2017 Toyota Tundra Crew Max SR5 4x4 - Gen 2 - CRITIQUE MY SUSPENSION PLAN
Discussion in 'Suspension' started by jayhawknavy02, Dec 10, 2024.
  1. Dec 10, 2024 at 2:02 AM
    jayhawknavy02
    jayhawknavy02 [OP] New Member
    SOCAL
    2017 Tundra 5.7L SR5 Crew Max TRD Off Road 4x4
    Dirty Deeds 10” exhaust TRD Accelerator OTT Tune Sony XAV-9000ES Head Unit AJT Interior Upgrades
    Team,
    I'm not a suspension guy, so this is my first attempt at what I think I might "need" (or at least do at some point) to make sure my Tundra is properly setup and able to utilize 35" tires without zero issues after a 3" lift based on reading the forums, YouTube and a ton of talking to Toyota club folks in SoCal. Doing this myself with help from friends, including a welder so I have good support. No personal experience or knowledge, and appreciate the help of the Team to sanity check what I've come up with (who knows - it may be garbage). Not sure however what is a want, vs need, or what I can delay or do later as smaller projects (if required).
    I don't think I'll go to 37s (or at least not for a long time) unless I get a second car, but who knows. I take the Tundra off-road, when I can, mostly overland now. I don't tow very often or have a camper (yet), but would like to get a pull behind at some point in the future, nothing huge, just for the wife, me and dog.
    There are multiples of some items indicated with an "Or", which is where I wasn't sure what the best/ideal choice is, and appreciate any help/advice.
    If I'm missing something please let me know, and conversely, if it’s not required, appreciate the heads up.
    Thanks in advance and hopefully I got close. What I haven't done (yet) is work on a phasing/build plan - that TBD based on the feedback.
    SUSPENSION
    FOX PERFORMANCE ELITE 2.5 COIL-OVER RESERVOIR SHOCKS - FRONT (3")
    FOX PERFORMANCE ELITE 2.5 COIL-OVER RESERVOIR SHOCKS HYPERLINK
    FOX PERFORMANCE ELITE 2.5 RESERVOIR SHOCKS - REAR (2" - 3")
    FOX PERFORMANCE ELITE 2.5 RESERVOIR SHOCKS- HYPERLINK
    JBA HD HC Upper Control Arms (UCA) - 1 to 3.5” lift
    JBA HD HC Upper Control Arms for 1 - 3.5” lift
    Perry Parts AB3F Front Bump Stops
    Perry Parts AB3F Front Bump Stops - Hyperlink
    Total Chaos Weld-On Spindle Gussets
    TOTAL CHAOS Spindle Gussets Hyperlink
    DRT Fabrication Cab Mount Relocation
    DRT Cab Mount Relocation Hyperlink
    Perry Parts AB3R Rear Bump Stops
    Perry Parts Rear Bump Stops Hyperlink
    CoachBuilder +2" Shackle Kit
    CoachBuilder +2" Shackle Kit Hyperlink
    Deaver 3 Leaf Overload Replacement 1 1/2" Lift (Pair)
    Deaver 3 Leaf Overload Replacement 1 1/2" Lift (Pair) Hyperlink
    DOBINSONS REAR U-BOLTS (UB59-437K)
    Dobinsons Rear U-Bolts UB59-437K - HYPERLINK
    DRIVETRAIN
    CVJ AXLE SET 95501TR
    CVJ Axles 95501 TR - HYPERLINK
    NOTE: Only if required to maintain proper geometry
