Anyone have success with compustar remote start and security system?
Discussion in '3rd Gen Tundras (2022+)' started by Kona_boy, Dec 5, 2024.
  1. Dec 5, 2024 at 1:45 PM
    Kona_boy
    Kona_boy [OP] New Member
    Jeff
    Kent, WA
    2023 white tundra 1794 TRD
    Went to installer and they said alarm is compatible but won’t have unlock/disarm function. I would need the oem remote to open doors and compustar remote to disarm. Dealer update firmware diagram for tundra confirms this however speaking with compustar they said it will work just fine with oem remote. Searching I’m finding more negatives, anyone have this installed and works as advertised?
  2. Dec 6, 2024 at 10:01 AM
    steveh
    steveh New Member
    '24 Tundra Limited
    Nothing Yet!
    Not sure what the misunderstanding is. It works fine with the OEM remote, so you have to carry two remotes. Is that right? What OEM alarm options are there?
  3. Dec 6, 2024 at 9:33 PM
    Kona_boy
    Jeff
    Kent, WA
    do you have compustar system? The installer said I’d have to use my oem remote to unlock door as usual by pulling handle but unlocking the door won’t disarm the alarm so it would go off once door opened unless I disarm the alarm with compustar alarm…
  4. Dec 7, 2024 at 12:31 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Find another compustar dealer to get a second opinion. It's possible that the installer doesn't want to screw around with making the alarm work with Tundra as it may be pita and just want to sell you easy standalone alarm option.
    If compustar direct says their alarm is compatible with the new Tundra then the installer is probably wrong
    1lowlife likes this.
  5. Dec 7, 2024 at 11:55 AM
    steveh
    steveh New Member
    '24 Tundra Limited
    Nothing Yet!
    "compatible with" does not necessarily mean the compustar system will unlock the doors etc. Can you set the alarm with the doors unlocked?
  6. Dec 7, 2024 at 12:12 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Well, any alarm can be installed onto any vehicle if it's a standalone and does not unlock the doors or interface with the vehicle in any way.
    It's very likely that if compustar says it's compatible, it can indeed unlock doors at the very minimum.
    But idk, just my best guess
  7. Dec 7, 2024 at 2:43 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I concur..
    If a compustar alarm means having 2 remotes then go with a different brand.
    It has been 10 years, but when I had my Compustar remote start/alarm installed it's remote replaced my OEM remote.
    But I only had to use the compustar remote, the OEM remote has been in a file cabinet for 10 years...
  8. Dec 21, 2024 at 11:59 PM
    Kona_boy
    Jeff
    Kent, WA
    Update, spoke with compustar directly and they confirmed oem remote works with security and everything will work as normal.
    Got it installed 12/17 at different installer that said it will be a harder install but that everything will work. First thing installer said when picking it up (which wasn’t mentioned before) was that I am not to use the compustar remote to open the doors as it will deactivate oem remote and I’d have to take it into toyota dealer to get reprogrammed… DroneMobile app doesnt lock/unlock doors only arms/disarms. Annoying bc I take the dogs out and notice my mirrors out so I open doors to lock truck and alarm goes off… tested it with app soon after and sure enough just arms/disarms:/ waiting to hear back from them will update when they do.
    Loved this system on two previous cars so hopefully an easy fix…
  9. Dec 22, 2024 at 12:26 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Wait... So the installer said that everything will work, but what he actually did was install compustar as a standalone alarm system and you have to use Toyota remote to lock unlock and compustar remote to arm disarm?
    Sounds like the installer couldn't figure out how to interface compustar with Tundra...
    I would be pissed as that's the only reason to get compustar as supposedly it will interface with the new Tundra.
    Perhaps try to put both the installer and the compustar support on the phone at the same time to ask wtf! Maybe support will tell him how to program it
    MaineTundy likes this.
