Window woes
Discussion in '1st Gen Tundras (2000-2006)' started by Crow1974, Dec 14, 2024.
  1. Dec 14, 2024 at 7:31 PM
    Crow1974
    Crow1974 [OP] New Member
    Eric
    2000 tundra
    I switched out my passenger door from 2000 Sr5 truck with a 2000 Limited door and my power window does not work now. Everything matched up other than the gray plug under the dash , it has different plug. Is that plug to the power mirrors or is that effecting my window? Appreciate any advice
  2. Dec 14, 2024 at 7:35 PM
    Picture would help, tremendously. You should’ve re-used your OEM door harness from the original door. In fact, I would’ve transferred over all internals. It should’ve been plug and play. Knowing what all you swapped over would help too.
  3. Dec 14, 2024 at 7:57 PM
    Crow1974
    Eric
    2000 tundra
    I will get some pics in the morning when it gets daylight, but I had a suspicion I might have to swap the harnesses
    FishNinja likes this.
  4. Dec 16, 2024 at 6:53 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    get back to work lol
    100% your issue.
    whodatschrome likes this.
  5. Dec 17, 2024 at 2:05 PM
    Crow1974
    Eric
    2000 tundra
    I switched out the wiring harness and it worked from drivers side control, then I put switch on and it worked from passenger side to but not drivers side. Now it won't work from either side. Any help will be appreciated
  6. Dec 17, 2024 at 2:41 PM
    There's a 30A window-style fuse labeled "PWR" in the dash fusebox, I believe in position 37 of this picture. Check that is intact.
  7. Dec 17, 2024 at 4:00 PM
    Crow1974
    Eric
    2000 tundra
    Appreciate the help. Fuse was ok, so I started tracing out the wire and found a broken spot that was only making connection part of the time, fixed that and now everything works like it should ( for now anyways)
    shifty` likes this.
  8. Dec 17, 2024 at 5:18 PM
    Curious, where was the wire damaged? In the rubber flexible sleeve the wires pass thru into the door?
