TUNDRA (2017) MAINTENANCE SCHEDULE - THOUGHTS?
Discussion in '2.5 Gen Tundras (2014-2021)' started by jayhawknavy02, Dec 4, 2024.
  1. Dec 4, 2024 at 9:24 PM
    jayhawknavy02
    jayhawknavy02 [OP] New Member
    SOCAL
    2017 Tundra 5.7L SR5 Crew Max TRD Off Road 4x4
    Dirty Deeds 10” exhaust TRD Accelerator OTT Tune Sony XAV-9000ES Head Unit AJT Interior Upgrades
    Team,
    Looking to make sure I've got all the maintenance actions that are out there captured for my 2017 Tundra SR5 Crew Max 5.7L (non flex fuel) TRD Off Road 4x4.
    I defaulted to the aggressive side, and if I'm way off, please let me know. I tried to scavenge all I could across the inter webs and the manual. If I've omitted something very much appreciate the feedback. Some items I adjusted to match up in terms of distance or duration to make life easier for me.
    Goal is to keep the truck as long as I can so I'm trying to take care of this beast for the long haul.
    Cheers and thank you in advance.
    Jay
  2. Dec 4, 2024 at 10:04 PM
    AZBoatHauler
    So.Arizona
    Transfer case every 30k is overkill.
  3. Dec 4, 2024 at 10:07 PM
    jayhawknavy02
    SOCAL
    Do you have a recommendation?
    I did mine previously at 50k, but listening to some YouTube Toyota mechanics they recommended cutting the interval in 1/2.
  4. Dec 4, 2024 at 10:10 PM
    AZBoatHauler
    So.Arizona
    Similar to the transmission fluid - they have no interval spec’d except for “extreme” use. I’d go at least 50-60k miles and use the right oil from Toyota - it’s about $160 for the oil so I wouldn’t throw it out more often than necessary.
    My truck has 105k miles and I’ve changed t-case oil once. In that same time, I’ve done three drain and fills on the trans and two on the diffs.
  5. Dec 4, 2024 at 11:35 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Note 2 and Note 3 need to be switched. Why replace diff and xcase oil when the fuel pump fails and the fuel filter every 50k when not towing or going offroad.
    jayhawknavy02[OP] likes this.
  6. Dec 5, 2024 at 2:39 AM
    jayhawknavy02
    SOCAL
    Thank you! I reordered the notes and missed that.
    Windsor[QUOTED] likes this.
  7. Dec 13, 2024 at 7:15 AM
    QuikreteTundra
    QuikreteTundra Previously owned '16 Tacoma SR5 Pro
    '21 Tundra Cement TSS OR 4x4 | '23 T4R Lunar TRD ORP
    I don't see the notes anymore. OP, were they removed? Could I see them again?
  8. Dec 13, 2024 at 3:55 PM
    jayhawknavy02
    SOCAL
    I'm overseas and for some reason I can't load any images.
    File was updated and much improved, but I think I have to wait until I’m back to reliably post. Seems only my cell phone works.
    I have another sort version by time vs mileage I’ll try and post. Once I have all the corrections and inputs I’ll post the excel document and PDF.
    Hope this helps!
    QuikreteTundra likes this.
  9. Dec 13, 2024 at 4:17 PM
    MVRCA
    MVRCA New Member
    Las Vegas
    2016 Tundra TRD Pro
    White Knuckle sliders, BDS 3" lift with Fox 2.5's. Method 305 NV with 35" Trail Grapplers.
    It's stuff like this that makes this place the best. Thanks guys.
  10. Dec 13, 2024 at 4:42 PM
    jayhawknavy02
    SOCAL
    Appreciate it! Definite work in progress, as the Dealer Manual, YouTube Master Techs, Forum, Chilton/Haynes, etc aren’t always aligned on interval (distance/time), but I think I captured (to the best of my knowledge) every maintenance action out there, and if not I will update.
    No hurt feelings on corrections as I’m not a mechanic and don’t play one on TV. Lots more experience here on the forum.
    MVRCA[QUOTED] and QuikreteTundra like this.
