Milwaukee Tools
Discussion in 'Off-Topic Discussion' started by T-Rex266, Nov 9, 2024.
  1. Dec 12, 2024 at 7:08 PM
    #661
    Outbound
    Aaron
    Northern Alberta
    Mine is the 1/2" mid torque. It's got 650ft lbs of breaking force. It pulls lug nuts with ease.
    Leo's first, Prostar 190 and Mater like this.
  2. Dec 12, 2024 at 7:18 PM
    #662
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Model number ?? Price ?
  3. Dec 12, 2024 at 7:19 PM
    #663
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Does anybody have the underhood light? It's one of many on my wishlist
    Leo's first likes this.
  4. Dec 12, 2024 at 7:25 PM
    #664
    blenton
    blenton New Member
    IIRC, Nutbusting torque figures:
    Stubby - 250
    Older mid torque - 450
    Newer mid torque - 650
    Older high torque - 1100
    New high torque - 1200-1600
    That’s maximum developed torque in reverse which takes a few ugga-duggas. In real life, the stubby will do lugs on aluminum wheels but struggles with steel wheels. The mid torque will usually bust free the rear shock bolt but not the front shock bolt unless you are lucky and let it eat for a bit.
    Leo's first and Mater like this.
  5. Dec 12, 2024 at 7:31 PM
    #665
    blenton
    blenton New Member
    Just got it the other day, haven’t used it. Yet. I’ve been using the m12 Rover when working under the hood. It is compact, puts out a good amount of quality light, and it has a magnet on the back to hold it to the underside of the hood. I always have a few in the truck so I don’t have to go searching for them, either.
    I expect the under hood light to be even better.
  6. Dec 12, 2024 at 7:38 PM
    #666
    TacomaTRD4x402
    Southern California
    Nice! I'm looking at the lighting options right now and there's quite a bit. I was gonna pull the trigger when it was on sale but I got a tight budget right now.
    Looking at this m12 Rover and it's $20 off right now at HD. This the one you have? Or the other?
  7. Dec 12, 2024 at 7:40 PM
    #667
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Just food for thought. I used cheap Nilight strip lights under the hood (could use Matt gecko etc etc) and terminated them into a DT connector. Bought this guy so I can power those lights either by m12 battery or off my switchpro
  8. Dec 12, 2024 at 7:46 PM
    #668
    TacomaTRD4x402
    Southern California
    Holy shit! That's ingenius. You just reminded me that several SEVERAL years ago I bought something similar from a guy on TW for my Taco. Adhesive led strip wired to the battery and a switch that would automatically turn them on when the hood opened. I'm sure he or someone that makes them is still out there.
    Wired to one of these switches so would turn off when hood closed and turn on when open
    Leo's first and Mater[QUOTED] like this.
  9. Dec 12, 2024 at 8:06 PM
    #669
    Outbound
    Aaron
    Northern Alberta
    ZappBrannigan, Leo's first and Mater like this.
  10. Dec 12, 2024 at 8:19 PM
    #670
    blenton
    blenton New Member
    This is the one I like. It has a USB port, as well, so you can charge your phone or earphones in a pinch.
    I have the M18 version of the one you posted; it works well for some things, but the little rovers are Excellent. They seem almost as bright as the m12 Rockets but last longer on batteries. They very handy and compact. I will often pack one in to an unlit bathroom or bedroom and it will provide enough light to work without squinting (as long as the walls and ceiling are white-ish, then they will reflect a lot of the light so I literally put the light in the corner facing the walls and ceiling rather than pointing at me). I will also throw them in my trailer if it's dark, or back of the truck when loading/unloading. They provide ample light without blinding you.
    They just released an M18 version of it which I plan on trying out. 110 hours of light on one XC5.0 set to UltraLow... 22 hours on High. Wow.
  11. Dec 12, 2024 at 8:23 PM
    #671
    blenton
    blenton New Member
    A little OT from Milwaukee tools, but I purchased a similar switch years ago with the intent of wiring an LED strip under the bed caps in my truck to illuminate when I open the tailgate. Speaking of which, I think I need to install that...
