GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Nov 25, 2024 at 3:21 AM
    #5251
    ToroR9
    ToroR9 New Member
    2024 Limited Black
    I think is with the Stabilizer Bar, but I'm not sure. The tire it's almost touching the UCA. I will go to the shop that made the installation today, to get better information
  2. Nov 25, 2024 at 3:39 AM
    #5252
    shorenetworks
    shorenetworks New Member
    East coast California DBA New Jersey
    2023 Tundra self destruct edition
    18x7.5 I believe
  3. Nov 25, 2024 at 3:41 AM
    #5253
    ToroR9
    ToroR9 New Member
    2024 Limited Black
    18x8
  4. Nov 25, 2024 at 3:41 AM
    #5254
    ToroR9
    ToroR9 New Member
    2024 Limited Black
    Sorry. These wheels are 20x8
  5. Nov 25, 2024 at 8:35 AM
    #5255
    Savagesawyer
    Savagesawyer New Member
    Beaverton, OR
    Does anyone know if you can put different center caps on pro wheels?
  6. Nov 25, 2024 at 12:54 PM
    #5256
    rajlovermaster
    rajlovermaster New Member
    Jay
    I put 20 inch wheels on my SR5 and some used tires for now. I was waiting for thanksgiving.
    Want to know which tires I can fit without rubbing and lift.
    33*12.50 R 20
    Or 35 x 12.50 R20
  7. Nov 25, 2024 at 6:38 PM
    #5257
    Hoody
    Hoody Member
    Kommiefornia
    '23 Platinum 6.5 bed
    Looking to pull the trigger on wheels/tires before black Friday is over for my '23 Platinum 6.5 bed w/ TRD lift. For wheels I'm going with Method 316 18x9 +18 offset, 28 lbs. I'm pretty set on Toyo AT3 for tires. Used to be a BFG guy but they don't balance for shit and I'm over E load tires. I'm leaning towards Toyo AT3 in 35x12.5R18 (34.5") D load 66 lbs, but then I wondered if that's too heavy or wider than necessary and if 295/70 would be better. I've searched a ton but only found a handful of pics with 295's on a TRD lift and some look fine but others look a little small, even though it's only a 1/4" height difference. My main priority other than bigger tires is maintaining a smooth ride. Not overly concerned with MPG but also don't want to drop below 15 if possible, current avg is 17. I need a decent AT tire since I live in a rural area with snow, rain, dirt roads, and toy hauler camping; so not a street queen but not an overlander.
    Looking at:
    #1 Toyo AT3 in 35x12.5R18 (34.5") D load 66 lbs. (My instinct pick but maybe too heavy?)
    #2 Toyo AT3 in 295/70R18 E load 63 lbs. (Tad lighter than 35s but stiffer E load)
    #3 Nitto Recons 295/70R18 Standard Load 53 lbs. (Super light but 3/32" less tread depth and reportedly not as good wet traction)
    Just looking for any advice if you went with 35s or 295s for a certain reason, any regrets, etc. Thanks in advance. Talk me out of 35s...if you can.
  8. Nov 26, 2024 at 11:20 AM
    #5258
    shorenetworks
    Installed but the jury is out for are Land Cruiser TPMS sensors compatible or not... or are they in the wheels at all?
    regardless here's a mandatory side pic
  9. Nov 26, 2024 at 11:24 AM
    #5259
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    Looks good. These wheels including my set just sit on the LC forum with no movement.
    Maybe I’ll list them here.
  10. Nov 28, 2024 at 2:53 PM
    #5260
    Duckinatruck
    Duckinatruck New Member
    Been scouring this thread for days now and can’t find what I’m specifically looking for. I have a 1 inch level and +18 offset, 9 inch wheels. Does anyone definitively know if I can fit 285/75R18 tires (likely Toyo AT3) without any clearance/rubbing issues on an SR5 4WD? I do not have mud flaps. Thanks.
  11. Nov 29, 2024 at 11:45 AM
    #5261
    cartage1
    cartage1 New Member
    Ohio
    2023 TRD Pro
    Thank you Tundras.com Nation!! Cannot find the darn post, but someone (likely multiple folks) noted that a 295/70r18 would fit a TRD Pro without modification. Was torn between that and a 35x12.5., but went with the 295 in Nitto Trail Grappler. Really close, but no rubbing at full lock, reverse, bumps, etc... Damn better look for sure!! Heavy and noisy.., and bad ass (at least for stock set up). Thanks gang, happy Holidays.
    Inner fender Pic is tough to judge.., it is close, but that shot makes it look tighter than it is.
  12. Nov 30, 2024 at 1:59 PM
    #5262
    nimbus
    nimbus New Member
    2022 Limited stock suspension. No lift. I was going with 35/11.5/20, but Discount tire did not have them in stock but had 295/65/20 in stock. I wasn't sure if they would fit. The guy said, we'll put one on check for rubbing and if it does quite a bit put yours back on and order the 35s. He called and said it fit well, very slight rub at full lock. But only on mud flaps, so I had them installed and removed mud flaps when I got home. Nitto Recon Grappler 295/65/20
  13. Dec 4, 2024 at 8:55 AM
    #5263
    dolooper
    dolooper New Member
    2025 SR5 TRD
    2025 SR5. Looked at several options, including the Falken Wildpeak, Toyo, and BFG K-Bros. Got the K-Bro 3s, ultimately. Upped from the kind of weird stock size to 275/70/18.
