Supercharger CSF radiator Leak
Discussion in 'Performance and Tuning' started by kingranch, Nov 13, 2024.
  1. Nov 13, 2024 at 10:17 AM
    kingranch
    kingranch [OP] New Member
    Magnusson SC 5.7 tundra developed 2 small leaks up top of radiator
    This CSF 7031 is the large upgraded one and only 5 yrs old- warranty is 2 :(
    Can anyone recommend a better radiator w this large of cooling capacity for the Magnusson setup? I don't want to drop 500$ again on something that should last at least 10yrs
  2. Nov 13, 2024 at 10:28 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    pvn.beluga and M3Tundra-JK like this.
  3. Nov 13, 2024 at 10:38 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    The radiator can probably be fixed if you can find a race shop.
    Personally I would just go with an OEM one.
    Mdl likes this.
  4. Nov 13, 2024 at 11:28 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I've been running OEM one since being supercharged in 2012 with no issues.
  5. Nov 13, 2024 at 11:51 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I've said it before I'll say it again. All those aftermarket ones have issues. OEM is the answer.
  6. Nov 13, 2024 at 12:07 PM
    kingranch
    Stock one couldn't keep up w the tune as it was getting hotter w oem rad. Runs cool w the csf but it now has a leak.
    Even Magnusson recommended the csf
  7. Nov 13, 2024 at 12:12 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Have you tried using Toyota red coolant not the pre mix? Higher radiator cap 18psi? Lower enginge thermostat?
    I run my little Maggie 1900 at 10-12 psi pretty consistently with pops to 14psi and at times 6300rpm shifts with no engine overheating.
    Most SC'd tundras with aftermarket hpt tuned have no engine over heat issues.
    reywcms and snivilous like this.
  8. Nov 13, 2024 at 12:16 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  9. Nov 13, 2024 at 12:20 PM
    snivilous
    SW UT
    Something sounds wrong about that, unless your supercharger is heavily modified, then something else is probably at play to make the truck overheat and the CSF is just a band aid fix and covering up the issue.
    Regardless, if you want to stick with aftermarket talk to a radiator repair place or get one of the other aftermarket options like the Mishimoto. Or get a custom mounting setup and run a Griffin 3" or something.
    reywcms and Mdl like this.
  10. Nov 13, 2024 at 12:27 PM
    kingranch
    Only when towing heavy loads it will get hot... never when running around or stomping the gas for fun.
    Mdl likes this.
  11. Nov 13, 2024 at 12:44 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Somethings up with your system then... Many running that blower or more boost with no cooling issues.
    Mdl likes this.
  12. Nov 13, 2024 at 1:11 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Could be too much timing, or an air pocket in the coolant passage. Make sure you're properly topped off. If you have a custom tune, maybe talk to your tuner to see if they added timing somewhere and maybe dialing it back?
    FWIW, no issues with my CSF radiator for the past 4 years...knock on wood.
  13. Dec 12, 2024 at 10:52 PM
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    @kingranch which radiator did you go with? I have the same issue.
  14. Dec 13, 2024 at 5:29 AM
    kingranch
    Csf
    Cools great my bullydog has it around 199-204 a avg..... jumps to 210 if towing or hilly
    I'm happy with the csf cooling however I'm not sold on its longevity as the first one failed prematurely imo
    BigAl likes this.
  15. Dec 13, 2024 at 7:39 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    This is a first, you guys saving me money!
    I had one in the shopping cart ready to go since bought a bigger trailer.
  16. Dec 13, 2024 at 8:02 AM
    blenton
    blenton New Member
    That’s about what I see for coolant temps towing heavy in the summer with the Whipple at 70 mph. Stock radiator. I guess I should note stock tire size (in an LT flavor) and gearing as well, but heavy truck even without the trailer.
