2018 Tundra issue
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Sthiel1005, Nov 26, 2024.
  1. Nov 26, 2024 at 10:40 AM
    Sthiel1005
    Sthiel1005 [OP] New Member
    Hi I have a 2018 Tundra. It's been to 4 different dealerships now , and no one can figure out what's wrong with it. At super low speeds in forward and reverse there is a almost bubbling and creaking noise coming from under the dash. It does it driving straight, but will also do it when I'm just sitting and moving the steering wheel. I've been told suspension is fine, but no one can figure this out. Anyone else have a similar issue? How to fix? Thanks
  2. Nov 26, 2024 at 10:57 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    So under the dash? Is the creaking inside the cab or outside? If they confirmed the suspension is fine, the creaking could possibly be coming from a skid plate(if you have one). I only say this because I recently had this issue with mine but that is because I over torqued the bolts on it. I removed it and re-installed with rubber washers and that fixed my noise.
    MVRCA likes this.
  3. Dec 21, 2024 at 8:13 AM
    MVRCA
    MVRCA New Member
    Las Vegas
    2016 Tundra TRD Pro
    White Knuckle sliders, BDS 3" lift with Fox 2.5's. Method 305 NV with 35" Trail Grapplers.
    This made me crazy for a year until I read about it here. It was my skid plate as well. Ugh. fixed now.
