  1. Dec 6, 2024 at 11:12 AM
    #7981
    maldo012
    maldo012 23 tundra hybrid
    Eric
    Chicago
    23 Tundra Hybrid-Limited
    3inch dobinsons ims struts w/Rough Country 1.5inch spring/M1 shocks in the rear— Icon Uca — Hostile maniac 20inch w/general grabber atx tires — Perry parts front bumps - alpharex luxx headlights— swapped many parts with trd body components— race off-road trd grill etc
  2. Dec 6, 2024 at 11:15 AM
    #7982
    maldo012
    Eric
    Chicago
    and I haven’t had any issues with rub at all. That’s with a 3.5inch rough country kit and also with my new setup for 3in ims dobinsons lift. I get about 1.5inch over stock and Still no issues
  3. Dec 6, 2024 at 11:41 AM
    #7983
    Crawldad
    Crawldad New Member
    2024 Tundra Limited TRD OR w/3” Lift
    My tires being 34.4” will be close, I’ll probably give them a try though I don’t want to run without mudflaps. If my tires rub I can sell the mudflaps here
  4. Dec 6, 2024 at 12:02 PM
    #7984
    maldo012
    Eric
    Chicago
    just buy some flat head screws from Amazon in the same size as what are included with the mudflaps brother to give you that extra space. Problem solved
  5. Dec 6, 2024 at 12:10 PM
    #7985
    Crawldad
    Crawldad New Member
    Yes, black ones
    maldo012 likes this.
  6. Dec 7, 2024 at 2:11 AM
    #7986
    BenInILM
    BenInILM New Member
    Ben
    Surf City, NC
    2023 Toyota Tundra Platinum (Hybrid)
    OEM Bronze 18" Wheels Rokblokz Mud Flaps
    I have also beeen running Rokblokz since getting my truck in 2023 and they are great.
  7. Dec 7, 2024 at 12:41 PM
    #7987
    SgtJeep
    SgtJeep New Member
    New Toyota owner. Coming from Jeeps and most recently a 2021 Ram Laramie 4x4. Loved the Ram, but really love the Tundra.
    Been lurking here for a while before I bought my 2024 Limited TRD on 31OCT24. I'm currently on page 220 of the 267 pages of this thread.
    Getting through it and making my lists of future purchases/builds. Lot of solid looking trucks!
    So far:
    Ceramic tint all the way around (minus pana.roof)
    TuffSkinz center console insert (should have been factory installed) and Grille TRD and TRD colors
    Screen protector
    OEM bed cover
    Fitted bed mat
    2 TRD air filters
    and just today, I installed the Blackout hood wrap from Rumble Wraps.
    I watched all his videos and installed myself. Super easy and came out great. (I did the dry install)
    Rumble wraps is GTG! Great shipping in super thick cardboard box. The vinyl was wrapped around a sturdy cardboard tube, with square plastic end pieces to ensure the wrap doesn't move at all in the box. He also put a center plastic piece in the middle of the shipping box bc USPS & UPS suck and squash things. I don't know the crush weight of the box the vinyl was sent in, but it would have taken quite a bit to damage the wrap inside! They did a great job in shipping and material.
    Next up is either a Covert front bumper or similar bumper with tow hooks (also should be a factory piece of kit).
    Tires/small lift down the road.
    Before and after pics:
  8. Dec 7, 2024 at 3:14 PM
    #7988
    Crawldad
    Crawldad New Member
    Removed my mud flaps and the tires rub the felt liner in back. Looks like I will need to pin the liners back and run without mud flaps
  9. Dec 7, 2024 at 5:10 PM
    #7989
    TBSTRDOR
    TBSTRDOR New Member
    2023 Tundra Limited TRD OR Crewmax Hybrid Blueprint
    I've had the RekGens for a year now and been happy. They fit well (with some adjusting) and work well. WAY better than the OEM flaps. Looks like they're a better setup than the ones shown in that Tacoma thread. That said, I am at full outward adjustment for coverage with my summer wheels/tires (Method 707 +18 with 275/70R18). I have excess coverage with my OEM wheels with 275/65R18 in the winter though.
  10. Dec 7, 2024 at 8:49 PM
    #7990
    ToyoJon
    ToyoJon New Member
    2025 Tundra Limited
    Used it to take the dirt bikes out for a ride.
    Loving this truck even more. Pulls great and looks good doing it.
    cartage1, jachal, Mr Rick and 5 others like this.
  11. Dec 9, 2024 at 7:18 PM
    #7991
    jachal
    jachal jachallen
    andy
    FLX NY
    2023 Black Platinum Hybrid
    [/QUOTE]
  12. Dec 10, 2024 at 3:29 AM
    #7992
    mach1man001
    mach1man001 New Member
    Rob
    MA
    2024 Limited Crewmax
    [/QUOTE]
    That looks great!
    jachal[QUOTED] likes this.
  13. Dec 10, 2024 at 11:25 AM
    #7993
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Added bump switch to the passenger side, waiting on the harness to be finished. Ordered a switch and bezel for drivers side and did a little engineering. IMG_2582.jpg
    Narco, thomez, Siblue and 2 others like this.
