  1. Dec 5, 2024 at 2:02 PM
    rcsbguy
    rcsbguy New Member
    Haha!
    Yes it’s original paint. Low mileage truck, well cared for. Shines bright!
    RCLB’s are great trucks!! Just longgg haha I had one too
    Deaner, Medicineman, OldGuy03 and 4 others like this.
  2. Dec 5, 2024 at 3:04 PM
    click
    click New Member
    SoCal- IE
    White 2008 Tundra 5.7 TRD dbl cab 2x4
    Did this a while ago now, but when I bought my truck a month ago, the front bumper didn’t have a way to affix the license plate. The premade brackets designed to go on the hawse fairlead either wouldn’t work due to it being recessed, or weren’t appealing to me since they stuck out a lot. Instead of $50 for something I didn’t really like, I paid 6.99 to get these little c-clamps and painted them black. There’s a little Velcro between the plate and the bumper to prevent scratches, and some foam tape between all the other metal to metal contact points. I think it turned out pretty good, without clashing with the off-road design of the bumper.
    Sure I could have left the plate off, but in California it’s just a waiting game for a headache I don’t need.
  3. Dec 5, 2024 at 5:55 PM
    click
    click New Member
    SoCal- IE
    One more from me today, Just now finished hooking up the lights on my new rear bumper. This was my first time doing anything like that, it was a fun learning experience.
    Added a button to the panel, the blue doesn’t match the rest of the orange backlights unfortunately. And the button sits a little recessed even when not pressed
    Used a fuse tap to plug in to the ACC circuit, so the button turns on and off with the truck. Came through the firewall by just pushing around the grommet, rather than cut it.
    The relay leads for the battery were very short, so it had to be mounted closer than I’d have preferred.
    Was definitely a fun little project, and I learned a lot from the process. Took a lot of wire to get to the back of the truck, more than I expected.
  4. Dec 5, 2024 at 10:06 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    I would highly suggest the relay be moved under the dash or replaced with a weatherproof relay. A non-weatherproof relay will eventually get corrosion and buildup between the contacts and cause a parasitic drain and possibly uncontrolled activation of the circuit.
  5. Dec 6, 2024 at 10:36 AM
    click
    click New Member
    SoCal- IE
    I appreciate the tip, as I said this was my first experiment with electrical in a vehicle.
    todays project was replacing the super faded and non-working tailgate latch/lock. Put in a metal handle, I wish the whole thing was metal not just the lever.
    mtucker, PhotoNerd and OldGuy03 like this.
  6. Dec 6, 2024 at 2:58 PM
    Windsor
    Homeless in Oregon
    Some.
    No worries. That's how most kits are sent pre-wired. The majority of people don't even think about it until they are chasing their tails because their battery dies overnight. I learned that lesson when my dual trumpet air horn started blasting on its own.
    Cruiserpilot and click[QUOTED] like this.
  7. Dec 7, 2024 at 6:05 PM
    Windsor
    Homeless in Oregon
    Some.
    Cleaned the engine a little. Got tired of looking at dirty hoses. Folks, keep your hoses clean. Clean hoses are happy hoses. After that, I'm done for a couple days, that was painful.
  8. Dec 7, 2024 at 6:08 PM
    Deaner
    Deaner New Member
    Dean
    The Mac
    2010 Rock Warrior
    I'm sure everyone would prefer their hose clean.
  9. Dec 7, 2024 at 6:09 PM
    82nd Airborne
    82nd Airborne New Member
    2012 SR5 DC
    That's a lot of clean hose...:eek2:
  10. Dec 7, 2024 at 6:49 PM
    chrisf111
    chrisf111 New Member
    If you haven't got this all hooked up yet take a look at the post I did. Details on how to wire it.
  11. Dec 8, 2024 at 5:04 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I’ve never seen hose that clean!
  12. Dec 8, 2024 at 5:05 AM
    Deaner
    Deaner New Member
    Dean
    The Mac
    2010 Rock Warrior
    You better keep them hose on a leash...
    OK I'll stop.
    Windsor likes this.
  13. Dec 8, 2024 at 12:58 PM
    rphass17
    rphass17 New Member
    Heatwave here today and all the car washes were full or broken. So I did a quick salt rinse and rotated my tires. I put copper anti-sieze on my wheel studs and wheel mating surfaces. Also kroil on my suspension component bolts because these original shocks need to be replaced.
  14. Dec 8, 2024 at 1:14 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Don't go too heavy on the wheel studs. I used copper on my trailer, both wheels damned near fell off.
