Platinum with AVS/air ride question
Discussion in '3rd Gen Tundras (2022+)' started by trdandglocks, Dec 5, 2024.
  1. Dec 5, 2024 at 1:27 PM
    trdandglocks
    trdandglocks [OP] New Member
    2022 Tundra Platinum
    Hello everyone,
    Has anyone with a Platinum with AVS/air ride in all 4 corners, replaced their suspension with another brand? If you did, did you get any lights on your dash? Thank you for your help.
  2. Dec 5, 2024 at 4:32 PM
    Rockpig
    Rockpig You did what?
    08 Limited
    Just curious, why would you want to do this? Pulling the system out and replacing it was aftermarket airbags seems like a backwards move and costly.
  3. Dec 5, 2024 at 5:59 PM
    trdandglocks
    I didn’t actually replace the air bags, I replaced the front and rear shocks with TRD Pro shocks. Obviously the Fox shocks from the TRD Pro didn’t have the connection that the AVS shocks did, which is why I’m getting a light on the dash, I think.
    I know there is other people out there that have done it, I just can’t seem to find any.
  4. Dec 5, 2024 at 6:17 PM
    Hella Krusty
    Hella Krusty New Member
    AVS and Air Lift are 2 different things
    Air Lift adjusts the ride height
    AVS adjusts the dampening of the shocks ( slow rebound for comfort or , ride like a Ford rebound )
  5. Dec 5, 2024 at 6:38 PM
    trdandglocks
    That’s correct, i still have my load leveling air bags in the rear, I just have Fox shocks. I was looking for a slight lift/level and better suspension.
  6. Dec 14, 2024 at 3:25 PM
    trdandglocks
    Still wasn’t able to find an answer on this, per the dealer there isn’t a workaround if you have an air suspension.
  7. Dec 14, 2024 at 3:26 PM
    trdandglocks
    I ended up just putting the original suspension back on, will have the TRD Pro/1794 limited edition suspension up for sale soon.
    23 Platinum likes this.
