Rear Diff Change
Discussion in '3rd Gen Tundras (2022+)' started by machd08, Dec 18, 2024.
  1. Dec 18, 2024 at 7:50 AM
    machd08
    machd08 [OP] New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Well the ole gal 24/1794 LE is going in for Rear Diff replacement tomorrow, I always change the rear/front differential fluid at on or about 5K miles for the first time (my choice to do so).
    Never heard noise or anything. This was on the magnet, SA and Technician at local dealer said bring it in tomorrow, change it (parts on hand).
    Dealership said it would be the 4th one they have changed on 3rd Gen.
  2. Dec 18, 2024 at 7:55 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    That long piece is weird. This is what I got on mine
    Tundrastruck91 likes this.
  3. Dec 18, 2024 at 8:21 AM
    machd08
    CLARENCE
    Damn, are they going to change it or?
  4. Dec 18, 2024 at 8:27 AM
    eddiefromcali
    Eddie
    100% Stock
    nope...thats actually very common for a new diff. Every truck I've owned has had some sort of machining debris/chips in it at the first drain (Mostly GM 10b & 14b diffs)
  5. Dec 18, 2024 at 8:52 AM
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    That is why it is important to change the oils in the drivetrain relatively early, to minimize the manufacturing swarf going on to get pulverized into blackness.
  6. Dec 18, 2024 at 8:54 AM
    eddiefromcali
    Eddie
    100% Stock
    exactly...If wear pattern looks good, gears dont whine and locking mechanism (Assuming you have it) works, youre ok. Its gonna take a lot more than a few chips to ruin a diff
    machd08[OP] likes this.
  7. Dec 18, 2024 at 12:44 PM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    Damn, I have never seen anything like what is in those pictures in any differential I have ever owned and changed the fluid on... which is every one of them. But then, I have not yet changed the fluid in my 2023 Tundra. Yikes.
  8. Dec 18, 2024 at 1:19 PM
    SAGE63
    San Diego County
    damn....
    machd08[QUOTED][OP] likes this.
  9. Dec 18, 2024 at 3:07 PM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    01 Tundra SR5, 02 Sequoia SR5, 23 Tundra Limited double cab
    That is what the magnet is for. Machining slag in a differential housing is not uncommon and is usually caught on the magnet first time or two the fluid is changed. If the rear differential is quiet and no other problems, don't worry about it. At least Toyota still puts drain plugs on their differentials making fluid change a breeze.
  10. Dec 18, 2024 at 3:38 PM
    machd08
    CLARENCE
    Not worried, dealership SD said bring it in and will swap it under warranty
    Leo's first and FrenchToasty like this.
  11. Dec 18, 2024 at 3:47 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Had the same crap in the rear diffs of gen2.5 Tundra and gen2 Sequoia. Front diffs were clean, as well as transfer cases.
  12. Dec 18, 2024 at 3:58 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    According to ECGS, the key is proper beak-in for a new or re-manufactured third member ... makes one wonder how Toyota is doing this?
  13. Dec 18, 2024 at 4:04 PM
    raylo
    Frederick, MD
    Differentials, blocks and main bearings... this debris problem is spreading. ;-0. Toyota needs to clean up their act.
  14. Dec 18, 2024 at 4:10 PM
    MVRCA
    MVRCA New Member
    Las Vegas
    2016 Tundra TRD Pro
    White Knuckle sliders, BDS 3" lift with Fox 2.5's. Method 305 NV with 35" Trail Grapplers.
    Manufacturing QC seems to be wanting a bit. Ugh.
  15. Dec 23, 2024 at 4:06 PM
    bailey bulldog
    bailey bulldog New Member
    I'm thinking about running some Amsoil.
    Funny story, I bought a 16 Tacoma new and the rear diff only had about a cup of fluid. Needless to say it grenaded within a few miles from the dealership....fun times.
  16. Dec 24, 2024 at 1:14 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    The thing is... If your diff is quiet, I wouldn't change it. New diffs are 50/50 there are a few people on this forum who had rear diff replaced and new one is more noisy than the old one.
  17. Dec 24, 2024 at 5:47 AM
    machd08
    CLARENCE
    New is quiet, so far so good, but only couple hundred miles on her.
    Kap1[QUOTED] likes this.