    RCV ULTIMATE IFS CV AXLE SET
    RCV Ultimate IFS CV Axle Set - Hyperlink
    NOTE: Only if unable to maintain proper geometry with CVJ axle set
    COACHBUILDER CARRIER BEARING DROP KIT (REAR LIFT 3”-4”)
    COACHBUILDER CARRIER BRG DROP KIT Hyperlink
    Coachbuilder 4WD Differential Drop Kit (1")
    CoachBuilder Differential Drop Kit (1") - HYPERLINK
    COACHBUILDER REAR DRIVELINE SPACER (10.5” REAR AXLE)
    Coachbuilder Spacer 10.5” Rear .75” HYPERLINK
    Yukon Ring & Pinion Gear Package (5.29) (YGKT001-529) (F 9"/R 10.5")
    Yukon Ring & Pinion 5.29 Gear Package Hyperlink
    BRAKES
    Old Man Emu Brake Line and ABS Wire Relocation Kit (FK32)
    SDHQ 6 PIECE BRAIDED BRAKE LINE KIT
    SDHQ 6 PIECE BRAKE LINE KIT Hyperlink
    STEERING
    COACHBUILDER REPLACEMENT STEERING KIT
    Coachbuilder Steering Kit HYPERLINK
    COACHBUILDER POWER STEERING RACK POLY BUSHING KIT
    COACHBUILDER STEERING BUSHING HYPERLINK
    Total Chaos Lower Control Arm CAM TAB WELD-ON REINFORCEMENTS (PART 59870)
    Total Chaos CAM TAB REINFORCEMENT Hyperlink
    EXTERIOR
    RCI Arapaho Front Bumper
    RCI Arapaho Front Bumper Hyperlink
    RCI Engine Skid Plate
    RCI Metal Works Engine Skid Plate Hyperlink
    ARK - TriXpoly Splash Guards & Mudflap Micros
    TriXpoly Splash Guards & Mudflap Hyperlink
    Cali Raised TRAIL EDITION ROCK SLIDERS
    Cali TRAIL EDITION ROCK SLIDERs Hyperlink
    CoachBuilder Front Bumper Shim Kit
    CoachBuilder Front Bumper Shim Kit Hyperlink
    SS Built Tundra Bed Stiffeners
    SS Built Tundra Bed Stiffeners Hyperlink
    Fab Fours Vengeance (Sensor) Rear Bumper (TT14-E2852-1)
    Fab Fours Vengeance Rear Bumper Hyperlink
    WHEELS
    Method Race Wheels 313
    17"x8.5" / +25mm Offset / 5.8" Backspace / 24.7 lbs
    Method Race Wheels 313 Hyperlink
    Or
    ICON Vehicle Dynamics Rebound SLX
    17"x8.5" / +25mm Offset / 5.75" Backspace / 31 lbs
    Icon Rebound - Titanium Wheels Hyperlink
    Or
    Stealth Custom Wheels Ray10
    17" x 9.0" / +25mm Offset / 6.00" Backspace / 24.5 lbs
    Note 8: Method 313 DISCONTINUED
    Gorilla Auto Small Diameter Spline Duplex E-T Lug Nuts - 13/16" & 7/8" - 14x1.50mm (K5ES-14150BGR)
    Gorilla Small Diameter Spline Duplex E-T Lug Nuts - 14x1.50 Hyperlink
    FearRLess Longer Wheel Studs 14x1.5 - 1.85" Thread Length
    Longer Wheel Studs 14x1.50 Hyperlink
    Or
    Wheeler's Off-Road - 8 Extended Length 2" Top Plate Stud Set (WOR-TP-STUD-X8) Or
    Kyo-Ei Hub Bolt M14x1.5
    KYO-EI HUB BOLT M14xP1.5 SBLC - Black Hawk Japan
    TIRES
    Toyo Open Country A/T III - 35x11.5/R17LT - 63 lbs - $368
    Toyo Open Country A/T III Hyperlink
    Or
    BF GOODRICH ALL-TERRAIN T/A KO - 35x12.5/17LT - 63 lbs - $376
    Or
    COOPER DISCOVERER AT3 XLT - LT315x70/R17LT - 64 lbs - $219
    Or
    FIRESTONE DESTINATION X/T - 35x12.5/R17LT - 60 lbs - $354
    rruff likes this.
