A340E/F INFO DUMP
Discussion in '1st Gen Tundras (2000-2006)' started by The Black Mamba, Dec 6, 2024.
  1. Dec 6, 2024 at 8:26 AM
    The Black Mamba
    The Black Mamba [OP] A pure specimen of TX Black Snek
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    A340E/F INFO DUMP
    While the above is a true and accurate statement, if you do find yourself in need and are searching used units, not all configurations of the A340 transmission are the same. These are things I learned in the process of finding a unit for my truck that may help someone later on.
    This thread will serve for information related to the AISIN A340E/F 4sp transmissions found in our 2000-2004 3.4 (5VZ-FE) V6 and 2000-2004 non-VVTi 4.7 (2UZ-FE) V8 engine First Gen Tundras.
    Transmission Info
    The A340 (A340E, A340F, A340H) and the AW4 are sister transmissions. The AW4 is commonly found in Jeeps, such as 1987-2001 Cherokees.
    The A340E, A340F, A340H transmission is found in Toyota cars, trucks and SUVs and a few Mitsubishis, Kias, Lexus cars and SUVs, and Volvos.
    Applications
    Some models of these vehicles have an A340 transmission:
    • 1992 to 2010 Toyota 4Runner
    • 1992 to 1998 Toyota Supra L6 3.0L without Turbo
    • 1993 to 1998 Toyota Supra L3 3.0L with Turbo
    • 1993 to 1998 Toyota T100
    • 1995 to 2017 Toyota Tacoma
    • 2000 to 2004 Toyota Tundra
    • Some 1990 to 2005 Kia, Lexus, Mitsubishi and Volvo
    Some international vehicles, such as Soarer
    Transmission Info Continued
    The A340 was offered in 3 different casings (depending on year and application). For the sake of this thread, our trucks (at least mine being a 00) have/has 4 valve passages evidenced on the left side of the transmission assembly. Older A340s have 3 and newer A340s have 4 with no provision for the kickdown cable. This information will pertain to the style of valve body that it is able to accept. Only casings of the same style will accept the same style valve body. See pic below
    Pans
    There are 9 different stock pans. These 9 stock pans have 4 different depths and 7 different dipstick receiver heights and angles. There are 13 different filters and 15 different valve bodies.
    Here is an image showing at least 3 different pan styles
    I have also read that some vehicles equipped with an external trans cooler will come factory with a shorter pan. This could give you an option later on to swap to a deeper pan for larger capacity and better cooling purposes. It’s a popular mod with the MKIII Supra owners to swap the pan for one from a GS300 with no further modifications needed other than adjusting for the extra fluid.
    Below is a deep pan from an A340 w/o external cooler
    Below is shallow pan from an A340 with factory external trans cooler
    Back to FGT A340E/F Info
    For the sake of our trucks, there are 2 different bellhousings and the block you have will determine the bell housing you have. V8s will be stamped on top with UZ and V6s will be stamped with VZ. See pic below.
    There are also 2 different tail shafts available depending on your drivetrain. The skinny tail shaft is for 2WD trucks, while the fatter, more flared out tail shaft will accommodate bolting up to a transfer case and is for 4WD trucks. (This should be common sense, but I figure the more info, the better)
    The “E” in A340E indicates that it is a 2WD trans and the “F” in A340F indicated that it is a 4WD trans. This info can also be found on the trucks VIN plate as 2WD trucks will be stamped VCK30 and 4WD trucks stamped VCK40.
    It is possible to convert a 2WD trans to a 4WD capable trans by swapping the tail shaft, valve body and trans pans, but I will not cover that here. It is also possible to swap the bellhousings, pans and valve bodies from a VZ truck to a UZ truck and visa versa. It is also possible to swap bellhousings, tail shafts, pans and valve bodies from other A340 equipped vehicles provided there share the same casings.
    Other A340 Related Info
    Each A340 will be equipped with a sticker on top of the trans letting you know what series it is and also a corresponding model tag can be found on the right rear of the case half. (See photos below.) Only those that precede with a serial number of 35000 are compatible with our trucks. The second number and the number printed on the sticker will indicate the valve body and trans pan configuration. The correct valve body is necessary in order to properly communicate with the ECM.
    Valve Bodies
    Lastly, I’ll cover valve body types. As stated earlier, there are 15 different valve bodies available for the A340 transmission depending on year, drive, casing and factory equipment such as tow package, ABS, ect…
    Below are a few examples. The most important thing to note is that each style valve body has a different casting ID number (mine is 8931). You MUST use a VB with the same casting ID as what your truck came with when doing a straight swap or else the ECM will be unhappy and at best, you'll throw a DTC for shift solenoid (P0773). This info is not accurate if doing a swap for modification purposes.
    Note that pic #3 is the type/style that is in our A340 equipped FGTs
    Repair Manual
    A340 Repair Manual can be found HERE.
    Here's a copy of the FSM. All A340 info can be found from pages 408-448
    Please feel free to add to or correct any info as you see fit. This will only help aid our knowledge going forward.
    Anima, BubbaW, BroHon and 14 others like this.
  2. Dec 6, 2024 at 9:09 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Wow, I'm very impressed with this post
  3. Dec 6, 2024 at 10:12 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
  4. Dec 6, 2024 at 10:16 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    G_unit3000, Anima, BroHon and 6 others like this.
  5. Dec 6, 2024 at 10:21 AM
    AmericanKing06
    AmericanKing06 New Member
    New Mexico
    04 Toyota Sequoia aka Dadwagon
    Great write up and attention to detail. Now my head is spinning if I should add the larger pan to my Sequoia. I wonder how many quarts it'll add?
    Tundra2 and The Black Mamba[OP] like this.
