Who’s going to be first? 25k oil
Discussion in '3rd Gen Tundras (2022+)' started by Woodrow bangs, Dec 7, 2024.
  1. Dec 7, 2024 at 4:25 AM
    Woodrow bangs
    Woodrow bangs [OP] New Member
    Baltimore
    2023 MBM Platinum
    Far from the jiffy lube 3k between oil changes back in the day. Who will commit to trying this??
  2. Dec 7, 2024 at 4:42 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Those with disposable engines, send it. 2022+
    Toyota1234, wing-2, WILLINH and 13 others like this.
  3. Dec 7, 2024 at 5:15 AM
    articdesert
    articdesert Will work for truck parts
    23 1794 MGM
    That’s the filet mignon of dinosaur juice
    WILLINH and ZappBrannigan like this.
  4. Dec 7, 2024 at 5:16 AM
    SpilledTheSalt
    SpilledTheSalt Fish Lips
    Oregon
    2024 Tundra 4x4 HV Limited TRD
    2" RC Leveling Struts
    I've used it previously, it's been around for a while. Several oils have the same mileage claims (Amsoil sig., M1 extended, etc.) I still change it at 3-4k regardless.
    Rcflyersd, AstroDude, Tom976 and 3 others like this.
  5. Dec 7, 2024 at 5:41 AM
    Tundra family
    Tundra family New Member
    Well I've ran mobile1 for about 10k with no issues (that I can tell, just the usual cam tower leak and VVT noises at 200k miles). I don't think I could ignore the "maintenance required" message for that long though and resetting it would throw off all my other maintenance intervals.
  6. Dec 7, 2024 at 5:55 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    You'd be better off running dollar store oil and changing every 5k miles or 6 month.
  7. Dec 7, 2024 at 6:15 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    I would run it…but not 25K. Don’t drink the cool aid. Proving a oil damaged the engine to an oil manufacturer is nearly impossible.
    WILLINH and Leo's first like this.
  8. Dec 7, 2024 at 6:15 AM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    No way
    Raven67 likes this.
  9. Dec 7, 2024 at 6:17 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Just no with any engine.
    Hell no with a turbo engine.
  10. Dec 7, 2024 at 6:36 AM
    gnatehack
    gnatehack New Member
    Middle of Minnesota
    13 SR5 5.7 4x4 Bench
    Up to date maintenance
    Are people seriously that lazy? Is it really that hard to change your own oil?
    ^^Rhetorical questions...^^
    The conclusions from my extensive research are 'probably' and 'no'.
    woods, WILLINH and ZappBrannigan like this.
  11. Dec 7, 2024 at 6:45 AM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Just cut to the chase and dump some kitty litter into the oil fill after your done:hattip:
    WILLINH likes this.
  12. Dec 7, 2024 at 6:53 AM
    Tundra family
    Every time I have tried to change the oil on this damn truck the housing gets jacked. I just let someone else screw it up now. 2 leaky metal housings and 3 stock ones later I just say "it's your problem now" as I hand over the keys.
  13. Dec 7, 2024 at 7:01 AM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    Mobil 1 and Amsoil have had 25k mile oils out for a long time now. I think these are intended for people who drive much more than average in a year.
  14. Dec 7, 2024 at 7:09 AM
    Mr Badwrench
    Mr Badwrench New Member
    How much is it? :monocle:
  15. Dec 7, 2024 at 7:25 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  16. Dec 7, 2024 at 7:27 AM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Those were the days. I ran Amsoil and the dual cartridge bypass filter kit for the first 180k miles of my f150 in the 2000s. Only did 4 or 5 oil changes on it. Sent samples to blackstone every 15k from the small petcock on cartridge setup. Ran one oil change close to 50k. I took the kit off 10 years ago and still have truck with 250k miles and still runs great, original engine and transmission untouched (except timing chain guides, ford used plastic that disintegrates). I follow the 5k for tundra now since i have extended warranty.
    WILLINH likes this.
  17. Dec 7, 2024 at 7:33 AM
    nafterclifen
    nafterclifen New Member
    Pocono's, PA
    For whatever it's worth - I have an 06 Tacoma with 260,000+ miles. I've owned it since new and have only ever used Amsoil's signature series (25k mile). I change oil and filter ever 10k miles though. Engine runs and sounds great and has never been opened.
    Woodrow bangs[OP] and coldcanuk like this.
  18. Dec 7, 2024 at 8:07 AM
    DRP
    DRP Old Member
    Dave
    A writer for Popular Mechanics did an article a while back where he talks about going 10 years without changing the oil in a lawnmower. He decided to send a sample to Blackstone and they came back and basically said it was still good to go.
    https://www.popularmechanics.com/cars/car-technology/a24676402/old-motor-oil/
    1lowlife[QUOTED] likes this.