  2. Dec 10, 2024 at 4:31 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Why you need bed stiffeners? C-channel frame is specially done for better suspension articulation and better wheels contact with pavement. Add stiffeners and you have a great stress point that is not intended to be there. If you want better cornering - add a rear sway bar. For offroading leave it alone, let it articulate.
    There's exactly zero ground clearance practical difference between 34.x" and 35". If you have 34.x" already then it is as good as it will be with 35". I run on 33", because 1" in my offroading conditions (deep snow) does not do anything besides looks, and 33" are good 30% cheaper than 35".
    Every inch to suspension lift adds considerably more to turning radius. Think twice. Every inch is a higher center of mass, think twice. Most of cheaper suspension mods don't do good for articulation, this is the opposite of what you want away from pavement. Stock suspension parts are beefy, you sure then intended upgrade parts are as reliable? Blow something on a rock, now what?
    No steel front bumper, no winch? This is actually what you find useful when offroading. Also must have steel skids plates all the way to transfer case. And steel skid for the gas tank. Hi-lift jack or any other that will raise the truck in air out in the field. Automotive set of tools for elementary repairs when you break your truck. A full size spare wheel. All fluids replaced regularly, in much shorter intervals. A tablet with diagnostic software and repair manuals.
  3. Dec 10, 2024 at 4:54 AM
    jayhawknavy02
    SOCAL
    Iis this a joke, or for real?
    Vizsla and JrJrOffroad like this.
  4. Dec 10, 2024 at 5:14 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    What exactly?
  5. Dec 10, 2024 at 5:21 AM
    JrJrOffroad
    JrJrOffroad Somewhere in the west
    Anthony
    Monument, CO // Cave Creek, AZ
    lol I’ve had that guy muted for ages. One of my better decisions in 2024.
    hit up @memario1214 and he will get you fully dialed in on suspension. Dude is a wealth of knowledge and has great pricing/customer service.
  6. Dec 10, 2024 at 5:27 AM
    JrJrOffroad
    Anthony
    Also for bed stiffeners, check out total chaos or R4T as well.
    Sliders comes down to preference. You cant go wrong with RCI, Wescott, SDHQ, or Cali Raised. Even C4- just pick which ones fit your needs (fab time, delivery cost, top or no top, angle). My wescott sliders are amazing and take abuse in moab with no problems at all.
    for bumpstops- I run perry parts. I highly recommend these- they have been a massive benefit at a low cost. I run all 4 up front in the bigger size (not the long travel).
    you don’t need the DRT BMR for 35’s. I cleared 35’s at full turn and full flex with just a body mount chop. I do have a DRT BMR now- but this was done for the upgrade to 37’s and was not needed for 35’s. A badass upgrade- just find a good welder.
    everything else- you are asking the right questions. Im just not educated enough on suspension to give you the right answers.
    Also- If you plan on wheeling the truck to any extent… your stock rear bumper is going to be a problem. To the point I would recommend looking into a high clearance rear bumper before a front. Depends on what sort of terrain you see.
    jayhawknavy02[OP] likes this.
  7. Dec 10, 2024 at 5:29 AM
    jayhawknavy02
    SOCAL
    thanks I just did the same.
    I’ll shoot memario1214 a note and appreciate the help
    JrJrOffroad[QUOTED] likes this.
  8. Dec 10, 2024 at 5:35 AM
    JrJrOffroad
    Anthony
    lol no prob. I added some more info to my reply but hopefully thats helpful.
  9. Dec 12, 2024 at 3:00 AM
    steezy
    steezy New Member
    2021 Tundra TRD Pro
    Unless you’re doing 60+ mph on whoops, I’d ditch the spindle reinforcements, bed stiffener, shock tower reinforcements, LCA reinforcements, etc…
    Not sure you’ll need to push the front bumper forward for 35s. My TRD Pro only rubbed on the aero flaps in front of my front tires.
    I wouldn’t touch the stock CVs until you have an issue.
