OVRLND Camper/Tundra Thread
Discussion in 'General Tundra Discussion' started by sea_weathered, Dec 10, 2024.
  1. Dec 10, 2024 at 2:36 AM
    sea_weathered
    sea_weathered [OP] New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
    I searched this group for an OVRLND Camper thread, but only came up with individual builds. Hopefully this can become a collective for OVRLND Camper enthusiasts.
    Here’s a few photos of ours. After a year of planning and preparation we picked ours up in early June 2024
    https://youtu.be/VxGAzoMczUQ
    IMG_4832.jpg IMG_4836.jpg IMG_4529.jpg IMG_4525.jpg IMG_3767.jpg IMG_4169.jpg
    Wallygator, ATV25, TheBeast and 13 others like this.
  2. Dec 10, 2024 at 2:41 AM
    sea_weathered
    Pacific Ocean
  3. Dec 10, 2024 at 5:17 AM
    Tundra family
    Tundra family New Member
    I have a genuine question for the overland/boondocks/dry camp folks....
    What do you use when you poo? Are y'all just doing it up ol school with :bucket:
    Mater and Florida AF like this.
  4. Dec 10, 2024 at 5:45 AM
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    Here is ours, we picked it up at the end of July and built it out. The OVRLND campers are very well made and the company is very flexible with custom requests.
    PXL_20241208_185538102.PORTRAIT.ORIGINAL.jpg PXL_20241128_182554376.PORTRAIT.ORIGINAL.jpg PXL_20241125_231244382.PORTRAIT.jpg PXL_20241125_231228626.jpg PXL_20240916_175555495.PORTRAIT.jpg PXL_20240813_230629948.PORTRAIT.jpg
    Wallygator, ATV25, TheBeast and 14 others like this.
  5. Dec 10, 2024 at 5:46 AM
    STravis
    Travis
    Ruidoso, NM
    I watched that video of your build the other day, you have an awesome setup.
  6. Dec 10, 2024 at 6:24 AM
    Florida AF
    Logan
    North Florida
    I have done compost toilets, holes and bags; depending on the location/rules and access. I have also just time it with stops and adjusted my diet to support. Of course, this was easier when single.
    Tundra family[QUOTED] likes this.
  7. Dec 10, 2024 at 6:31 AM
    Tundra family
    Don't wanna be that guy, think I'd get any answers if I asked this in it's own thread?
    Mater likes this.
  8. Dec 10, 2024 at 6:48 AM
    Florida AF
    Logan
    North Florida
    I honestly dont know why, unless folks have seen and just dont have an answer at the moment. I know some campers who wont answer because they do not look up local laws first and just go with the OG way, which includes a shovel and a hole. So they wont risk saying anything when they post where they go.
    Compost toilets are the easiest way to check all the boxes for this one. And not the worst when it comes to clean up.
  9. Dec 10, 2024 at 7:06 AM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    Similar to what @Florida AF is saying but there is a product called Bio-Gel made by Reliance that you add to any waste within a bag to help solidify and mask odors to prep it when you throw it away. Only reason I'm mentioning it is that it can be used for more than just composting toilets.
    Florida AF likes this.
  10. Dec 10, 2024 at 7:23 AM
    sea_weathered
    Pacific Ocean
    We go find a spot in the woods whenever possible. When that isn’t possible, we have a Trelino toilet IMG_4235.jpg
  11. Dec 10, 2024 at 7:26 AM
    sea_weathered
    Pacific Ocean
    Thank you! It was quite the endeavor to build.
    STravis[QUOTED] likes this.
  12. Dec 10, 2024 at 7:31 AM
    scarecrow87
    scarecrow87 New Member
    Shane
    Silver 2023 Tundra SR5 TRD
    Link to the video please?
  13. Dec 10, 2024 at 7:39 AM
    sea_weathered
    Pacific Ocean
    I started out with 400w (2x200w)of rigid solar panels on the roof, wired in series. The weight of the rigid panels was always a little challenging when raising and lowering the top, plus I was less than thrilled with the partial shade performance of the panels wired in series. It seemed more often than not one of the panels was partially shaded. So I swapped them out for (4x100w) flexible panels from Lensun, and wired them in a series/parallel configuration. This seems a to be a little better for performance, plus they weigh significantly less and are a lot more aerodynamic! IMG_4217.jpg
  14. Dec 10, 2024 at 7:41 AM
    sea_weathered
    Pacific Ocean
  15. Dec 10, 2024 at 7:47 AM
    Tundra family
    When you did the panel swap was it as easy as just connecting current wiring to the new panels? I have a heavy panel and it's affecting my lift system pretty dramatically, but I'm an electrical idiot and don't wanna hafta wire anything again.
    Mater likes this.
