Simple interior light upgrade
Discussion in '3rd Gen Tundras (2022+)' started by grnwdjsn, Dec 10, 2024.
  1. Dec 10, 2024 at 12:05 PM
    grnwdjsn
    grnwdjsn [OP] New Member
    2023 Tundra Limited TRD Offroad
    I was getting tired of using my phone or a head lamp to see anything inside my console, so I added these simple LED lights to the sunglass holder. It works great and I am still able to keep shades in there. Got the LEDs on Amazon and picked up an AOB switch. The LEDs are .4 amps each so it was simple to tap the existing wires on the dummy switch. Under $50
    https://www.amazon.com/gp/product/B01ADHUXGU?ie=UTF8
    https://www.aironboard.com/online/p...50s-rav4-camry-hiace-corolla-led-in-blue.html
  2. Dec 10, 2024 at 2:23 PM
    SDT-Online
    SDT-Online New Member
    2024 Tundra Platinum (Red)
    Brilliant solution to a frustrating problem.
  3. Dec 10, 2024 at 4:56 PM
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    Have you noticed any change to your key fob reception to the truck? I read recently that the meso customs units makes the key fob range decrease dramatically, possibly due to unshielded LEDs? Just curious if these lights had any effect on your range?
    kirkb likes this.
  4. Dec 10, 2024 at 5:05 PM
    CringyDad
    CringyDad New Member
    Scott
    Fresno, CA
    2024 Tundra 1794 TRD (blueprint/saddle tan)
    Nothing.
    Totally unrelated to this was a similar issue I had with my garage door openers. I installed 100w equivalent LED bulbs in them and found that I could open (or close) the door via HomeLink sometimes, and it would not work at all other times. The wired controller worked flawlessly. After hours of frustration, I realized that if the lights timed out and turned off, the remote worked but when the lights were on, it did not. Went back to CFLs and no more issues. LED interference is no joke.
  5. Dec 10, 2024 at 5:11 PM
    Hella Krusty
    Hella Krusty New Member
    I have to ask what this frustrating problem is?
  6. Dec 10, 2024 at 6:05 PM
    SDT-Online
    Not near enough light in the cab. Toyota could have built in better lighting. .... old eyes, I guess.
    kirkb and PapaDave418 like this.
  7. Dec 10, 2024 at 6:34 PM
    Hella Krusty
    Maybe it's a trim thing. My 61 year old eyes are fine in my 22, but I have the ambient lighting which is more than sufficient to find the bottle opener
    Ipaddick and 1lowlife like this.
  8. Dec 10, 2024 at 6:38 PM
    bailey bulldog
    bailey bulldog New Member
    Same boat here too!
  9. Dec 10, 2024 at 6:42 PM
    99ways2die
    99ways2die New Member
    NJ
    2022 Tundra Platinum
    Tundrastruck91 and PapaDave418 like this.
  10. Dec 11, 2024 at 4:06 AM
    grnwdjsn
    I have not noticed it, but I have the lights hooked to ignition power so they only work if the key is already on.
    PapaDave418[QUOTED] likes this.
  11. Dec 11, 2024 at 5:14 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  12. Dec 11, 2024 at 5:26 AM
    grnwdjsn
    I looked hard at putting them in that spot on the overhead console, but it seemed like a real challenge getting it to come apart. The glasses holder was easy (and easily replaced if I messed it up).
    PapaDave418 and kirkb like this.
  13. Dec 11, 2024 at 8:15 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Good idea ...forgot there was even a 'sunglass dropdown holder' as I never used it even on previous rides.
  14. Dec 11, 2024 at 10:13 AM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    Nice install. Fyi, there’s no way these tiny LEDs pull .4A ea. Their spec sheet is wrong. 40mA is .04A ea
  15. Dec 11, 2024 at 1:18 PM
    grnwdjsn
    You are correct. My fat fingers....
  16. Dec 11, 2024 at 2:09 PM
    JohnF4x4
    JohnF4x4 New Member
    US
    2025 Platinum Windchill Pearl with AVS
    Of topic but 'll comment. Last month i installed two garage doors and also had concerns about it, buy al cheapo LED "Great Value" from Walmart work great, no interference and i open both doors from 40-50 yards away no mater of they on or off.
  17. Dec 12, 2024 at 8:19 PM
    mrlittlejohn
    mrlittlejohn New Member
    Michael
    2022 Toyota Tundra Limited
    Gonna read more of this when I get home. Cool ideas here for my 22 Limited.