    I’d pull the trigger on Fox parts, UCA, deavers, coachbuilder bushings & steering arm. (I’d also look at coachbuilders lift shackle vs the rest).
    Install all that + the protection you’re talkin about and I think you’ve got a bombproof trail rig.
  10. Dec 12, 2024 at 3:56 AM
    jayhawknavy02
    SOCAL
    heck yeah! Thank you, but what are “deavers”?
  11. Dec 12, 2024 at 4:39 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Leafy springies.
  12. Dec 12, 2024 at 7:33 AM
    mfelton18
    mfelton18 I'M THE PROBLEM
    South Central Texas
    2014 Magnetic grey SR5 4x4 crewmax
    Eibach Stage 2, RCI armor, Method 705
    NOTE 3: Need to verify that this is compatible with lowered differential
    NOTE 4: BDS Suspension Front Differential Drop Kit BDS128006 comes with skid plate spacers
    The RCI skids also come with a spacer for a lowered diff.
  13. Dec 13, 2024 at 5:25 PM
    jayhawknavy02
    SOCAL
    Thanks to everyone for the help, I’ve updated the list, but left some items in case it helps anyone else.
    Working wheels now, and updated above for all the 17s I could find from google.
    Thanks again and stoked for the build and future upgrades!
  14. Jan 17, 2025 at 11:22 AM
    jayhawknavy02
    SOCAL
    Thank you to everyone who helped above, and especially Dirty Deeds, CoachBuilder, Fox, King , 88Rotors, and others who gave me some great advice and guidance. I think (safely) I have a much better understanding of what I need to do and updated the original post and tried to sequence in a way that made sense. Appreciate any update, inputs, feedback, corrections, etc.
    I still have some questions, but considerably less than at the beginning thanks to the Team!
    Cheers,
    Jay!
    STAGE 1: PRE-SUSPENSION INSTALL
    STAGE 2: SUSPENSION (Level - 2" Lift)
    STAGE 3: EXTERIOR
    STAGE 4: AS REQUIRED
  15. Jan 23, 2025 at 6:24 AM
    QCTundra
    QCTundra New Member
    Sounds like a nice built you get yourself intoo :)
    You dont specified what type of wheeling you do or want to do ; are you gonna rip desert at 60 MPH or slowly wheel up some rocky trails ?
    I dont think steering kit , neither spindel gussets or up-graded axels are a neccesity ! If you want to slowly wheel up some rocky trails : i would focus on a more articulated suspension set-up and perhaps ditch some reinforced parts to add some more rock protection like rock slidders , and some high angle of attack FR and RR bumpers :)
    Also dont go with an ''add On'' leaf kit, but go on a full leaf set that suits your needs ( fast whoops oriented or slow rock crawling oriented to maximised articulation )
    Same goes on the valving type of the shock you choose !
    Gear sets on 35 is REALLY a must to me, while in there you should considere a eaton Elocker for the rear if you gonna enjoy crawling some trails . i dont think you need more then a cab mount plate weld to fit 35'' with no rubbing on a 3/2 lift kit .
    i run 34's'' with a trans. tune and i will eventually go to a 4.88 gear set , cant imagine 35 on stock gears/stock tune ... it must be horrible on highway and wayyyy too tall on the trail !!
    Again , its unclear on what type of wheeling you are/want to get intoo so a bunch of parts might not be needed , an some other should be consider ! Fast vs crawling can change a lots of parts choices and shocks tuning , and save you some money to ultimatly put parts where needed and maximised you truck performance and handling regarding on what type of terrain/ wheeling you do !
    Tire choices seems allright , those new Falken RT or At4 worth a look too ! Also E or C Rated can change suspensions dymanics, depend on the terrain you ride the most ! I personally run E-loaded because i run LOTS of rock at fast speed air down at 20 PSI , but i wish i could runs C tires to save some unsuspended weight and a general smoother ride !
