Negative battery terminal upgrade, or just better regular check?
Discussion in '2.5 Gen Tundras (2014-2021)' started by panicman, Dec 17, 2024.
  1. Dec 17, 2024 at 10:13 PM
    panicman
    panicman [OP] Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Several years ago, I had the truck act weird on the freeway- it just went dead in mid flight, with all gauges, electrical, rpm's, everything going dark and dead.
    And then it would pick back up. And then die, and start, die, etc....
    I found the negative battery cable was caked with powdery white residue, and was a little loose. Cleaned, tightened, and all was good for a long time.
    A week ago, I changed the oil, and checked the negative battery terminal by trying to wiggle and shake it. It looked clean and felt plenty tight.
    Well, my shake must have knocked it loose! The next morning it did it again as I pulled into work. So, I loosened the terminal, looked for build up, crammed it back on and tightened it, and it has been fine.
    I do run some mods- a power amp and seat heaters that I added that may exacerbate the persistence of the issue, but could this perhaps be solved with a beefier negative cable with a better clamp?
  2. Dec 18, 2024 at 4:26 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    How old is the battery?
  3. Dec 18, 2024 at 4:29 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    You can get those terminal upgrades from sdhq. I like mine for my extras and they are plenty sturdy. Alternatively you can clean the terminal and clamp and coat it in used oil and it stops corrosion.
    panicman[OP] likes this.
  4. Dec 18, 2024 at 4:36 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
  5. Dec 18, 2024 at 4:42 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
  6. Dec 18, 2024 at 3:19 PM
    panicman
    Eric
    About a year and a half. I don't doubt the battery at all. IMG_3107.jpg Once I cleaned and tightened, there have been no more issues.
  7. Dec 18, 2024 at 3:38 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Your ground terminal looks very bad. At least remove oxidation on the mating surface with sand paper.
    panicman[QUOTED][OP] likes this.
  8. Dec 18, 2024 at 5:30 PM
    panicman
    Eric
    That's what I thought too. That picture is after I wire brushed and applied dielectric grease. I think a beefier negative clamp is in order.