  15. Dec 8, 2024 at 3:15 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    Sneak peek on next weeks reveal.
    Did some painting and sprang for the 2K clear coat on Amazon.
    Gonna let them cure for about 5 days, wetsand w/ 3000 grit and cut/polish.
  16. Dec 8, 2024 at 6:18 PM
    LILTRD
    LILTRD New Member
    East Bay, California
    2013 Tundra RCSB
    Hidden Winch Lighting Suspension/Air bags Wheels/Tires Audio Center Console swap
    Finished up the TRD front sway bar install as the replacement came in. Also, worked on mounting my AFR/Boost gauge..can't decide straight up/down or lean to the side.
    PhotoNerd and koditten like this.
  17. Dec 8, 2024 at 6:36 PM
    koditten
    Kirk
    Midland of the Mitten
    To the side. I use CC too much to have that icon not being visible.
    Mdl, joseph_womack and FrenchToasty like this.
  18. Dec 8, 2024 at 7:14 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I went to the left side as well, I felt that it obstructed fewer cluster items.
    Mdl and koditten like this.
  19. Dec 8, 2024 at 8:24 PM
    Windsor
    Homeless in Oregon
    Some.
    Vacuumed, wiped off all the dust from the summer, wiped the hard surfaces with armor all, cleaned windows, washed. Realized I forgot to turn off my solar controller before I disconnected my battery, fried the controller.
    joseph_womack likes this.
  20. Dec 8, 2024 at 11:38 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    Wait why do you need to disconnect the solar controller first? And where do you have your solar panel mounted?
  21. Dec 9, 2024 at 7:44 AM
    Windsor
    Homeless in Oregon
    Some.
    The controller I had was the lowest one that Renogy sells. Pretty much their giveaway controller, a 10a pwm. If you don't disconnect it first, it has no protections built in. Second one I've killed. First was a learning experience that got me to put in a switch since my controller is behind the back panel. This one was a learning experience to install one with internal protections.
    Panel is mounted on the roof platform.
  22. Dec 9, 2024 at 1:57 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Home made trailer? Got enough power there from all that solar I'm surprised you only have a 10A controller.
    But that's just the truck then? What do you power in the truck?
  23. Dec 9, 2024 at 5:00 PM
    Windsor
    Homeless in Oregon
    Some.
    Lots of solar on the trailer because I am usually in the trees and have to move the ground panels around. Trailer has a 100a controller.
    Truck has single panel 100w panel and 10a controller. That is to keep the battery topped up because if I am working on the road, I am using my CB and VHF radios.
  24. Dec 9, 2024 at 6:26 PM
    joseph_womack
    Joe
    Louisiana
    Ahhh I see, I was looking at their marine controller that’s 20a I believe, benefit being its waterproof
    I’ve wanted to put a panel on mine, but it’s a regular cab so no roof rack and I think my tent is too wavy to mount it there, might go straight on the roof
  25. Dec 9, 2024 at 6:29 PM
    Windsor
    Homeless in Oregon
    Some.
    I was just looking at the marine controller. I need to check the model numbers as it seems they are swapping some of the chargers to positive ground.
    joseph_womack[QUOTED] likes this.
  26. Dec 9, 2024 at 9:01 PM
    08OffroadTN
    08OffroadTN New Member
    2008 TRD Offroad
    The original 3rd brake light was loose and letting water in, so I replaced it with the Morimoto X3B15.2
    Optic15, TruckyTruck, Ryuu and 10 others like this.
  27. Dec 9, 2024 at 9:53 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Quick oil change on the '08 today.... It'll get one more before it hits 300k :evil:
  28. Dec 9, 2024 at 10:06 PM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub,
    Nice! How much was it? So much easier to change with the roll down window... jealous.
    ScreenSavers, PhotoNerd and OldGuy03 like this.
  29. Dec 10, 2024 at 2:08 PM
    Windsor
    Homeless in Oregon
    Some.
    Took the door panels, vapor barriers, window weatherstripping, and vent visors off. Cleaned window rails, windows, inside of the doors and weatherstripping. Taking it in on Friday to get the windows tinted and figured she'd like to not deal with multiple years worth of FSR dust.
    Window weatherstripping started to fall apart when I was removing it, so I will be ordering new ones for all 4 doors.
    Holy crap the inside of the doors were dirty.
    Tripleconpanna and joseph_womack like this.
  30. Dec 10, 2024 at 2:37 PM
    SAGE63
    San Diego County
    Added Dobinsons Snorkle... Hopefully less desert dust in the airbox.
    oops this should be in the 2.5 gen thread...