    Those little M12 adapters are handy. I use them to run 12v accessories light radios, lights, etc on my workbench or outside. I was fiddling with some LED lights I had sitting around and decided to compare lumens and pattern one night but didn't want to wire them up to the truck. I used the adapter with some quick connect fittings and took each light outside to shoot it down the road (I live on a county lane, so I wasn't blinding any traffic). The Hella 550's were as good as I remembered them to be. Speaking of which, I need to go figure out how to put the new ones on the truck. ha.
  12. Dec 13, 2024 at 4:18 AM
    #672
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Big hint in this pic.
  13. Dec 13, 2024 at 4:47 AM
    #673
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Something to do with conduit ? bender, flair tool, press
    wtf is this
    T-Rex266[OP] likes this.
  14. Dec 13, 2024 at 5:03 AM
    #674
    TomC843
    Tom
    Charleston, SC
    Close, I wonder what we would do if we needed to install that disconnect on 1 1/2 conduit?
    Hint- It's not what is there it's what not there. (in the pic)
    other guy is a blue fan, but he just ordered and likes his new small RED band saw.
    Prostar 190 likes this.
  15. Dec 13, 2024 at 5:16 AM
    #675
    I guess if no one is going to answer you it's a punch out press.
  16. Dec 13, 2024 at 5:31 AM
    #676
    TomC843
    Tom
    Charleston, SC
    Knock out kit
  17. Dec 13, 2024 at 5:38 AM
    #677
    Are you knocking out for a booster heater or dishwasher?
    Ghost Rider and Leo's first like this.
  18. Dec 13, 2024 at 8:45 AM
    #678
    TomC843
    Tom
    Charleston, SC
    Water tower / cooling tower
    Mater and FrenchToasty[QUOTED] like this.
  19. Dec 13, 2024 at 5:13 PM
    #679
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    The angle makes it look so large... :rofl:
    You're welcome people...
  20. Dec 13, 2024 at 5:15 PM
    #680
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
  21. Dec 13, 2024 at 5:27 PM
    #681
    TacomaTRD4x402
    Southern California
    Oh but it is very large...
    Just realized you were referring to the stubby. D'oh! :facepalm:sorry I'm slow :smack:
  22. Dec 13, 2024 at 5:43 PM
    #682
    Tripleconpanna
    This doesn't help you right now, but I believe I grabbed mine on a doorbuster for $189 (free tool) w/charger and battery purchase....
    This is the online sku for the deal... 322135293
    ...but it's showing like $430 now.
    The in-store sku is... 1009472915
    Keep an eye out on the Special Buy 'Deal of the Day' to see if it pops back up again :thumbsup:
  23. Dec 13, 2024 at 5:45 PM
    #683
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    so your total with the battery was how much ? I go to HOME DEPOT quite a bit but how do you find out about DEAL OF THE DAY ??
  24. Dec 13, 2024 at 5:48 PM
    #684
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Sign up for it.
  25. Dec 13, 2024 at 5:50 PM
    #685
    Tripleconpanna
    https://www.homedepot.com/SpecialBuy/SpecialBuyOfTheDay
    Yeah, I went back and checked my order...
    It was on the 29th of Nov (so it was a BF doorbuster), and I paid $189 for the 'charger and a 5ah battery starter pack' and got a tool for free.... One of the options was the 1/2" mid-torque brushless impact!! Screaming deal I couldn't pass up :thumbsup:
    Don't know if you'll see it that cheap again, but check periodically on the deal of the day and also on the $199 $299 starter packs w/'free tool' to see if it cycles back into play again during the holidays!
  26. Dec 14, 2024 at 2:26 AM
    #686
    Leo's first
    Groton ma
  27. Dec 14, 2024 at 5:55 AM
    #687
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    @Leo's first I was headed here to post that. I've really enjoyed mine.
    Leo's first and Tripleconpanna like this.
  28. Dec 14, 2024 at 6:10 AM
    #688
    Tripleconpanna
  29. Dec 14, 2024 at 6:17 AM
    #689
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Thanks guys !! do you guys normally get the extended warranty ? I normally don't
  30. Dec 14, 2024 at 6:25 AM
    #690
    Tripleconpanna
    No
    OldGuy03 and Leo's first like this.
