Need immediate Inputs
Discussion in '2.5 Gen Tundras (2014-2021)' started by pvn.beluga, Dec 16, 2024.
  1. Dec 16, 2024 at 9:20 AM
    pvn.beluga
    pvn.beluga [OP] New Member
    Phuc (Phooc)
    Connecticut
    Thoughts on these caliper pistons?
    Driver side outer pad completely wore down.
  2. Dec 16, 2024 at 9:25 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Can’t tell much from that. Do they compress? The pads can get stuck in the casting and the pins and accelerate wear
  3. Dec 16, 2024 at 9:26 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Yeah clean em up/lube and push em back with the old pad - I do not see any leaks or tears.
    Filthyphil likes this.
  4. Dec 16, 2024 at 9:28 AM
    Tundra family
    Tundra family New Member
    Looks fine, clean em up and send it.
  5. Dec 16, 2024 at 9:28 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    I may have over done it with brake lube. It caked up
  6. Dec 16, 2024 at 9:33 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Cleaned all the gunk
    Tundra family and JMGmanAZ like this.
  7. Dec 16, 2024 at 9:50 AM
    Tundra family
    Looks better than anything I've been working with for the last few pad swaps. :thumbsup:
  8. Dec 16, 2024 at 9:51 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    So I may have added lube to the wrong places previously. Where are you guys adding it?
  9. Dec 16, 2024 at 9:55 AM
    Tundra family
    I'm sure someone's going to tell me I'm wrong, but the only thing I grease is the pins
  10. Dec 16, 2024 at 9:56 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    We meet once again yellows. OE rotors on.
    Tundra family likes this.
  11. Dec 16, 2024 at 10:09 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Anti-seize on the slide pins (after you scotch pad them and clean, and on the back of the pad where the pistons contact. That's what I've done historically no issues. Pistons and caliper looks fine to me also.
  12. Dec 16, 2024 at 10:09 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Does the rotor have some play on the hub prior to pad installation? I don’t remember.
  13. Dec 16, 2024 at 10:11 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Thin coat I assume?
    reywcms[QUOTED] likes this.
  14. Dec 16, 2024 at 10:16 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    yessir
  15. Dec 16, 2024 at 10:25 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    New hardware too from Napa.
  16. Dec 16, 2024 at 10:31 AM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    I've always used thin coat of ceramic brake grease on corner end of pad plate where it might touch caliper, on back of pad between the plate and shim, and where shim touches pistons. Plus pins of course.
    Tundra family and pvn.beluga[OP] like this.
  17. Dec 16, 2024 at 10:34 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Just my luck that it snows today in Connecticut.
  18. Dec 16, 2024 at 10:54 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Definitely used too much brake lube last change.
  19. Dec 16, 2024 at 11:13 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
  20. Dec 16, 2024 at 11:21 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Now onto the rears
  21. Dec 16, 2024 at 11:25 AM
    Same here.
  22. Dec 16, 2024 at 11:51 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Alright, what are we greasing for the rears?
  23. Dec 16, 2024 at 12:07 PM
    Tundra family
    The pins and the clips that the pads slide in, and I guess the backing plate, although that is a new one to me. Great choice of pads by the way, love me some of that yellow stuff
  24. Dec 16, 2024 at 12:55 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Does anybody have torque specs for front and rear caliper bolts and rear sliding pins?
    getting multiple numbers from different sources.
  25. Dec 16, 2024 at 1:20 PM
    Tundra family
    I know for the sure the front is 79 ft lbs. I think the back is 40 but don't quote me on those.
  26. Dec 16, 2024 at 1:27 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    on the caliper bolts put red loctite on them, slide pins in the rear get grease but no loctite. Just hit the front and rear caliper bolts with the impact or make sure theyre good and tight, the slide pins you want to just snug up
  27. Dec 16, 2024 at 1:31 PM
    joseph_womack
    Joe
    Louisiana
    torque on front caliper bolts is 133 ft lbs
    rear caliper bolts are 123 ft lbs
    rear slide pins are 65 ft lbs
    this is from alldata for a 2021 Tundra 4wd; I don't think I would go to those numbers since you aren't using new hardware, just do what I previously stated
  28. Dec 16, 2024 at 1:34 PM
    joseph_womack
    Joe
    Louisiana
    Breakdown attached
    pvn.beluga[OP] likes this.
  29. Dec 16, 2024 at 3:56 PM
    Tundra family
    That seems really high, is that the bracket to the knuckle or the caliper to the bracket?
  30. Dec 16, 2024 at 4:34 PM
    joseph_womack
    Joe
    Louisiana
    I agree it does seem high and I wouldn't torque it to that on a customers car or my own; the bolts are beefy so I don't doubt that they can take it but I would be worried about continuously torqueing to that, the bolt will get fatigued and break. On the repair manual it lists for new bolts which is why I said just red loctite and get it very tight
    thats an official repair manual as well so those numbers are accurate