    If i'd run more sand and slow speed, i would run C loaded all day for sure .
  16. Jan 23, 2025 at 7:44 AM
    QCTundra
    QCTundra New Member
    Basicly i wanted to say your parts choice seems base on ''lift'' only , rather then Maximum travel or performance on the terrain you want to wheel on !
    For exemple the rear shackels might not be needed with a leaf pack and rear shocks combos design for max wheel travel or max articulation etc !
    let us know what parts you order and what type of terrain you'd wheel ontoo ! :)
  17. Jan 23, 2025 at 8:23 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Man, that is a pretty exhaustive list. I have the exact same trim and package truck, except it’s a ‘21. What has worked super well for me is just putting the TRD Fox suspension kit and RAS on it with some skinny 35s.
    The benefit of the TRD Fox kit is that it’s almost a mid-travel kit that bolts right in with zero mods needed for UCAs or anything else. The RAS acts like a sway bar but also kinda like KDSS at slow speeds offroad where you still can get great articulation in the rear.
    The 285/75R18s fit on OEM wheels with OEM offset, again with no cutting to fender well plastics or chopping and moving the cab mounts. The downside is they need rebuilt within 50k miles, less if you’re off pavement often. I’m now looking at the Bilstein 8100s, which will require UCAs and less positive wheel offset. But the setup I just outlined got me up and running for minimal time and $$$ and worked well for me for a few years.
    Just a comment on two points that vtl made:
    The bed stiffeners thing. I run them, but I understand the argument for not. They’re kind of a bandaid and simply transfer movement to the next, weaker link in the chain. The argument against them is, maybe we shouldn’t use our bedsides to combat frame twisting.
    And yeah, that’s a pretty strong argument.
    The reason I run them anyway is because I noticed my aluminum roll cover twisting in a weird way and needing to be retightened. If I had a ton of weight in the bed, I probably wouldn’t run them, but I’m generally only at 3-500 lb even loaded up for camping. They keep my bedsides square so my roll cover operates like it should. If I start seeing pinch welds coming apart at the front of the bed or stress around the bolts that actually mount the bed to the frame, I will remove them.
    The best mod to combat frame and bed flexing is boxing the frame, which several members have done.
    Secondly, a nominal 35x12.5 tire measures 34.5” in diameter, and when it’s on the truck under a load, it’s even less. My 285/75R18s measure 34.8” on some rims, and 35.1” on others. What I notice though, is that at ~40psi and mounted on the truck, they’re barely taller than 34”. They were still the very best option for me to get extra ground clearance with zero cutting or chopping anything to make them fit. Remember, you only gain ground clearance at the axles with larger diameter tires.
    It’s so easy to spiral out of control with mods. Now that I’m considering the Bilstein kit, it makes me think I might as well go to 37s lol
  18. Jan 23, 2025 at 3:22 PM
    jayhawknavy02
    SOCAL
    Thanks everyone for the responses! Very much appreciated!
    I've done some rock crawling in the Tundra in stock form, and it did amazing for how pudgy and long it is but would rather not do anymore. I think I lost a few pounds and added some gray hairs at Anza Borrego. Looking to stick to overland type fun and areas that look somewhat like roads or at least desert without boulders I have to drive up and over. Kids and Dad like to go fast, but typically stick to the sand washes. There are some rocks, small streams you have to go up/over and across to get to some great camping, but nothing insane. The Tundra club out here does some very cool stuff, but requires 35" tires, not sure about the Tundras to Sedona event. This truck gets me to and from work 95% of the time, and when I can (weekends) trips to the desert. Long past my really stupid days, now just kind of stupid, so not driving really fast and not looking to smash my truck on boulders and get stuck in the desert either. Done both in the past.
    Copy that!
    Those should be in the plan above, are you saying those are not suitable? Just a little confused and appreciate the clarification.
    In regards to the leaf springs (rear) - Deaver or Dobinson or doesn't matter?
