  1. Dec 16, 2024 at 2:35 PM
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    They just dropped last week!
  2. Dec 16, 2024 at 2:50 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    This guy lol here we go
  3. Dec 16, 2024 at 2:56 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    My name is Ruslan and I have a problem. :rofl:
  4. Dec 16, 2024 at 2:56 PM
    CaptRussia253
    Ruslan
    Damn I should have waited. Can’t wait to see them on yours.
  5. Dec 16, 2024 at 3:00 PM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    yes still stock (LED). the housing shroud tabs are cracked a bit, but also the light lens and the tabs it connects to the housing/shroud are whack too.
  6. Dec 16, 2024 at 3:08 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    “WE” have a problem lol
  7. Dec 16, 2024 at 3:08 PM
    CaptRussia253
    Ruslan
    This is true. I should just be happy with two sets. My wife would kill me if I buy a third set of wheels. haha. Honestly I need four total for each season. :thumbsup:
  8. Dec 16, 2024 at 3:08 PM
    rdiddy5
    rdiddy5 New Member
    Arizona
    I got these work lights mounted up high on the tent. They were previously under the bumper. Now I can illuminate an area, like when setting up camp at night, or hitching up the trailer, etc.
    Found that extrusion strut slot cover material that fills the t-slot gap and covers the wires.
  9. Dec 16, 2024 at 3:35 PM
    Tundra family
    Tundra family New Member
    Snow tires, all weathers, a set with highway tires and a set of M/T. Then you always have an excuse to keep swapping LOL
  10. Dec 16, 2024 at 3:57 PM
    CaptRussia253
    Ruslan
    That is the dream.
    grant.ducckk and Tripleconpanna like this.
  11. Dec 16, 2024 at 4:45 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    ...or you could just say you have 2 full sets and a pair of spares for each set :hattip:
  12. Dec 16, 2024 at 6:19 PM
    mfelton18
    mfelton18 New Member
    South Central Texas
    2014 Magnetic Grey SR5 4x4 crewmax
    Installed new rear leaf springs, shocks and bump stops. Got General Springs HD leafs, Eibach stage 2R shocks and Wheeler bump stops. Took about 5 hours and a few cocktails after.
  13. Dec 16, 2024 at 6:22 PM
    Tundra family
    Gonna need a review on the leafs, I'm in the market
    mfelton18[QUOTED] likes this.
  14. Dec 16, 2024 at 6:37 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I have my Boise Springworks AALs to install still! I need to get off my arse, more!!
    BlueRibbon4x4 likes this.
  15. Dec 17, 2024 at 5:15 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Well, that doesn’t look good does it? Yeah I know.
    I was riding on this for about 2 weeks. The culprit was that when I did my brakes last year, I slapped on TOO much brake lube. The result was that it caked up, causing the pins to most likely not allow the pads to slide easily. Took a hell lot of brake cleaner to scrub all the gunk away. Driver side took about an hour, passenger took about 30 min, rears took about 45 min each.
    The rears were still good, surprisingly. But I ended up just swapping everything out. New rotors for fronts and rears with new pads all around.
    Now I know that once the Yellowstuff start squealing, it’s time to pick up another set. More so the fronts than the rears. The rears can probably last me twice as long as the fronts. Thin layer of lube and anti-seize on the pins will save me from more headaches in the long run.
    I may need to set up an alignment check again to make sure camber hasn’t moved. Noticing some slight wear on the sides.
    At least now I have peace of mind knowing what went wrong on the previous brake job.
    Also swapped out the 0w-20 to 5w-30. AMSOIL will be next on the list for the next oil change.
  16. Dec 17, 2024 at 5:49 AM
    centex
    centex New Member
    Just how much lube did you use to cause that issue? Generally one packet per caliper is all you need.
    pvn.beluga likes this.
  17. Dec 17, 2024 at 5:58 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Best place to go when public beaches are crowded on holidays. The 4x4 only section drastically cuts down on traffic.
  18. Dec 17, 2024 at 6:02 AM
    Florida AF
    Logan
    North Florida
    Jealous as I never made it down there during my stent in Texas. Hoping to bring the wife and kid there when we do our next big trip. This looks like a dream day!
    and my only regret with my truck is not having a 4wd for things like this. I still wouldnt care to use it, but just having it to get access to some of the country's beaches would be nice. They closed the one I went on near me that was 2wd tolerant.
  19. Dec 17, 2024 at 6:17 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Every year there's a huge beach cleanup event held by volunteers who honor a local beachcomber who passed away a few years ago. Only open to 4WD because past the "point of no return" sign, the beaches are totally unmolested - no county/state maintainers grading loose sand, nada. It's raw beach and in some sections you can get caught in high tide and unable to drive back once the tide hits the dunes. Pure coastal beauty.
    That being said, the last beach cleanup brought in ~28 tons of trash. Next year will mark 30 years of these cleanups and approximately 30 miles of beach get scouted for trash.
  20. Dec 17, 2024 at 6:48 AM
    reneaux
    reneaux I've been around
    2017 SR5 CM 4x4
    One of my favorite beaches. Would love to be a part of the cleanup I will have to check that out.
  21. Dec 17, 2024 at 6:50 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Friends of Padre
  22. Dec 17, 2024 at 7:42 AM
    18DCTRD
    18DCTRD New Member
    Dave
    Dracut, MA
    ‘18 DC TRD Off Road
    How do you like the yellow pads with the factory oem rotors? Any noticeable performance difference?
    I switched to Pennzoil Ultra Platinum 5-30 at my last oil change, I'm happy I made the switch.
    BR73 and pvn.beluga[QUOTED] like this.
  23. Dec 17, 2024 at 8:17 AM
    Tundra family
    I can vouch for the yellow stuff and OEM. I've had them on slotted rotors and it felt good, but OEM have a better bite. They are DUSTY AF though, if you're a clean rim guy just avoid em. LOL
  24. Dec 17, 2024 at 8:23 AM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    35" KO2, METHOD 701, WESTCOTT COLLAR, CB+3, BUMPER SHIMS, CALIRAISED ROCK SLIDERS STEP EDITION, DIAMONDBACK HD
    Got rear ended on the Lowe’s parking lot :mad: time for a steel bumper??
  25. Dec 17, 2024 at 8:34 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Bummer! Paging @STravis
  26. Dec 17, 2024 at 8:35 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    All in the snow no less! Your dedication to maintenance is admirable
  27. Dec 17, 2024 at 8:40 AM
    CaptRussia253
    Ruslan
    I was just about to tag him haha.
    @STravis time to hook this guy up!
  28. Dec 17, 2024 at 8:45 AM
    JrJrOffroad
    JrJrOffroad Somewhere in the west
    Anthony
    Monument, CO // Cave Creek, AZ
    rear bumper timeeeee- best tundra mod by far
  29. Dec 17, 2024 at 8:46 AM
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    That's a bummer man! If you are interested we build a bumper that would probably cut off most of that damaged area and save you from having to take it to the body shop.
  30. Dec 17, 2024 at 8:49 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    That's pretty nice. Does it work w/ BSM?