  6. Dec 6, 2024 at 11:02 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    I got lucky!
    FGT VB ID 8931
    T4R VB ID 8931
    Winner Winner Chicken Dinner!
    Anima, BroHon, JakeJake and 3 others like this.
  7. Dec 6, 2024 at 11:20 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    I should also note that the A340 has AT LEAST 2 different inhibitor switches available (could be more)
    FGT Inhibitor Switch (also know as a neutral safety switch)
    Donor T4R Inhibitor Switch
    Due to the different harnesses, these are not interchangeable, but are easily swapped from one transmission to another.
    shifty` likes this.
  8. Dec 6, 2024 at 12:02 PM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    This pic here will illustrate the difference in filters. FGT deep pan filter left, T4R shallow pan filter right. I'm not reusing either one of these, btw.
    KNABORES likes this.
  9. Dec 6, 2024 at 1:41 PM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    Other various info from the owner's manual that will be redundant to most, but I felt beneficial to at least have it here.
    upload_2024-12-6_15-40-26.png[​IMG]
    G_unit3000, Anima and AmericanKing06 like this.
  10. Dec 7, 2024 at 8:37 AM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    Thx for posting this info.
    The Black Mamba[OP] likes this.
  11. Dec 7, 2024 at 8:50 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    shifty` and The Black Mamba[OP] like this.
  12. Dec 7, 2024 at 10:48 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
  13. Dec 30, 2024 at 10:55 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    For science, this is what the internals of an A340 look like
    The piece in this next pic is related to my failure. That should be solid and smooth on top
    G_unit3000, BroHon and FrenchToasty like this.
  14. Dec 30, 2024 at 11:26 AM
    Still kinda jealous of y'all with the 4spd. I guess I should Google around and see if it's possible to add a dipstick to the A750f and have it actually be functional.
  15. Dec 30, 2024 at 11:33 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    Oh, I found this neat little diagram
  16. Dec 30, 2024 at 11:44 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    Check with PML. They have a deep pan for the A750 and A760 with provisions for a temp sensor. Might be able to adapt that for a dip stick tube(?)
    shifty`[QUOTED] likes this.
  17. Dec 31, 2024 at 10:55 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    G_unit3000 and FrenchToasty like this.
  18. Dec 31, 2024 at 11:57 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    So approx. how much do you charge to rebuild? Lol *wink*
  19. Dec 31, 2024 at 12:08 PM
    It’s insane what Toyota charges if you need to replace a shift solenoid.
  20. Dec 31, 2024 at 1:39 PM
    Desert Dog
    That's probably all manufacturers. I had a mid-90's Pontiac Bonneville SSEi that needed a solenoid replaced. $30 part. ~$800 labor. In 90's dollars.
  21. Dec 31, 2024 at 2:05 PM
    Haha…sorry, I just meant the part alone was $200 each, IIRC from a member’s last post. Might as well source a fully rebuilt transmission if you want Toyota to do the work.
  22. Dec 31, 2024 at 2:29 PM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
  23. Dec 31, 2024 at 2:49 PM
    How does that compare to the work of tearing apart the transmission to replace a solenoid?
  24. Dec 31, 2024 at 3:45 PM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    It doesn’t but the dealership will not rebuild, only replace
  25. May 2, 2025 at 3:13 PM
    Anima
    Anima New Member
    2000 TRD Tundra V8 4x4
    The amount of information is very impressive Mr. Mamba! Thank you!
    I found this post while searching for some information on my hard shifting transmission. My 2000 4WD AC shifts hard from 2nd to third. It only happens from 2nd to 3rd. All other gears shift smooth. The truck has 269k on it. I bought it at 265k to i have no idea how the previous owner maintained it. I do know that he took it to a shop that did a flush and fill (no filter change) at 250k because I found the receipts.
    What happens, is that if I am at 2k RPM's it shifts semi-decent, but if i am at 2k to 4k RPM's it shifts so hard its like someone took a sledge hammer and banged it on the floor. However if you accelerate up to 4k RPM and then back your foot off the gas, it will shift semi-decent. So I feel like it has something to do with the throttle, but I'm not sure. My few hours of research has led me to think it might be a shift solenoid no. 2 (S2). I'm headed to a junk yard tomorrow to see if I can find some parts on 2 other 2WD Tundras at my local junkyard. Otherwise I might just buy some new shift solenoids. I found a nice diagram that I wanted to share, but I also wanted to see if anyone could confirm this is a shift solenoid problem?
    Thanks again for all the help!
  26. May 2, 2025 at 3:28 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Have you checked that they actually put proper amount of fluid in ?
    Fortunately 00-04 have a dip stick....should be up to temp and idling in park to check it.
  27. May 2, 2025 at 3:33 PM
    Anima
    Anima New Member
    Yep.
    Level ground. Cycled through all the gears P-L, then back to P. Checked the dip stick and it was fine. No burning smell. No codes. All other gears shift fine. Just that damn 2nd -3rd that's giving me a problem.
    BubbaW[QUOTED] likes this.
  28. May 2, 2025 at 5:37 PM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    Before you go to the trouble to buy anything, download a copy of the field service manual and do a search for harsh engagement. The automatic transmission section will actually give you a flow chart to follow and tell you what is most likely wrong so that you are not guessing
    Anima and BubbaW like this.
  29. May 3, 2025 at 9:03 AM
    Anima
    Anima New Member
    if you’re referring to the flow chart on page 410. I don’t really understand what I’m looking at? I know that sounds pretty ignorant, but would you mind providing a little bit of insight?
  30. May 3, 2025 at 1:25 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    This is pretty informative.. I'm wondering if the 'kickback wire' is applicable from other models to the Soarer...