    Specific to tuning, I was thinking of taking it to the Accutune folks here in San Diego, unless there is another / better / easier option I can do myself when I install. Appreciate any insight in to that!
    I've thought about the Eaton or ARB, but wasn't sure I really needed it for the JV level of stuff I'm probably going to be doing, I'm assuming (need to do some google) the E-Locker doesn't require an air system/pump. Not sure my use case necessitates it (which I failed to put above).
    Agreed, I have a master welder who can do either for the price of beer, so I thought why not it to completion do to avoid any subsequent re-work when the labor may not be free and if I decide to run 37s someday (unlikely) I could (but probably won't).
    May be flawed logic, but that was my thought process.
    Absolutely, I have another thread specific to tires/wheels. I chose the above as kind of a "worst case" dimension wise. I don't see my use case requiring the E rated and I think I can save some weight, especially with some of the tires around 60 lbs being 8 ply.
    https://www.tundras.com/threads/gen...-long-time-listener-first-time-caller.152823/
    Agreed! The issue is I don't have that expertise or experience level. Not sure if an added leaf or leaf pack + shackle or a new leaf pack is the best approach, or which combination does or does not require an extended shackle. Not something I've done before. Previous work was just return things back to OEM when they broke vice modify so appreciate the help and advice tremendously. I've seen mixed reviews on Icon on the forum so I can give Deaver and Dobison a call.
    Gotcha, not sure what the RAS is though? I do need to get some new UCAs anyway which is why I was going with JBA and the price is nearly OEM and have the lifetime warranty.
    I scored some Icon Recon SLX 17x8.5 +25 offset wheels ($100 each) so I down that path already unfortunately.
    Nice, I've not heard about or familiar with boxing the frame, but I'll check that out, may be something I can beg the welder for with another case of beer!
    I sympathize and seem to be going the same path...lol.
  19. Jan 24, 2025 at 8:29 AM
    QCTundra
    QCTundra New Member
    I love how you put details and so much organized info in your tread ! Thats what i do at work and love to work with people with that much level of details haha !
    Keep in mind ; sometimes less is more , and its SO easy to get lost in all the part and set-up availble for our trucks . sometimes to much mix and match get things worst , or it can cost lots of money to learn and waste on not adequate or optimal parts . sometimes parts dont work well together !
    The key to a good set-up is balance between parts, and there is always a compromise to make somewhere , so it work best where we want , and less in some situation ( Linear VS degressif shock , for exemple ! )
    it seems you are not going to be Very hardcore in your wheeling, and if the truck is used 95% on the street ; there is no need to oriented the set-up in a very hardcore set-up and off-road oriented . Something very soft for whoops will not handle well on the streets
    More fancy parts also means more maintenance and more money , and more part dosent always equal more performance or more reliability , it can even make a truck less capable or under perform !
    Our truck are very capable from factory and made VERY sturdy and durable : They can take a BEATING with stock parts and component , only with a few bolt-ons .
    I can only speak for myself and my own experience , but i run an Icon LTX leaf pack for almost a year now and they have been flawless , pair with a set of 8100 By-pass bilsteins and i'm very please on how they handle and perform and they have been abuse and beat to hell !
    I chose the RTX because i tow and haul a lots of different weight and i wasent sure on how they will perform , so with this kit i was able to put more or less spring rate accordingly if needed . i end up using them on the medium leaf adjusment pair with blue sumos and its been the perfect balance for me and my need !
    If i had a set-up that weight about always the same ( like an overland set-up in the box ) i think a Deaver Pack made for my weight would have been a good choice . More travel IS always better ; some leaf and shock combos are made for this , like my RTX and 8100 combos... i know fox and icon have some combos for this too and i would suggest you look intoo these option !
    My set-up is not the smootest at slow speed in washboard and smaller road inputs , but it really shine at speed. the more i beat on them, the best it perform. it can out-perform the truck chassis EASYLY . And thats exactly what i wanted , it also behave so good on the street and highway , much better then the stock SR5 it was , more stabe and more planted ! Not sure it would be best in crawling and slow speed wheeling . something linear damp softer would work better for sure .
