Leaf spring recommendations?
Discussion in 'Suspension' started by PermafrostTundra, Dec 15, 2024.
  1. Dec 15, 2024 at 12:45 PM
    PermafrostTundra
    PermafrostTundra [OP] New Member
    I have a LonePeak wedge style camper on order. Base weight of the camper is 400lbs and I imagine after adding gear I will have a constant weight of about 650lbs then occasionally more when loaded up for trips.
    I currently have Bilstein 5100’s front and rear with the fronts on middle setting with 2 Coachbuilder 1/2” shims on the driver side and one on the passenger. This puts me just slightly nose high maybe 1/2-3/4”.
    The end goal would to have about 1” of rake loaded with my constant weight. Any recommendations on leaf spring packs to look at or other recommendations? Also with the 5100’s it says the rears are good for 1” of lift, is there any stretching this out?
    Thanks in advance.
  2. Dec 15, 2024 at 1:28 PM
    mfelton18
    mfelton18 New Member
    South Central Texas
    2014 Magnetic Grey SR5 4x4 crewmax
  3. Dec 15, 2024 at 1:32 PM
    mfelton18
    South Central Texas
  4. Dec 15, 2024 at 4:21 PM
    d33pt
    d33pt New Member
    I use RAS spring helpers for the same camper load. I put enough tension on the springs to keep it at around stock level. Rides great and doesn't sag.
  5. Dec 16, 2024 at 7:42 AM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    Alcan
    texasrho83 likes this.
  6. Dec 16, 2024 at 7:51 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Custom deavers or alcans
  7. Dec 16, 2024 at 8:17 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    This thread can be locked now...
    reywcms[QUOTED] and FrenchToasty like this.
  8. Dec 16, 2024 at 8:42 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    I have the icon leafs on mine with about 300lbs of constant extra weight and another 300+ when loaded up for a trip, and they do pretty well. I agree that custom leafs from alcan or deaver are probably better, but the icons are half the price and there is no wait to get them made.
    If you go custom you'll need to get the camper on and loaded and take your truck to a scale
    PermafrostTundra[OP] likes this.
  9. Dec 16, 2024 at 9:36 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
