Help, Bilstien 5100
Discussion in 'Suspension' started by Macattack34, Dec 9, 2024.
  1. Dec 9, 2024 at 8:13 PM
    Macattack34
    Macattack34 [OP] New Member
    2015 white Crewmax Limited
    Hey all, new to this forum and I'm sure it's been talked about before but I need some advice.
    Bought some Bilstien 5100 for all the way around. I've been getting conflicting advice. I've heard the middle setting on the fronts will raise the front enough to almost be level but still have a slight rake and I've heard the top setting is ideal for being level. Another person told me doing the top leve) puts the front higher then the rear? Can anyone assist and show me pictures of middle and top.
    I've got a white 15 crewmax limited. It's completely stock except slightly bigger tires currently.
    Thank you in advance!
  2. Dec 10, 2024 at 4:04 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    If you lift the front, you’d also want to do something with your rear. However, it’s your choice on how you want it to sit.
    Personally, I wouldn’t want to only lift the front and neglect the rear.
    You can get a CB+1 or 3/4” shackle to give it a minimal lift for the rear.
    My truck is on 5100s all corners with front at top setting (2.3”) and rear at 3/4” lift.
    AircoolerKirk and eccracer104 like this.
  3. Dec 10, 2024 at 5:01 AM
    Macattack34
    Thanks for the advice, also love the look of your tundra, what size tires are you running?
  4. Dec 10, 2024 at 5:15 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Thanks! I’m on 37s.
    eccracer104 likes this.
  5. Dec 10, 2024 at 5:47 AM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub, Rokblokz XL, AVS visors
    In my opinion that varies based on mileage and rear leaf spring wear. My truck had 250k and rear springs were worn so I did middle setting to be safe. I have about ¾" of rake which i like. Top setting probably would have sat level for me. On a newer truck with less leaf spring wear, you'd probably have ¼"-½" rake at top setting is my guess.
  6. Dec 10, 2024 at 7:25 AM
    DCRB4X4
    DCRB4X4 New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    I have 5100s on front, top setting. 1.5 inch spacer blocks in rear. ( from PO) Was hoping to be able to remove spacers and be level. Not the case.
    My truck sits level like this.
  7. Dec 11, 2024 at 12:28 AM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    That's weird. Your rear springs must be pretty sagged out. 5100s on top setting should be pretty close to stock rear...
  8. Dec 11, 2024 at 5:10 AM
    DCRB4X4
    DCRB4X4 New Member
    Most likely
  9. Dec 11, 2024 at 6:33 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Middle perch on my 08 CM with 145k. No blocks in the back. Been awhile and I no longer recall my measurements but it was a small nose down rake.
    Top perch would have put me slightly nose high.
  10. Dec 11, 2024 at 7:51 AM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    My first suspension upgrade was 5100s all around. I set the fronts at the middle setting and added a CB shim to each side. Total lift was about 2” - a little less than going with the 3rd setting and no shims. (2” is also what the TRD Pros are lifted). This made the truck level and because the coils were not as compressed, the ride quality was not impacted. IMG_2090.jpg
    LD_15 and SD Surfer like this.
  11. Dec 13, 2024 at 5:50 AM
    DCRB4X4
    DCRB4X4 New Member
    This is what my target was. At the last minute I decided to use top setting. Hopefully in the spring I can correct this and get rid of the rear spacer blocks.
    sr5shark[QUOTED] likes this.
