2020 OEM Fog Lights won't stay connected to VLeds
Discussion in '2.5 Gen Tundras (2014-2021)' started by brkncly, Dec 16, 2024.
  1. Dec 16, 2024 at 6:35 AM
    brkncly
    brkncly [OP] New Member
    Oregon
    I purchased a set of VLeds V25 Monochrome Seriies Dual Color White / Yellow 9006 9006 H10 9145 9140 to replace the factory fog lights. When I connected them together I noticed that they wont’t stay snapped in and doesn’t make a positive connection. I was wondering if they made a coupler that I can use instead of cutting and splicing the wiring harness. First picture is the OEM socket and the 2nd picture is VLeds pigtail. 3rd & 4th pictures showing them connected together from different sides
  2. Dec 16, 2024 at 7:50 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    On your 3rd photo. There is that tab. It should be on the other side where the lock/unlock tab is on the oem wiring.
    If you flip them and they lock in but the fog wont turn on. It is because the polarity on our truck are reverse. That is why it wont lock in or stay lock when you push them together.
    just like on your 4th photo. You should be able to read the “+” and “-“ on the same side as the factory lock/unlock tab.
    So you have a choice here. You can de-pin the factory plug and switch them around. Or leave it as is and use zip tie or electric tape to secure the 2 plug together so they won’t come apart. You can’t depin the vled plug because it’s solid 1 piece as you can clearly tell.
    brkncly[OP], Leedaar and bulldog93 like this.
  3. Dec 16, 2024 at 10:11 AM
    brkncly
    Oregon
    I tried both ways, they do stay on if I hold them together with some force behind the connectors.
  4. Dec 16, 2024 at 10:35 AM
    BrandonL812
    Brandon
    I remember my diode dynamic ss3 fog was also pretty tough to get clip in. Had to use some muscle to push them together. They stayed just fine.
  5. Dec 16, 2024 at 2:20 PM
    brkncly
    Oregon
    Ended up getting these, hopefully they work.
    BrandonL812 likes this.
