Puddle Lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by WVU12, Dec 14, 2024.
  1. Dec 14, 2024 at 10:17 AM
    WVU12
    WVU12 [OP] New Member
    Can Anyone recommend a quality LED replacement for the puddle lights on the bottom of the side mirrors that they have had experience with?
  2. Dec 14, 2024 at 10:21 AM
    Vleds
  3. Dec 14, 2024 at 10:25 AM
    WVU12
    How do these compare with the Morimoto
  4. Dec 14, 2024 at 12:26 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    I installed VLEDs nearly 6 years ago, and they are great. I can't speak to any other brands. These installed cleanly and have had zero issues. It's a lot nicer to enter and exit the truck at night with these. IMG_2442.jpg IMG_2440.jpg IMG_2441.jpg
  5. Dec 14, 2024 at 12:43 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  6. Dec 15, 2024 at 6:17 PM
    WVU12
    Thanks! Vleds will be the next upgrade for puddle lights and cargo light
  7. Jan 10, 2025 at 12:21 PM
    steezy
    steezy New Member
    2021 Tundra TRD Pro
    Glad I found this post. My 2021 TRD Pro has black caps where a puddle light would be. I bought the VLEDS puddle light replacements. If I remove that cap will there be a dongle to plug in the VLEDS?
  8. Jan 10, 2025 at 1:04 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Gotta check and let us know if they do!! I'd imagine you'd still need to throw some wires in but maybe they were considered no longer an option and just a trim difference...
  9. Jan 10, 2025 at 1:18 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    I doubt you will have wiring IN your mirror for puddle lights.
    You can test your mirror plug and see if it supplies puddle light power.
    On my 2014 SR5 I had to run wiring thru the door and thru the mirror.
    I tapped into the driver's side floorboard light circuit.
    I also had to drill my own holes in the mirrors for the lights.
    Your mirror plugs will be M 6 and N 5 behind the door sail.
    You may have to remove the door panel to access it.
    You'll be testing pin 6 brown wire for power and pin 5 white/black stripe for ground on both sides.
    HulkSmurf14 likes this.
  10. Jan 10, 2025 at 1:22 PM
    steezy
    steezy New Member
    2021 Tundra TRD Pro
    You da man!
    1lowlife[QUOTED] likes this.
