Anyone else have a minivan a the app?
Discussion in '3rd Gen Tundras (2022+)' started by CrayCray, Dec 12, 2024.
  1. Dec 12, 2024 at 8:37 PM
    CrayCray
    CrayCray [OP] New Member
    WA State
    2024 Platinum 6.5
    My app shows a minivan instead of a Tundra on some of the screens. Anyone else have this “problem“?
    Tundrastruck91 likes this.
  2. Dec 12, 2024 at 8:45 PM
    Linesman
    Linesman New Member
    2023 Smoke Mesquite Tundra Double Cab limited
    Mine too
    CrayCray[OP] likes this.
  3. Dec 12, 2024 at 8:54 PM
    onehundredLL
    onehundredLL New Member
    2025 Tundra Limited
    they'll get a correctly represented vehicle in your app for $5/mo. color correct for $15/mo.
    :hattip:
  4. Dec 12, 2024 at 9:03 PM
  5. Dec 12, 2024 at 9:06 PM
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    Yep for status and health it’s a white minivan
  6. Dec 12, 2024 at 9:23 PM
    Pine_Cone67
    Pine_Cone67 New Member
    2024 Tundra Limited
    Wow, I’ve never noticed this, until just now.
  7. Dec 12, 2024 at 11:20 PM
    CrayCray
    WA State
    2024 Platinum 6.5
  8. Dec 13, 2024 at 7:01 AM
    jtweezy
    jtweezy New Member
    Jeffrey
    I thought it was a Tundra with a color matched cap on the bed.
  9. Dec 13, 2024 at 7:27 AM
    Tundra family
    Tundra family New Member
    At least it isn't a Prius
    drewpweinerMD and CrayCray[OP] like this.
  10. Dec 13, 2024 at 7:31 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  11. Dec 13, 2024 at 7:42 AM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    Well, if it makes you feel any better (and doubtful that it does), I'm pretty sure that's a Highlander. It's not only odd that they are using the Highlander in this view, but they are using the OLD, previous gen Highlander. Below is a 2019 Highlander (first one, without sunroof), and the second is the Sienna. Oh, and by the way, I have the same view on my app for my 2.5 gen.
    CrayCray[OP] and GODZILLA like this.
  12. Dec 13, 2024 at 7:44 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    First world problems..:sadviolin:
    389 24/7 and CrayCray[OP] like this.
  13. Dec 13, 2024 at 7:44 AM
    18" TRD Off Road Wheels
    I was going to point out that the rear door handles were wrong for a minivan. Glad I'm not the only one who noticed the differences.
  14. Dec 13, 2024 at 7:45 AM
    Yup. Just like threads not being something you'd post or like to read.
  15. Dec 13, 2024 at 8:05 AM
    jtweezy
    jtweezy New Member
    Jeffrey
    There is probably an issue in a bug tracker somewhere with a very, very low priority to make the vehicle image match the vehicle profile. They have the right image for the info/home page of the app, so it's not a matter of "can't".
  16. Dec 13, 2024 at 8:54 AM
    CrayCray
    WA State
    2024 Platinum 6.5
    Is that too much? KO2s with max psi of 80.:oops:
  17. Dec 13, 2024 at 8:57 AM
    CrayCray
    WA State
    2024 Platinum 6.5
    Agreed
  18. Dec 13, 2024 at 11:07 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Here is a shot from another app.
    Shows the truck bed but doesn't show the tow mirrors!
    @eddiefromcali check out these cold tire pressures! ;)
    CrayCray[OP] and eddiefromcali like this.
  19. Dec 13, 2024 at 11:10 AM
    eddiefromcali
    Eddie
    100% Stock
    big rig pressures.
    woods and PBNB like this.
  20. Dec 13, 2024 at 12:52 PM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    Let’s just say she must be a firm ride. I did the chalk test and 37 seemed to be the right spot. Due to cold weather they are at 35 right now.
    I choose to identify as a Porsche Cayenne in my app.
    woods and CrayCray[QUOTED][OP] like this.
  21. Dec 14, 2024 at 1:38 AM
    CrayCray
    WA State
    2024 Platinum 6.5
    She does ride firm but I like it that way. Was trying to achieve a decent MPG after installing the 35”s, but the last 3 tanks are indicating 13-14. I guess it’s a little higher when you adjust for the increased tire circumference. Maybe I’ll bump them down to 40 psi because it doesn’t seem like I’m gonna get decent gas mileage in this rig no matter what I do.
    Tundra family likes this.
  22. Dec 14, 2024 at 7:10 AM
    389 24/7 125k on the gen3
    Oregona
    2022 TRD OR
    Nada
    It's makes me wonder if anyone checks their work/uses it themselves before calling it 'done' in our modern day & age
    So many things on the gen3 tundra fall into this category
    It's a good truck tho
    I've got 116k on my 2022
    & enjoyed every mile
    Definitely a 1st world problem
    Hehehe
  23. Dec 14, 2024 at 7:14 AM
    Oregona
    2022 TRD OR
    Nada
    OP-
    I run my tires at 30-35 psi
    It easily get 20 mpg
    but I'm running the factory tire size
  24. Dec 14, 2024 at 8:55 AM
    CrayCray
    WA State
    2024 Platinum 6.5
    I’ve never sniffed 15…never. Maybe my motor’s about to blow.
  25. Dec 14, 2024 at 8:58 AM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    Shows in advance what you’ll get as a loaner when your truck is in for its new motor.
  26. Dec 14, 2024 at 8:59 AM
    CrayCray
    WA State
    2024 Platinum 6.5
  27. Dec 14, 2024 at 9:13 AM
    Tundra family
    My V8 with a 1600# camper loaded in it is getting 13.8, id have questions.
    CrayCray[QUOTED][OP] likes this.
  28. Dec 14, 2024 at 9:21 AM
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    Nope. They are "our world" problems!! :D
  29. Dec 14, 2024 at 9:23 AM
    gdisarray
    They definitely don't think about what the customer would want. They have in their mind the way it should be and that is what they implement.
  30. Dec 14, 2024 at 10:09 AM
    CrayCray
    WA State
    2024 Platinum 6.5
    I’ve learned to stop questioning this vehicle and just drive it.
    Tundra family[QUOTED] likes this.