  14. Dec 10, 2024 at 11:32 AM
    #7994
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    How many screws did you get on that switch?
  15. Dec 10, 2024 at 11:58 AM
    #7995
    machd08
    machd08 New Member
    CLARENCE
    None, just used 2 that were a little longer. On the bottom, had to put a thick spacer under the tab so that it moved the bezel back a little. The photos I copied from a guy on Facebook that did his, instead of washers I used a spacer that was thick enough. I went through 2 bezels doing mine. Bottom will not align perfectly. If I could have cut the factory bezel that would have been the better option, tried and it looked like shit. Unless someone could router it out or 3d print one that is like the actual passenger side, instead of engineering the drivers side to work on the passenger side.
  16. Dec 10, 2024 at 1:13 PM
    #7996
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    WOW! That's alot of work, I rarely even use the switch on the drivers side. Good job though.
  17. Dec 10, 2024 at 1:44 PM
    #7997
    eddiefromcali
    Eddie
    100% Stock
    @machd08 I was under the impression that you could just pop the fake button out of the passenger side and slap the switch in there...no need for another bezel. Is that not the case then?
    ziznack likes this.
  18. Dec 10, 2024 at 7:35 PM
    #7998
    Reaper1911
    Reaper1911 New Member
    2024 White Tundra Limited Off-Road
    -TRD pro reaper bumper panels/fender flares -Catalytic converter cover -Bak revolver x4s tonneau cover
    Replaced my ugly gloss black center console with a topograph one.
    Added a holster for a squirt gun.
    Put on a cute little tri-color badge on the grill.
    Dont know how to add a vid clip of my holster, so i guess it's just a zip file to dload, it's not a virus I promise.
    Bucng8r, Narco, CYBERO24 and 4 others like this.
  19. Dec 10, 2024 at 8:22 PM
    #7999
    ToyoJon
    ToyoJon New Member
    2025 Tundra Limited
    Is the console a sticker or an actual swap? I don’t mind the gloss black but looks like it’ll show swirls rather easy. Was thinking of looking into other options.
  20. Dec 10, 2024 at 8:25 PM
    #8000
    Reaper1911
    what headlights are those? I think I was looking at similar ones but read that they dont last long.
  21. Dec 10, 2024 at 8:28 PM
    #8001
    Raven67
    Kentucky
    I found this on Amazon, looks amazing & it's excellent quality. $1520241005_154116.jpg
    JDMCAR Central Control Gear Shift Panel Trim Cover Compatible with 2022 2023 2024 2025 Toyota Tundra/Sequoia Accessories, Gear Shift Control Anti-Scratch Panel Decorative Sticker -Matte Black https://www.amazon.com/dp/B0CJRNWTWD
  22. Dec 10, 2024 at 8:28 PM
    #8002
    Reaper1911
    It replaces it completely. I could be wrong but the wrap just slaps over the original, I had to rip out my old one. Hated that fingerprints and dust collected on it.
    ToyoJon[QUOTED] likes this.
  23. Dec 10, 2024 at 8:29 PM
    #8003
    Reaper1911
    all black looks good.
    Raven67[QUOTED] likes this.
  24. Dec 10, 2024 at 9:07 PM
    #8004
    ToyoJon
    ToyoJon New Member
    2025 Tundra Limited
    Very cool, I searched and found one by AJT but didn’t see yours. Where did you get that one?
    Reaper1911[QUOTED] likes this.
  25. Dec 10, 2024 at 10:00 PM
    #8005
    Reaper1911
    Center Console Panel Tundra (2022+)
    Here's the site I got them from. Apparently the panel is AJT but they dont sell the topograph on their website. Yota Xpedition does. I also added a red cap for the 4x4 selector switch, didn't like the light gray color.
  26. Dec 11, 2024 at 6:11 AM
    #8006
    machd08
    machd08 New Member
    CLARENCE
    Not the case
    eddiefromcali[QUOTED] likes this.
  27. Dec 11, 2024 at 8:25 AM
    #8007
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
  28. Dec 11, 2024 at 10:31 AM
    #8008
    akira
    akira 25 Tundra Limited TRD OffRoad
    San Diego
    Hoping one of these companies makes this for the A/C control panel that has the volume knob present.
  29. Dec 11, 2024 at 11:36 AM
    #8009
    NTX_Tundra
    NTX_Tundra New Member
    Joined the 3rd gen gamily with a 2023 TRD Off-Road with Off-Road premium package
    Miker24, 23MAXBlue, cartage1 and 5 others like this.
  30. Dec 11, 2024 at 1:01 PM
    #8010
    Arthughes1
    Arthughes1 New Member
    Northwest Arkansas
    2025 Limited TRD OR
    Added the Beatsonic amp to the JBL system. Decent amount of improvement but causes the whole thing to rattle like hell. Still trying to decide if I’ll keep it.
    eddiefromcali likes this.
