Floating display w/column shifter
Discussion in 'Audio & Video' started by Jeffninjaslayer, Oct 16, 2024.
  1. Oct 16, 2024 at 12:02 PM
    Jeffninjaslayer
    Jeffninjaslayer [OP] I37 butterfly murderer
    2014 black dc
    2014 SR5 DC BAKFlip Revolver X4S 2019 TRD LED headlights Swing Case Interior LED upgrade Color match TRD grille and hood bulge Rigid fog lights 3 1/2" lift Toyota bed rail
    My 2014 has a column shifter and I've been doing research on new head units. Anyone have pictures or links with larger sized units with column shifters. I know there is clearance, but just concerned with it looking cluttered or not enough clearance.
  2. Dec 7, 2024 at 12:06 AM
    ps8820
    ps8820 New Member
    joe
    06 SR5 AC 2WD V8 BktSeats
    due to 'overwhelming response', Im guessing nobody has or wants these floating display HUs...
  3. Dec 7, 2024 at 1:09 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    There’s the Tesla style display if you want to completely swap it out.
    I don’t think a floating would clear the column shifter.
  4. Dec 7, 2024 at 6:05 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Unless your using a cathode ray floating display, you should not have any clearance issues. Passenger side visibility issues maybe....
    1lowlife likes this.
  5. Dec 7, 2024 at 6:29 AM
    Tundra family
    Tundra family New Member
    I don't think very many people have the chicken wing shifter. Wish I did.
  6. Dec 7, 2024 at 7:10 AM
    MadMaxCanon
    What exactly is the question?
  7. Dec 7, 2024 at 7:20 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You can totally clear it if you flush mount the display.
  8. Dec 7, 2024 at 7:58 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    So the HU pics are in my '19 and the column shift is my '00... not apples to apples, but I can't imagine it'd be much different location.
    I think there would be plenty of room. There is some adjustability in the floating displays.
    I have my phone mount between the HU and the wheel with no interference or blockage so there is space.
    bulldog93 likes this.
  9. Dec 7, 2024 at 7:59 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    When you're in Drive, wouldn't the shifter be low enough to not be in the line of sight of the HU?
  10. Dec 7, 2024 at 8:03 AM
    SD Surfer
    Bruce
    So Cal
    Not that anyone would watch movies while in motion... ;)
  11. Dec 7, 2024 at 8:21 AM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    I have a mag mount to the left of the head unit above the 4x4 switch (2nd gen) and the end of the column shift definitely obscures the screen. However, I can't see how it would block any vision of one of the floating screen head units, it would be too far away.
    SD Surfer likes this.
  12. Dec 7, 2024 at 7:22 PM
    ps8820
    ps8820 New Member
    joe
    Floating display HU- Does it work for you or not [if you have one installed, especially in a FGT]?
    Why not or why so? [eg: crowds the cab, obscures air vents or other..jambs fingers against shift lever end,,,on n on n on...
    Pics to support your case one way or the other appreciated....
  13. Dec 7, 2024 at 7:37 PM
    Pomp_Cat115
    Pomp_Cat115 New Member
    Los Angeles, CA
    I have a pioneer on my 2011, never had any issues with clearance or feeling cluttered.20241207_193401.jpg 20241207_193412.jpg 20241207_193412.jpg
    Tundra family likes this.
  14. Dec 7, 2024 at 7:42 PM
    ps8820
    ps8820 New Member
    joe
    Personally think shift lever is too long anyway in FGTs; feels like with an 8" floating display it"d be close, but going to 9 or 10 might be a finger jammer or broken display when shifting back & forth quickly for parking, etc...
    Not that i have NBA size hands, but i remember in my FGTacoma having clearance issues swinging the steering wheel and catching the W/shieldWasher arm w/my fingers.
    OTOH, biggest plus is larger screen and closer to eyes/rt hand, which could make extra cost of HU a wash.
    I can live w/max 7" for FGT dash openings, but if I want bigger display, will i be compromising cab space or creating awkward access/driving issues..?
    Wouldnt think its much of an issue in later GenTundras since I last tried one on at a dealership couple weeks ago and couldnt help noticing the frt cab/dash area is huge [compared to FGT] like an AirBus cockpit. felt like i had to clear take-off w/ ATC tower...-
  15. Dec 8, 2024 at 5:47 PM
    ps8820
    ps8820 New Member
    joe
    thx @Pomp_Cat115.
    It looks like your SGT may benefit from a slightly larger cab or better spread dash arrangement. Doesnt look like a knuckle-buster from your shift lever as well.
    Is that Pioneer 9 or 10" ?
  16. Dec 8, 2024 at 5:58 PM
    ps8820
    ps8820 New Member
    joe
    thx @SD Surfer. About your FGT: Did you ever consider a Floating 8 or 9" HU?
  17. Dec 8, 2024 at 6:18 PM
    Pomp_Cat115
    Los Angeles, CA
    It's the 10" screen
  18. Dec 8, 2024 at 6:36 PM
    SD Surfer
    Bruce
    So Cal
    No, when I did that one, I don't think the floating big screens were really a thing yet.
  19. Dec 8, 2024 at 8:57 PM
    ps8820
    ps8820 New Member
    joe
    thx @1lowlife, but i think blocking screen vis wouldnt be as bad as knocking the shift lever out of gear accidentally while turning down volume @70...of course im exaggerating but i would rather have a floor/console shifter instead of the 'chicken wing'.
    1lowlife[QUOTED] likes this.
  20. Dec 9, 2024 at 5:08 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Understood, I had this HU in my 2005 with a column shifter..
    No issues there, other than changing the CDs..:eek2::cool::thumbsup:
  21. Dec 15, 2024 at 7:13 PM
    ps8820
    ps8820 New Member
    joe
    As much as I'd like a bigger screen, I dont think I have clearance w/out rubbing my knuckles against it w/every shift.
    Not shown in pic but I always have my mitt over the end of the shifter.
