OBDLink MX+ and OBD Fusion App with CarPlay - Read Outs
Discussion in '2.5 Gen Tundras (2014-2021)' started by JohnWhicker, Nov 27, 2024.
  1. Nov 27, 2024 at 5:33 PM
    JohnWhicker
    JohnWhicker [OP] New Member
    Do these numbers look right? Temps for engine oil, coolant and transmission? First time I read these temperatures and data in CarPlay. Pretty cool app and setup honestly. I purchased the custom Toyota PID package which got hundreds of pids available.
    G_unit3000 likes this.
  2. Nov 27, 2024 at 6:22 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Those are normal transmission temps for a truck with no cooler. With a cooler it will be more around 180-190. Guessing there's some reason you're using OBD fusion over the OBDlink app. The OBDlink MX+ comes free with all those PIDs in the app. Also there is no engine oil temp sensor, it just estimates it and it basically will follow suit with what ever your ATF pan temp is so no real use to look at the engine oil temp.
  3. Nov 27, 2024 at 6:44 PM
    JohnWhicker
    The OBDlink MX+ app does not have CarPlay, only the Fusion app does. Yeah is a waste of $$$ but I like the idea to display it all in the CarPlay.
    G_unit3000 and Joe333x[QUOTED] like this.
  4. Nov 27, 2024 at 6:50 PM
    Heyyo_Friday
    Heyyo_Friday Circle driving enthusiast
    Derek
    2020 tundra 1794
    Rays valve stem caps
    Those is the same temps my truck ran on my recent road trip. 195-201 ECT and 205-212 trans temp
  5. Nov 27, 2024 at 7:37 PM
    Joe333x
    Joe333x Member
    Boston
    Gotcha, figured that had something to do with it, I have 2019 so no car play, I use a tablet mounted to the dash instead.
  6. Nov 27, 2024 at 7:45 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    I'm on a camping trip now, first time towing since installing the Kenwood and Maestro, giving me the ability to monitor trans temps.
    S4 @ about 62-ish MPH, towing from San Diego to just this side of Yuma.
    On the flats she settled in at 210°-212°, and climbing the grade out of town up to just over 4,000' the highest I saw was like 228° and temps immediately started dropping once we plateaued.
    169 miles, with a 9.6 MPG average with a 5,500 lb. parachute.behind me.
    All in all, not bad.
    20241126_115136.jpg 20241127_075421.jpg 20241126_162927.jpg 20241127_122817.jpg 20241127_120559.jpg 20241126_143817.jpg
  7. Nov 27, 2024 at 10:04 PM
    DirkS
    DirkS New Member
    Dirk
    Abbotsford, BC
    2016 Tundra Limited
    Funny part is I just picked up an OBD reader and was looking at apps. The thing I’d really like is to be able to get individual tire pressures instead of just one idiot light on the dash. Can you tell me if the app shows that? Had that with a Maestro setup on my old 4Runner and I miss it.
  8. Nov 28, 2024 at 2:55 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    How are you able to get OBD Link to show on the display?
  9. Nov 28, 2024 at 2:58 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Ah. Nevermind, it’s the OBD fusion app. I’m guessing it’s from the creators of OBD Link?
  10. Nov 28, 2024 at 3:49 AM
    JohnWhicker
    Let me check it today and will let you know.
    DirkS[QUOTED] likes this.
  11. Nov 28, 2024 at 7:21 AM
    JohnWhicker
    It doesn't show the pressure in PSI :( See image.
  12. Nov 28, 2024 at 7:54 AM
    SD Surfer
    Bruce
    So Cal
    I'll bet if you play around in the app there's a setting to change the unit of measure from bars (or whatever the hell that is) to psi.
  13. Nov 28, 2024 at 8:01 AM
    JohnWhicker
    You Sir are a very smart man. I am going to give you the Turkey award :)
  14. Nov 28, 2024 at 8:07 AM
    DirkS
    DirkS New Member
    Dirk
    Abbotsford, BC
    2016 Tundra Limited
    I’m curious if that results in a more reasonable number. Aside from the fact that the number shown originally is negative (help, my tires are imploding! :(), 14.73 mmHg is only a bit over 7 PSI…
  15. Nov 28, 2024 at 8:43 AM
    SD Surfer
    Bruce
    So Cal
    Woo Hoooo!!
    Yay, a Turkey award... Gobble till you wobble!
  16. Nov 28, 2024 at 9:05 AM
    JohnWhicker
    You Sir suck because you're correct. No Turkey award for you :)
    But yes, it looks like my truck is on Mars now
  17. Nov 28, 2024 at 9:31 AM
    SD Surfer
    Bruce
    So Cal
    Ha ha! I got a turkey award and you didn't!
    Neiner neiner neiner!
  18. Nov 28, 2024 at 9:46 AM
    DirkS
    DirkS New Member
    Dirk
    Abbotsford, BC
    2016 Tundra Limited
    Hah - joke’s on you, I’m Canadian and had my turkey a month ago! :p
  19. Nov 28, 2024 at 9:47 AM
    DirkS
    DirkS New Member
    Dirk
    Abbotsford, BC
    2016 Tundra Limited
    But think of the air time you’ll get over those bumps!
    Thanks for checking - I appreciate it!
  20. Nov 28, 2024 at 9:48 AM
    JohnWhicker
    You sure it was a turkey? An election was lost in US and many of them emigrated to Canada in disguise :)
  21. Nov 28, 2024 at 9:49 AM
    JohnWhicker
    Is kind of silly not to get the right PSI readings since the data is there. I will ask the app support "whatsup"
  22. Nov 28, 2024 at 10:34 AM
    SD Surfer
    Bruce
    So Cal
    Dagnabbit!
  23. Dec 14, 2024 at 4:16 PM
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    King's all around, Dirt Deeds 10" exhaust, 18x9 Method 305 NV, Falken Wildpeak A/T3W 305/65/18 tires, tinted windows (shhhhh)
    Doesn't your instrument cluster have individual tire pressures?
  24. Dec 14, 2024 at 4:35 PM
    SportDek
    SportDek Boat hauler, Bus Driver
    Dale
    TEXAS from MN
    2021 1794 Tundra Crewmax Windchill Pearl
    TRD Swaybar, RCI Skid plates, DiamondBack HD cover, bed rug, Cooper AT3 4S
    How do you get to that screen on the instrument cluster? I had it at one time, but have lost it to MPG now.
  25. Dec 14, 2024 at 4:45 PM
    DirkS
    DirkS New Member
    Dirk
    Abbotsford, BC
    2016 Tundra Limited
    Nope. I have a 2016 - different display.
  26. Dec 14, 2024 at 4:49 PM
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    You just arrow over using the steering wheel control button. Once to the car icon you may have to arrow down.
  27. Dec 15, 2024 at 4:36 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
  28. Dec 15, 2024 at 6:35 AM
    SportDek
    Dale
    TEXAS from MN
    OK, got it! Thanks guys! I guess you are never too old to learn new tricks on these Tundras!
