  1. Dec 5, 2024 at 5:53 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Living just West of Erie Pa., all I have done is snow blow most of the days. We have gotten 70+ inches since 11-29 and we are supposed get another 20 inches today. As I write this we are in the middle of a blinding blizzard with wind gusts of 60 mph. Erie is paralyzed. No end in sight until sometime next week. Glad I retired from nursing because if I was still working in the hosp. you'd never get home. As a nurse,you don't just get to leave if staffing isn't in place for the next shift. You might be stuck there for days.
    j-utah, TaquitoBandito and blackoutt like this.
  2. Dec 5, 2024 at 6:02 AM
    Kung
    KG, VA
    I'm not anywhere near as knowledgeable as others are concerning HVAC, but even if the issue you're experiencing is not related to insulation levels, I will again recommend verifying that you have sufficient insulation (not sure if you mentioned that anywhere) in your attic.
    Once I got the local insulation firm out, they told me that not only had our insulation compressed over time and lost its effectiveness, but there were also some areas where we flat out had *no* insulation. They blew in a ton more insulation; I think we're at like an R-53 level right now.
    The difference is SUPER noticeable. For example, last winter, if the outside temp was 20 degrees, the heat pump would run for an hour or two in order to get the temperature from 68 to 70 or so. It'd then drop from 70 to 68 in 5 minutes or so, and the cycle would repeat. Not optimal, to say the very least.
    Now? Due to the increased insulation, the heat is retained longer...so not only will it heat up in 30 minutes or so, instead of an hour or two (since it's not fighting against poor insulation, therefore there's nowhere near as much heating/cooling loss), it takes far longer to drop in temp - we're talking 30-40 minutes, instead of 5 minutes. :)
    bmf4069, TaquitoBandito and TomC843 like this.
  3. Dec 5, 2024 at 6:12 AM
    Definitely possible. Thinking it through a bit more, if he was low or overfilled on refrigerant, maybe the compressor is responding to that.
    I'd be tempted to look at levels, but again, not enough info on condition to make an educated guess at this point.
  4. Dec 5, 2024 at 8:36 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
  5. Dec 5, 2024 at 8:44 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Let's see some snow carnage pics Don!
    Had some friends get re-routed further south last weekend. I miss living in the northeast, sounds like a blast!
    TaquitoBandito, OldGuy03 and KNABORES like this.
  6. Dec 5, 2024 at 2:14 PM
    Supposed to be resting today…nah. Time to put up a tv on my study for cameras and streaming
  7. Dec 5, 2024 at 2:54 PM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    temp inside is where it should be. so what im saying is the house is cool
  8. Dec 5, 2024 at 3:16 PM
    Florida AF
    Logan
    North Florida
    Love the rough posts... Truly love that look. I will be building one for next year and may try to find something like that for mine.
    TaquitoBandito likes this.
  9. Dec 5, 2024 at 3:19 PM
    Florida AF
    Logan
    North Florida
    Today was one of the fun projects. My neighbor drove over last week and said, I need these attachments for my tractor. I know you will also need tines for the new building, so can you find some to buy? Then he handed me a wad of cash and said he didnt feel like shopping around. So I got to buy stuff with someone elses money, and even give him money back because I found a better deal with the discount weeks...
    So, unboxed these and loaded the trash into my trash runner for tomorrow...
    This is a quick attachment adapter that makes using multiple PTO attachments easier:
    And then, the new tines:
    And then we went to town and bought more distilled water, formula and diapers. Maybe momma a bottle of wine too.
  10. Dec 5, 2024 at 3:47 PM
    Replaced the wife’s bathroom GFCI with one that has usb, and usb-c so she can stop using my side for her damn mirror
    j-utah, Florida AF, Kung and 3 others like this.
  11. Dec 5, 2024 at 5:01 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Maybe I'm old no I am, since when do mirrneed USB ports?
  12. Dec 5, 2024 at 5:13 PM
    It’s one of those portable ones that plug in and have diff colors of light or something. Wife and daughter both have one…and they aren’t cheap
  13. Dec 5, 2024 at 5:15 PM
    I think it’s this or similar.
