  1. Dec 6, 2024 at 12:11 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Took three telephone calls over three days but got the CV axle boot kit ordered. Apparently their computer system screwed up and cancelled my internet order. Should have it here Monday.
  2. Dec 6, 2024 at 12:37 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    So funny you say that, because I created mine out of that very thing, 2 big tree pots :rofl:. Truck came w/o any liners. They have held up really well!
  3. Dec 6, 2024 at 12:47 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  4. Dec 6, 2024 at 12:56 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Not as red as Tickle, but a bunch of self tappers were involved. I actually used stainless bolts where it mounts to the fender, so that kind of balances it out.
    I didn't have cable, but I found a "way" to watch that series for a while... if just to see how funny/drunk Tickle would be.:rofl:
  5. Dec 6, 2024 at 1:36 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Yeah got some onsale mobile full synthetic. But double the price to not have to swap a rear main may be worth considering if M1 seems have the seal conditioner.
  6. Dec 6, 2024 at 1:55 PM
    Bed Tundy
    Bed Tundy Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    Heyyyyy quick question here, about to drop the rear axle from both leaf springs, any reason I’d need to do just one at a time?
    like, keeping one sides leafs U-bolted to the axle so it doesn’t move backward or side to side or something?
    the jack under the axle has everything snugged up and in place right now, I’m just an amateur mechanic and am worried I’m seconds away from causing a lot more work
  7. Dec 6, 2024 at 2:11 PM
    No worries from a rear axle alignment standpoint. The pins will center it on the new leafs. I personally just did one side at a time so I didn’t end up wrestling with any of it, rotating and what not.
    805Tundra, PNW15, ToyotaDude and 3 others like this.
  8. Dec 6, 2024 at 2:11 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
    Welllllll shoot. Guess I’ll U-bolt one side back on. Glad I checked
    ToyotaDude and oscardog86 like this.
  9. Dec 6, 2024 at 2:14 PM
    oscardog86
    oscardog86 New Member
    Southern California
    What are you trying to do? Im an amateur mechanic as well but Ive done struts and leafs back there and I always did one side at a time. I didnt see any reason/benefit to dropping the whole axle and every instruction I read stated to do one at a time. Dont know what it would cause if you did drop the whole axle but I guess it could make things more difficult if it didnt line up correctly anymore.
    Bed Tundy[QUOTED] likes this.
  10. Dec 6, 2024 at 2:19 PM
    I've heard more than one person say it's easier to do one side at a time.
    PNW15 and Bed Tundy like this.
  11. Dec 6, 2024 at 2:19 PM
    I mean, in all honesty, if you drop the axle out of the way, then mount up both of the leaf packs, then lift the axle up to the leaf springs, it seems like it would be way less finagling.
    The unfortunate part about doing one side at a time is you are limited on all the space you have available. I was able to get it done (it's how I've always done it), but there was a lot of lifting/dropping the axles with other jacks to be able to wedge the leaf pack in.
    Bed Tundy likes this.
  12. Dec 6, 2024 at 2:26 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I've done it one side at a time when I've done it. You may not run into this issue, but it helped me to keep the axle aligned when re-installing. Also, it creates a bit of a lever and drops one side further so you have more room to work. Good luck!
    oscardog86 and Bed Tundy[QUOTED] like this.
  13. Dec 6, 2024 at 3:29 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    No pics, but took advantage of some Black Friday deals. Got the desert does it seat jackets and oh my god it’s so much more comfortable. Much better support.
  14. Dec 6, 2024 at 3:38 PM
    The Black Mamba
    DFW
    Imma keep it stock
    luv u
  15. Dec 6, 2024 at 3:40 PM
    The Black Mamba
    DFW
    Imma keep it stock
  16. Dec 6, 2024 at 3:41 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I’m creeping up on it. 27x,xxx.
  17. Dec 6, 2024 at 3:55 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
    I would have gone this route but I’m limited in my number of available jacks haha. Im halfway there
    One side at a time was great, the axle gives me a place to rest the leafspring, which is really heavy! I appreciate the lever.
  18. Dec 6, 2024 at 3:57 PM
    Definitely one side at a time, the entire axel wants to roll forward and becomes a pain in the ass to deal with
  19. Dec 6, 2024 at 4:14 PM
    Chrisfrom1986
    Chrisfrom1986 New Member
    Central CA
    06 AC SR5
    Yeah it's 150a. Not sure how much of a difference it makes but I still need to replace the negative terminal. The voltmeter is moving around a lot more than I'm comfortable with.
  20. Dec 6, 2024 at 4:17 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I did both at once and kind of wish I hadn't. With the right setup it might be better, but with limited equipment and one person, I think one at a time is better. Once you have both off, the axle is just kind of flopping around back there...
  21. Dec 6, 2024 at 5:06 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Good to know, for when I'm ready to up the ante on my 06's electronics
  22. Dec 6, 2024 at 5:45 PM
    MT-Tundra
    Montana
    Brought home a new chest freezer to store game, and picked up some very heavy duty saw horses along the way, to rest the truck camper on. Guess my plastic tailgate handle was feeling old and brittle, and the saw horses must have been resting with more weight on the tailgate than I thought. Pulled the handle, heard a snap, handle went floppy. Another project.
  23. Dec 6, 2024 at 8:29 PM
    bfunke
    bfunke Tundra Curmudgeon
    Wait till you see the price of that handle.
    bmf4069 and oscardog86 like this.
  24. Dec 6, 2024 at 10:47 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Not today, but yesterday replaced the 24f battery I had installed temporarily (4 years ago...) with a 27f.
  25. Dec 6, 2024 at 10:49 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    What type/ brand you go with?
  26. Dec 6, 2024 at 10:52 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    One from a local parts house, down the street from the shop. FMP/factory motor parts, they just label one made by the big 3. Just a normal lead acid.
    des2mtn[QUOTED] likes this.
  27. Dec 6, 2024 at 11:17 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    What’s the difference?
    I replaced my 24f a couple years ago with a 27f, really just because the number was bigger and it fits. Did the “cold weather package” get the bigger battery?
  28. Dec 6, 2024 at 11:33 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Slightly larger and more capacity (think Amp hour, not actual cranking amps).
  29. Dec 7, 2024 at 6:37 AM
    Pro tip: use your trucks OEM bottle jack to help lift the spring and be an extra pair of hands. Mount one side, I find hanger side was easier, then move jack to the other side and lift the other end of the spring into place, bolt it up. Gas tank side is the worst. Once both sides are bolted in, use floor jack to life axle up to the leaf pack and u-bolt it. Easy peasy.
  30. Dec 7, 2024 at 7:01 AM
    MT-Tundra
    Montana
    I've been wondering...I remember when my Tacomas door handles hit their expiration date. I went aftermarket to avoid OEM expense. I think after replacing the handles about once a year from there on, I finally added up costs and decided OEM was worth it after all...
    oscardog86, Desert Dog and shifty` like this.
