Suspension install tutorial for 2.5 Gen
Discussion in 'Suspension' started by flogrown, Dec 10, 2024.
  1. Dec 10, 2024 at 6:38 PM
    flogrown
    flogrown [OP] Ready up
    2020 Tundra SR5 CM 4x4
    Hey all. I just picked up 6112/5160's for my 2020 and I'm looking for someone to point me in the direction of good, step by step instructions on how to do the install. I'm pretty comfortable with a wrench but I earned my degree from YouTube university.
    I have never touched suspension before and would feel much more comfortable having something to follow along with. It can be written or a video.
    Appreciate it in advance!
    Sleeper16plat likes this.
  2. Dec 11, 2024 at 8:26 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    First, search here. Search box in upper right. There are threads with pics, details of installs.
    and or- search on youtube, im sure there is a vid out there of a Tundra coilover install.
  3. Dec 11, 2024 at 8:27 AM
    frichco228
    Frank
    Virginia
  4. Dec 11, 2024 at 10:22 AM
    flogrown
    I appreciate it. Sorry for not searching first. Rookie mistake.
  5. Dec 11, 2024 at 10:25 AM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    I recently changed out my front and rear shocks (stock OEM for Eibach Stage 2R's) as well as changing out the upper control arms (stock OEM for Dirt King UCA's). I did not change or add anything else.
    Like you, I had not done any type of suspension work on any vehicle. I did plenty of searching on this site (and got a lot of helpful information), and I also referenced Youtube for any visual walkthroughs.
    I found these videos very helpful in changing out the shocks and UCA's on my 2011 SR5 CM 4x4, which shouldn't be much, if any, different than yours.
    https://youtu.be/56bAcn4FmEg?si=e1yeLmEBvyg9G9-N
    https://youtu.be/6qtFQX7Xq2M?si=w5EWivX33GpeUojp
    https://youtu.be/oUpTxegQ89Y?si=glyV-83Il1JbUKWo
    Those videos show changing out stock parts for stock parts, so they don't address aftermarket lift configurations. But they should be useful in getting the concepts for working with getting the old parts uninstalled and getting the new parts installed.
    OHwendTrd, equin and flogrown[OP] like this.
  6. Dec 11, 2024 at 10:57 AM
    flogrown
    This is awesome. I'm doing UCAs as well so this is extremely helpful. Thanks.
    Thumper_6119[QUOTED] likes this.
  7. Dec 11, 2024 at 11:13 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    @Thumper_6119 sent you some good links. The particular suspension won't change "how" it's installed so it should be good there.
    Pretty sure you picked up your goodies from us here at Hotshot Offroad as well so we're always around if you need a lifeline :fistbump:
  8. Dec 11, 2024 at 11:45 AM
    flogrown
    I did indeed. You guys are the best. Hopefully I won't have to reach out but thanks for letting me know I can.
  9. Dec 31, 2024 at 7:11 PM
    SoJersey
    SoJersey New Member
    Invest in a torque wrench as well. I’m a big fan of torque’ing shit down to what it’s supposed to be set at.
    Thumper_6119 likes this.
  10. Feb 8, 2025 at 11:57 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    In the middle of installing JBA UCAs and having some trouble. Driver side was easy. But the passenger side is kicking my butt trying to install the long bolt into the new UCAs. I've already got it through the front UCA bushing all the way but can't seem to line it up into the rear bushing without the bolt hitting all the passenger side hoses (which also got in the way when removing that bolt but I was able to wiggle it out after a lot of effort). I've looked at install videos and tried searching on here for tips on the passenger side, but most videos show the driver side install and most threads on here say how easy the passenger side was. Those of you who've done the install, any tips on clearing all those hoses in that tight passenger side?
  11. Feb 9, 2025 at 3:32 PM
    equin
    Ed
    DFW, TX
    Finally got that bolt all the way in. I’m guessing some Tundras’ passenger side is easier and some harder, like mine was. Those hoses were a pain to work around in. Driver side was easy peasy for me, though.