  14. Dec 5, 2024 at 5:40 PM
    Ditto. Or similar. And we have to close the bathroom door when she is charging it because the ring around it glows red until it’s charged, and switches to green. Annoying as hell! I hadn’t thought about putting one in the barhroom vanities, then I’d need to get cables for them I bet. She wouldn’t understand they just carry over.
  15. Dec 5, 2024 at 5:57 PM
    I put together a vanity desk for our daughter. Big ass mirror with the led light around it. It’s pretty bright
    KNABORES and TaquitoBandito like this.
  16. Dec 5, 2024 at 6:07 PM
    bfunke
    bfunke Tundra Curmudgeon
    Those are beautiful. BTW I used to live in SAT and one of my favorite restaurants in the old Fincke Meat Market building on Josephine St. Any relation to E.J Fincke?
  17. Dec 5, 2024 at 6:10 PM
    JMB
    Chesapeake, VA
    Goddam 120 for a mirror..?!!?!?!
  18. Dec 5, 2024 at 6:14 PM
    bfunke
    Try this:
    Leviton T5636-W 60W (6A) USB Dual Type-C/C Power Delivery In-Wall Charger with 15A Tamper-Resistant Outlet, USB Charger for Smartphones, Tablets, Laptops, White
  19. Dec 5, 2024 at 6:26 PM
    We installed these in the kids bathroom, and in the gym bathroom. But my better-3/4 has one of the portable round ones that charges via cable, and we have a wall mounted 6’x4’ mirror in the master. These have touch sensitive buttons on the glass to defog the mirror and for the outer light ring. Light is on with one to demonstrate. They were less expensive than I expected. Pretty solid quality.
    j-utah, Florida AF, bmf4069 and 3 others like this.
  20. Dec 5, 2024 at 6:32 PM
    NWPirate
    Zach
    WA
    Needed a easier way to get water out to the animals this winter.. added a hose bib after the main shutoff in the garage. Threw a gauge in there too for shits and gigs.
  21. Dec 5, 2024 at 6:36 PM
    Those are nice. Did you tie in power from the outlets below?
  22. Dec 5, 2024 at 6:40 PM
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    Have a link for those?
    T-Rex266 and TaquitoBandito like this.
  23. Dec 5, 2024 at 6:42 PM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    Thanks, and yes EJ Fincke was my great grandfather. My wife and I always like going there for dinner when we can.
  24. Dec 5, 2024 at 6:51 PM
    Power is fed to the mirrors from the 2-gang wall outlet, which is a different, non-GFCI circuit than the receptacles you see there. As stupid as it is, the half bath almost directly downstairs feeds those two wall outlets shown. The sparkies who originally wired this house figured, “ah screw it, the half bath only needs one outlet… let’s run from the box, up 5ft to the half bath and drop a GFCI to start the circuit, then feed the master and guest bath 5ft upstairs from there!” Proper wiring for the GFCI at the time, only the 1st outlet in the run needs a physical GFCI outlet w/ buttons. But yeah, it was really fun when we remodeled, tracing back how all the upstairs and bathroom outlets were teeing off. Wiring new circuits is a FPITA having three stories, main panel in the bottom floor.
  25. Dec 5, 2024 at 8:47 PM
    It's upside-down.
  26. Dec 5, 2024 at 8:52 PM
    The outlet? No..
    Edit; ha I guess so. Oh well.
  27. Dec 5, 2024 at 9:00 PM
    NWPirate
    Zach
    WA
    Your ocd won't be able to handle that :rofl:
  28. Dec 5, 2024 at 9:03 PM
    Ya there’s a good chance in the near future I’m gonna turn it back :laugh:
  29. Dec 5, 2024 at 9:09 PM
    NWPirate
    Zach
    WA
    :D:fistbump:
  30. Dec 6, 2024 at 4:19 AM
    Just giving you shit. It's fine either way, but I prefer ground down. You see ground up more in commercial. The NEC even says ground up is recommended, but both ways are fine. Do what makes YOU feel good.