  14. Dec 4, 2024 at 6:18 PM
    #5264
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    37s for sure won't fit without some trimming up front. Even the rear is very tight without trimming. Will have to get another angle
  15. Dec 4, 2024 at 11:47 PM
    #5265
    rfoskett
    rfoskett New Member
    rob
    2023 TRD limited tooyota Tundra
    Stock as of now
    A basics question that i have some how not been able to find. I know tGoodrich is rolling various tries sizes with the AT K03 over-the next year but wanted to see what folks have done so far with the K03 that are available. I have 2023 Tundra TRD Limited stock suspension. and basic OEM 265,60,20 wildpeak tire from delaer that need to be replaced. What have folks done if they want the KO3. Is the AT KO3 available in 275/65/20? or just 285/65/20. I don't really want to spend the money on a mod it out but do believe it might be worth the waiting for correct K03 Sizes. Any help is much appreciated from all perspective.
  16. Dec 5, 2024 at 6:53 AM
    #5266
    mikev25
    mikev25 New Member
    Kansas
    2022 MGM SR5
    TRD lift, wheels, tires, AlphaRex headlights
    Yes, you can get it in 275/65 now.
  17. Dec 5, 2024 at 7:30 AM
    #5267
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    Question for those in snow season parts of the world...do you swap out your wheels/tires to the stock wheels for the winter? Not sure I want my wheels getting salt and whatever else they spray all over the road on them.
  18. Dec 6, 2024 at 12:35 PM
    #5268
    Savagesawyer
    Beaverton, OR
    Anyone have the part number for the black lugs? Or can I grab any black M14x15 off Amazon?
  19. Dec 7, 2024 at 7:38 PM
    #5269
    DJTHEMAC
    DJTHEMAC New Member
    Just got my first Tundra 25 limited OR and got a 1.75 lift installed with TOYO OC at3s 285/65/20 on the stock rims. Really happy with the results. I might go bigger when the oem lift fiasco gets resolved but I’m really stoked with what I have now
  20. Dec 8, 2024 at 5:57 AM
    #5270
    MAC25Tundra
    MAC25Tundra New Member
    2025 Limited Crew Max 4x4
    I put 285/60r20 KO3 tires on my 2025 Limited 4x4 one week after purchase. Love everything about the tire, the look and the ride. They fit without rubbing on the mudflaps on a bone stock suspension.
    AstroTRD, ToyoJon, VT-ISE and 4 others like this.
  21. Dec 9, 2024 at 1:11 PM
    #5271
    jachal
    jachal jachallen
    andy
    FLX NY
    2023 Black Platinum Hybrid
    can u elaborate what u mean by ‘oem lift fiasco’ thx
  22. Dec 9, 2024 at 5:15 PM
    #5272
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    DJTHEMAC and jachal[QUOTED] like this.
  23. Dec 9, 2024 at 7:12 PM
    #5273
    jachal
    jachal jachallen
    andy
    FLX NY
    oh yeah remember hearing about that now, about the tool that was discontinued or something. sucks..
    lift is great. might pop in some elkas tho. keep yall posted
    sbk504, AstroTRD, ytank1 and 3 others like this.
  24. Dec 10, 2024 at 4:05 PM
    #5274
    _yabai_
    _yabai_ New Member
    Thanks to the posters before me, hope this helps someone!
    @SCSPerformance Blaze 10 17x8.5 +20 (~22lbs)
    Falken Wildpeak A/T4W P285/70R17 SL 116T (53.4lbs)
    2024 Platinum stock suspension, no rubbing, maybe 1/2 inch clearance at full.
  25. Dec 10, 2024 at 4:19 PM
    #5275
    Crawldad
    Crawldad New Member
    2024 Tundra Limited TRD OR w/3” Lift
    Nice light setup, your only about 3.4lbs over stock.
    I went a litter bigger/heavier to fill the wheel wells with a 3” lift.
    SCS Blaze10 Gloss Gunmetal 17x8.5 +20 offset 22lbs
    BFG KO2 E Rated 315/70R17 64lbs
  26. Dec 11, 2024 at 11:44 AM
    #5276
    Savagesawyer
    Beaverton, OR
    Anyone know the center cap specs and if there are any aftermarket caps that will fit 3rd gen OEM wheels?
  27. Dec 11, 2024 at 2:08 PM
    #5277
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    I believe they are 84mm in diameter. The Toyota ones at least.
  28. Dec 12, 2024 at 8:26 AM
    #5278
    vichmr
    vichmr New Member
    Scott
    Suwanee, GA & Highlands, NC
    '25 MGM Platinum TRD OR 6.5 w/ factory lift
    Go Rhino Dominator D6, Diamondback HD
    It looks fantastic! I'd like to know the details of the mods - wheels, tires, sizes, lifted, etc.
  29. Dec 12, 2024 at 8:49 AM
    #5279
    Savagesawyer
    Beaverton, OR
    Same. I'm putting you in charge of a reverse image search!
  30. Dec 14, 2024 at 8:47 AM
    #5280
    jachal
    jachal jachallen
    andy
    FLX NY
