Hood Nose Cap...
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Ozcomm, Dec 14, 2024.
  1. Dec 14, 2024 at 10:49 AM
    Ozcomm
    Ozcomm [OP] New Member
    Dean
    2021 TRD Pro
    When I opened the hood on my '21 TRD Pro I heard a 'snap'. Looked up and one of the brackets to the 'nose cone' of the hood has snapped. (see pics) Does anyone know if this can be fixed by replacing the bracket, or does the whole 'nose cone' need to be replaced.
    Thanks
  2. Dec 14, 2024 at 11:38 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    If you take it off, you may be able to jb weld that piece back together. I have had good success with similar issues but don’t know what the other piece of that bracket looks like
    Ozcomm[OP] likes this.
  3. Dec 14, 2024 at 12:38 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  4. Dec 14, 2024 at 12:38 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Does JB Weld work on plastic?
  5. Dec 14, 2024 at 1:08 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    plastic weld......and there are also some good vids on fixing clips on youtube using tools that heat wire for strength and use plastic weld
    Worse case- new hood bulge
  6. Dec 14, 2024 at 4:18 PM
    Ozcomm
    Dean
    2021 TRD Pro
    Its the metal clip that snaped, not the 'nose cone'. I found a clip on Toyota Parts Express for $1.09! I think that will fix it.
  7. Dec 14, 2024 at 4:21 PM
    Ozcomm
    Dean
    2021 TRD Pro
  8. Dec 14, 2024 at 4:45 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    That's awesome.
    I thought the mount broke off..
  9. Dec 18, 2024 at 9:14 AM
    JrJrOffroad
    JrJrOffroad Somewhere in the west
    Anthony
    Monument, CO // Cave Creek, AZ
    FYI If the whole mount breaks, you can just move the bolt and metal piece over to the next bracket. This is what I had to do with mine and its been holding great for a year now.
  10. Jun 15, 2025 at 4:20 PM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    My Hood Bulge broke on Memorial Day weekend when driving Hwy 412 in West Oklahoma... combination of heavy winds and a semi tuck passing in the opposite direction pushing a gush of wind into the front of my truck.
    I ordered an OEM one, but they are backordered with no timetable being given. Ordered a generic one off of Amazon for $100, but it was a light gray, not MGM..
    In the meantime, I have used black gorilla tape and completely sealed off the opening, to keep air from getting into it and pushing it up.. That opening didn't appeasr to serve a purpose, looks like the wind just goes in and hits a wall so to speak.. So far, it's staying put. Figured what would it hurt bc once I receive a replacement, this one is done.
    The only thing holding it on is the plastic pushpins and the one screw kinda in the middle.. The two screws on each end are both broke.
    Just an idea for anyone in a similar situation.
