Aftermarket oil dipstick suggestions?
Discussion in '1st Gen Tundras (2000-2006)' started by BlueGarden, Dec 19, 2024.
  1. Dec 19, 2024 at 2:02 PM
    BlueGarden
    BlueGarden [OP] New Member
    Paducah, KY
    2002 Tundra Limited 4x4 4.7L
    Like alot of others, I have a terrible time reading the oil level on my 2002. Does anyone know a good oil dipstick to buy to replace the OEM sticks? I've found aftermarket ones, but i cant find any that are specific to the 1st gen tundra. I would think that variations in dipstick length would cause a problem.
  2. Dec 19, 2024 at 2:03 PM
    Why not pick one up at a salvage yard?
    JMGmanAZ likes this.
  3. Dec 19, 2024 at 2:09 PM
    Am I crazy or did someone on here find their 1st gen actually had the wrong dipstick, from the factory? Like, dipstick was too short.
  4. Dec 19, 2024 at 2:28 PM
    bfunke
    bfunke Tundra Curmudgeon
    I’ve never had any difficulty reading mine.
    Jack McCarthy likes this.
  5. Dec 19, 2024 at 2:31 PM
    I recall that. I think it was just an anomaly.
  6. Dec 19, 2024 at 3:20 PM
    It’s somewhere in the hand models archives, I’m sure he touched on the subject
  7. Dec 19, 2024 at 3:51 PM
    rcsbguy
    rcsbguy New Member
    Sand with 120 grit horizontally up to the full mark. Insert and remove it quick. You’re welcome.
    robabeatle, des2mtn and FrenchToasty like this.
  8. Dec 19, 2024 at 3:55 PM
    Do you pull it out, clean it off and reinsert? Very much necessary to get a good reading. Once you pull it out again, you’ll see the correct value on one side.
  9. Dec 19, 2024 at 3:56 PM
    This
  10. Dec 19, 2024 at 4:15 PM
    I definitely like the ‘insert and remove it quick’ part. Do that quite repeatedly and I think they put you on a list or something.
  11. Dec 19, 2024 at 4:38 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    R.I.P.
  12. Dec 19, 2024 at 4:52 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    Are you just having trouble seeing where the oil is? Or is it hard to read because it’s stained brown?
  13. Dec 19, 2024 at 5:10 PM
    bfunke
    Although I have to admit, the dipstick in my suburban with its crosshatch pattern and small drilled holes is easier to read.
    BlueGarden[OP], shifty` and des2mtn like this.
  14. Dec 19, 2024 at 5:35 PM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Park it on a flat surface, preferably overnight, and pull it out and read the inboard side, not the backside that drags the curves on the way out. You'll have a nice level on the stick. It takes a bit of time to get a "proper" reading because the oil takes a while to drain back to the pan. I have a bit of an expert opinion on this :muscleflexing: because I've owned the truck since new, 23 years or so, lots of oil changes and checks of the dipstick. BTW, the level never goes down that I can see on the dipstick between 5k oil change intervals.
    Soupbean77 likes this.
  15. Dec 19, 2024 at 6:23 PM
    Too bad GM didn’t make electronic transmissions as stout as their dipsticks. :rofl:
  16. Dec 19, 2024 at 6:35 PM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    I bought a 2000 Tundra new. Mine was the SR5 extra cab with 4.7 V8. Owned that truck for fifteen trouble free years. I forget exactly when, but sometime in the first year of ownership a shipping tube was shipped to me from Toyota USA. It contained a new dipstick with instructions to remove and discard the dipstick currently on the vehicle. I forget the difference between the two, but I do remember it was very minor.
  17. Dec 19, 2024 at 6:37 PM
    Sounds like there’s probably a TSB out there for it on just the 2000 Tundra, maybe?
  18. Dec 19, 2024 at 8:48 PM
    BlueGarden
    Paducah, KY
    It would be just like the one I already have that is hard to read.
  19. Dec 19, 2024 at 8:51 PM
    BlueGarden
    Paducah, KY
    Yes, hard to see where the oil is on a fresh oil change.
  20. Dec 19, 2024 at 8:52 PM
    joseph_womack
    Joe
    Louisiana
    I gotcha, honestly easiest way is just use a flashlight if you’re in a dimly lit area
  21. Dec 19, 2024 at 9:00 PM
    BlueGarden
    Paducah, KY
    Yep, I clean it off and put it back in repeatedly and I just can't see where the oil is. I've tried reading both sides of the stick. Truck is on level ground. I can see that there is oil on the dipstick, I just can't see where the oil stops at its highest point. It needs little cross-hatch marks like other sticks on most other vehicles I guess. I might have to hatch it myself like someone mentioned. I was just hoping that someone had found one that already had that done.
  22. Dec 19, 2024 at 9:01 PM
    rcsbguy
    rcsbguy New Member
    It literally takes 3 seconds and all your problems are fixed. 60 grit, 120, 240…any will work.
