Transmission
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2016cmJD77, Dec 8, 2024.
  1. Dec 8, 2024 at 7:15 PM
    2016cmJD77
    2016cmJD77 [OP] New Member
    2016 CM platinum 4x4
    6” pro comp lift, S&B CAI
    I am new here to the group, thanks for the add. I am also new to my new to me tundra. I love the truck and I got jumped into the club early on. I picked it up 10/31 and 11/24 the transmitter left the chat on the way to California. Looking for some others expertise with rebuilds, factory replacement custom build?
  2. Dec 8, 2024 at 7:55 PM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Throwin’ a code? I had a shift solenoid take a dump and I woulda bet the trans was done (barely moved, no 1st, slammed into 3rd etc)
    $60 later..back to normal.
  3. Dec 8, 2024 at 7:59 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If you're lucky and it's a solenoid(s), here's a great video on how to swap them out.
  4. Dec 9, 2024 at 7:41 AM
    2016cmJD77
    no reverse got to raise the rpm to about 2,500 before it will go forward. I didn't have my scanner it just said transmission temp high
  5. Dec 9, 2024 at 7:47 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Get the codes pulled if any way possible. As others have said, it's often a solenoid. Toyota will say new trans as they won't replace solenoids. Super simple to change out if you've ever dropped a transmission pan.
  6. Dec 9, 2024 at 8:16 AM
    Have you checked the fluid level?