    Dont over think THAT much , choose a vendor you trust and go from there : they will make sure you buy parts that works together and are well balance for your need !
    i always use the rule of 3 : call 3 vendor , have them a quote for a base set-up , and see who had the best set-up/best advise for you ! Dont buy a price ; buy a service/knowledge from an experience shop and vendor !
    Start simple with bolt-on , Say 4 shocks , a leaf pack and whats needed to go together ( diff drop , shims , bump stops etc ) and go from there... ride the truck and you will soon enough know what to add or not from there from your typical week-end wheeling and also what compromise you want that keeps the truck friendly to commute to work ! :)
    There is SO much info on youtube you must already know for our truck , Like ''Thinkerer adventure'' chanel and the guys from Shock surplus have TONS of very nice technicals content to help you make your mind and understand suspensions dynamics , it worth the watch and re-watch to help chose the kind of set-up youd enjoy on your truck the best !
  20. Feb 16, 2025 at 4:25 PM
    jayhawknavy02
    SOCAL
    I'm going to pull back to 34" tires based on the lack of need to re-gear, and if I want to go off-road (insane level) I'll just pick up another wheel set to avoid destroying my daily driver MPG, suspension wear/tear, tires, and the reduced on road performance. A 2" lift up front should pretty much level the truck with the OEM springs. Thanks to everyone, especially Dave at CoachBuilder.
    STAGE 1: BODY (Level – 2” Lift w / 34” Tires)
    STAGE 2: BRAKES
    STAGE 3: SUSPENSION (Level – 2” Lift w / 34” Tires)
    STAGE 4: DRIVETRAIN
    STAGE 5: WHEELS & TIRES
    STAGE 6: EXTERIOR
    STAGE 7: INTERIOR
    rruff likes this.
  21. Mar 18, 2025 at 12:05 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Hi, I stumbled across this while looking at 17" rims and Maxxis Razrs... because I want to put 37s on mine!
    I have fat (>13") heavy (>80 lb) 35s on my rig (325/65r18), 1.5" front lift (IM FCP), +25 18x9, Boise Spring 4 leaf add on, no UCAs, no regear, big assed camper and load. I also live at 7k ft, so the engine is relatively anemic compared to sea level.
    None of the "terrible" things you mention regarding larger tires align with my experience. Tundras look way better with big tires, they are better offroad, and they are fine on road too. You'll lose a little acceleration, but you'll forget about that soon enough. It's a big V8 after all! No weird shifting, no MPG loss, at least with 2.5 gen. Firmer ride, but handles better too.
    Oddly before the camper my MPGs were no worse than with the stock Bridgestones, and better at low speed. Long highway trips >17 mpg, and now a little under 15 with the camper. Part of that is luck, because I got tires with low rolling resistance. ATs vary a lot, and they aren't tested for MPG, so it's hard to tell. Though I think as a best guess, go with the higher speed ratings as a proxy.
    Also... get a throttle controller! This is absolutely necessary IMO. The 2.5 gens have different computer settings... very anemic "learned" throttle mapping if you drive fairly sedately. It causes the engine to feel like a 4 cyl... 1/2 the throttle gives you maybe 1/4 of the engine. I got a HikeIt X5, cheap and works fine.
    Keep your lift <2" and you can use your stock UCAs. When aligning, move the wheels as far forward in the wells as possible. I went into detail on that somewhere in this forum. Space your bumper forward. No BMC needed unless you get 37s, and 1.5" lift will still be fine. Excessive lift is the biggest stress on an IFS front end.
    I'd avoid shackles for lift. Unless you extend the bumpstops, they'll over-stress your springs when you bottom out.
    Where the hell did you get those rims so cheap?
    Happy to discuss more, if you wish.
