at 4:30 PM
    #59
    2wheelsforfun
    Foothills AB Canada
    That's a great idea, wonder why they don't do that.
    Hella Krusty[QUOTED] likes this.
  30. Dec 25, 2024 at 1:36 AM
    #60
    Nio9
    Nio9 New Member
    It seems as yet another lack of engineering on Toyos part- hmmmmmmm- lets have an app that you must pay $ for to remotely start your truck, it's doesn't provide climate control, it doesn't warm the freezing seats, the truck turns off when you touch the door handle...... So why does Toyo even have remote start? I think the concept there is aS dumb as a rock. Or the consumer who pays these obnoxious morons for crappy, unthoughtful engineering. My buddy's Ram you remote start, jump in & take off, not my Tundra, remote start, touch door handle yup- truck shuts off!
