2010 Toyota tundra transsmission
Discussion in '2nd Gen Tundras (2007-2013)' started by Zake, Dec 12, 2024.
  1. Dec 12, 2024 at 11:14 AM
    Zake
    Zake [OP] New Member
    Had some codes for solenoids decided to drain oil change filter and check all coils for resistance all that checked out good. But I broke a filer mounting bolt the actually female thread broke of of valve body will I be ok with just three bolts fastened
  2. Dec 25, 2024 at 10:23 AM
    Tundrasam97
    Tundrasam97 New Member
    Sam
    Qc, Canada
    2010 black tundra SR5 DCSB 3ur-fe
    Bilstein 5100
    You made the mistake of mixing bolt length and bottoming out it in the hole. It broke off the mount… There is an oil passage behind that mount that you broke off. Sorry but your valve body is done.
    ColoradoTJ likes this.
  3. Dec 25, 2024 at 12:06 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's too bad. I can't see if there is an exhaust port near there, if there is you MAY be ok. But it might relieve too much.
    You can always chuck it back together and see how it operates.
    **separate the bolts so you don't mix them up**