  19. Dec 7, 2024 at 8:24 AM
    Mr Badwrench
    I accidentally purchased a "no oil change" mower without realizing. It's a Briggs engine. The damned thing doesn't even have a drain plug so I have to flip it over and remove the oil fill spout. Based on the sheen of the oil, it very much needs to be changed.
    Maybe I'll put this stuff in my lawn care equipment(?)
  20. Dec 7, 2024 at 8:31 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    My first Toro lasted 4 years, admittingly I never changed the oil.
    It just locked up one day.
    My second Toro I changed the oil religiously, once a year.
    I was a 2011 and one of the seals gave out this year, I got 13 years out it.
    It was going to cost more to fix it than it was worth so I bought this new one.
    All 3 I had to, or will have to, tip it over to drain the oil..
    Sorry for the thread drift..
    Tundrastruck91 and WILLINH like this.
  21. Dec 7, 2024 at 8:47 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    I'm a firm believer in good maintenance. I take care of it all myself on everything I own. No vehicle ever goes past 5000 miles regardless of oil used. Dino oil, Synthetic oil, or snake oil. Every year or 5000 miles.
  22. Dec 7, 2024 at 9:16 AM
    steveh
    steveh New Member
    '24 Tundra Limited
    Nothing Yet!
    I got in with a local oil testing company and did frequent oil tests. I haven't done one now since I moved but I will be screening, at least, my oil at 10k after getting my first oil change at 5k. I did run a corolla 50k on an oil change, changed the filter at 25k. The oil was still good at 49k, but decided to change it anyway. That was Amsoil Sig. Not sure how the current Toyota oil compares with Amsoil now though.
    jtwags likes this.
  23. Dec 7, 2024 at 9:51 AM
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
    Every mower I’ve bought in the last 25 years didn’t have a drain plug. Always had to take the fill hole thing out and turn mower on its side
    22whatwedo and WILLINH like this.
  24. Dec 7, 2024 at 2:18 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    Off topic again. Is it a push mower? My Briggs is a push mower that is a no oil change engine. Tilt it in its side. It takes a half a qrt.
  25. Dec 7, 2024 at 3:08 PM
    Mr Badwrench
    Yeah it's an "even cut" brand (made in chy-nuh) belt-driven field push mower. Not self propelled. It's got the 6.5 Briggs, haha they don't even rate them in horsepower anymore, it's 6.5 something though :confused:
    Sorry OP, I derailed your thread! But it looks like there's a special on Amazon. 5 qts of 25000 blend for $29.99. Even if you change it at 5,000 miles, you can break even $$. I'd be more concerned about the filter after 10,000 miles. Looks like they make long life filters though.
  26. Dec 7, 2024 at 4:02 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    I don’t mean to hyjack either but I use Briggs 5W30 in mine.
    Mr Badwrench[QUOTED] likes this.
  27. Dec 7, 2024 at 4:23 PM
    GREENPUS
    GREENPUS New Member
    Scott
    Yeah me too but to save money you can also take the old used oil from your truck and dump it in your mower :rofl:
  28. Dec 7, 2024 at 4:31 PM
    Breathing Borla
    Northern Illinois
    Won’t be me, I just hit Toyota up every 5k done , nice waiting room anyways
    jtwags, MEGA VOL and WILLINH like this.
  29. Dec 7, 2024 at 4:46 PM
    Mr Badwrench
    I've been using straight 30W, probably no distinguishable difference since we probably mow in the warmer months. The last time I drained it, the oil looked like silver paint, that was my break in oil though. Lots of particulate, granted there is no filter. I couldn't imagine running that dirty oil for very long. My last mower was a two stroke Lawn Boy from the early 1980's! Then it lost compression :( I still have it, I can't let it go :rofl: Wish I could find over sized rings, I'd rebuild it just for fun and nostalgia. The tires actually went bald from use. They had little diamond shapes, now they are slicks.
  30. Dec 8, 2024 at 11:42 AM
    GREENPUS
    GREENPUS New Member
    Scott
    I bought a rebuilt 70’s lawn-boy. Loved that thing. After 15 years it shot the shit and died. I bought a new Lawn-boy and it was the biggest POS. Toro f’d up big time with LB. I put up with the POS for a few years because I paid a lot for it and didn’t want to throw it out. Finally had enough and bought a $1200 Honda push mower. OMG. That thing is a dream. I’d never pay that much for a push mower again but dam, I’m glad I did lol
    22whatwedo likes this.