  16. Dec 10, 2024 at 7:59 AM
    sea_weathered
    Pacific Ocean
    Based on the number of panels you have, the number of panels you want to get, and what wiring configuration you want to run, you just need the right components and it’s all plug and play. These options are usually based on your available space and charger capacity. I went with these 100w Lensun panels because two of them fit side by side between my roof rails, and my 50amp charger could handle 400w of solar any ol way I wanted to configure it
  17. Dec 10, 2024 at 8:07 AM
    g6t9ed
    Is this your first time using Lensun? I ask because I have their hood panel and I don't know if I installed it incorrectly or if their quality isn't up to snuff for the amount of curve the hood requires. The issue I'm having is that the edges are delaminating and I've tried getting them to seal again by using silicone caulking but the issue reappears.
  18. Dec 10, 2024 at 8:16 AM
    sea_weathered
    Pacific Ocean
    I have heard from others with this problem, but haven’t seen any signs of delamination yet myself. I’m hoping that they resolved whatever was causing the issue. Do you think the additional heat coming from your vehicles engine accelerated the problem?
    Mater and g6t9ed[QUOTED] like this.
  19. Dec 10, 2024 at 8:22 AM
    g6t9ed
    I had that thought as well but in my "research" I haven't ran across a widespread problem of this. Of course, not too many people would purchase such a niche product, so the info is slim pickings. I, personally, do not think the heat is an issue as it only reoccurs in particular spots and not across the entire edge. I park outside in the Texas heat, so I would think the entire edge would be susceptible to the issue and not just recurring areas but who knows. I know there's the more expensive Cascadia version and I haven't heard of any issues with theirs, so that's another reason why I was leaning more towards quality and not area of application.
    Edit: Just want to add clarification that I do think the added heat with the engine would degrade the lifespan of the solar cells but I'm speaking specifically as to why I don't think it pertains to my particular delamination at spots along the edge of the panel.
  20. Dec 10, 2024 at 10:18 AM
    Tundra family
    Just trying to swap this for something lighter. It's a 200W system that Im running to a trickle charger.
    Hope it's as easy as disconnecting the output and using what I already have with a new panel
    Wallygator and Florida AF like this.
  21. Dec 10, 2024 at 10:24 AM
    sea_weathered
    Pacific Ocean
    If you go with the same wattage panels and the same wiring configuration it should be a simple plug and play. PM me if you want more help looking at connections and determining what panels to go with
    g6t9ed and Tundra family[QUOTED] like this.
  22. Dec 10, 2024 at 10:26 AM
    Tundra family
    Thank you for all the help, like I said, I'm a dummy and was worried about causing more problems than solving.
  23. Dec 10, 2024 at 10:36 AM
    sea_weathered
    Pacific Ocean
    I spoke on the phone with Calvin (I think that’s his name) with Alcan suspension, about picking up a custom leaf pack for supporting the rear of my truck better. I’m currently running an Icon RXT multi-rate leaf pack in the heaviest configuration, and a set of Sumostop bumps, but it isn’t quite enough for my estimated 1200lbs of camper all loaded up. I’ll be in the Grand Junction area in July and plan to have him do the initial.
    Wallygator and Tundra family like this.
  24. Dec 10, 2024 at 10:39 AM
    STravis
    Travis
    Ruidoso, NM
    Alcan springs are great. I had them build me a set a couple years ago and they were exactly what I needed and they are holding up very well.
  25. Dec 10, 2024 at 10:51 AM
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    I haven't installed my Total Chaos engine mounts but when I do, I'm sure the truck will feel and preform a bit different.
    sea_weathered[OP] likes this.
  26. Dec 10, 2024 at 11:00 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    In North Maine Woods the first step is to find a spot clean of moose/deer/bear poo... I don't see how another animal's poo is any different.
  27. Dec 10, 2024 at 11:02 AM
    sea_weathered
    Pacific Ocean
    What front suspension setup do you have? Your ride height is perfect!
  28. Dec 10, 2024 at 11:33 AM
    STravis
    Travis
    Ruidoso, NM
    I'm running ADS 3.0 coilovers and MCM uca's.
  29. Dec 10, 2024 at 11:33 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    My setup is pretty basic... I still use truck for truck duties, so can't do anything fancy with the bed, other than installing a Leer cap. And roof rack. Overlanding activities usually end up in winter offroading and/or white water exploration or hiking/hunting w/ backpack. Just driving is a bit boring, after years of doing the driving part only.
    Can sleep up to two adults: one in the DC cab, another in bed. Truck has ~1.5"-2" of lift which is eaten down to less than stock height by steel skids, bumper, winch, cap and rack. Need to do something about it, would love to have a bit more of ground clearance when loaded up for trip. Camping gear setup is pretty basic, but I do have a 68 qt fridge powered by the secondary battery. So, steaks, salads and cold beer and other camping excesses now.
    The next mod is a diesel heater :)
    Wallygator, ATV25, Florida AF and 3 others like this.
  30. Dec 10, 2024 at 12:13 PM
    sea_weathered
    Pacific Ocean
    Stock LCAs, Stock spindles, and no drop bracket?
    What do you estimate your total lift to be?
