  1. Dec 3, 2024 at 3:50 PM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    I have a slight gasoline smell on the passenger side, can't see any leaks. Wonder if I may have the same type of thing happening? I might check the injectors to make sure they're seated all the way.
  2. Dec 3, 2024 at 5:01 PM
    Give em a rotate back and forth
    ATBAV8[QUOTED] likes this.
  3. Dec 3, 2024 at 8:13 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Hope everyone has been well!
    Ordered a new bike and needed a frameless contact way to haul it. Found some 2.5G billie bars on marketplace with bike mounts. Cut the extrusion down to fit. Guess I'm going back to a cheap roll up bed cover lol.
    Don't mind the mess. I've got too many projects going on at the house currently lol.
    FishNinja, oscardog86, BroHon and 3 others like this.
  4. Dec 3, 2024 at 8:26 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I saw you posted your bed cover, but that stupid FB group doesn't let me post or reply for some reason. It auto declines everything I type. Anyways if not for spending so much on parts recently, I'd be all over that, because I'm supposed to be meeting Mamba this weekend to give em my old LSD.
    khooiii[QUOTED] likes this.
  5. Dec 4, 2024 at 12:56 AM
    Big Red15
    Big Red15 New Member
    Jackson
    2005 Double Cab 4x4 Tundra
    Auxbeam Light Pods Bilstein 5100s Flowmaster 40 Series Muffler Wildpeak AT4s
    I put some Christmas lights and a wreath on tonight but they draw so much power I have to use an external battery for them
    NUDRAT, Tlar25, whodatschrome and 8 others like this.
  6. Dec 4, 2024 at 6:53 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Holler at me I don’t live too far from his neck of the woods.
  7. Dec 4, 2024 at 7:21 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    G_unit3000 likes this.
  8. Dec 4, 2024 at 10:07 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Probably meeting in Huntsville. Maybe grab a bite.
  9. Dec 4, 2024 at 1:29 PM
    New starter is quick and smooth. Glad I went ahead and swapped it out. No return of the gas leak on injector two either. Still have some driveline rumbles. U joints are next on my list
    ToyotaDude, bmf4069, ATBAV8 and 4 others like this.
  10. Dec 4, 2024 at 2:07 PM
    bfunke
    bfunke Tundra Curmudgeon
    Seem just fine to me. I have a little over 250K on my truck and I can’t remember what brand I used last time. I still have OEM calipers and have not done the upgrade. My pedal and braking seems good to me.
  11. Dec 4, 2024 at 2:11 PM
    bfunke
    This ought to be ban-worthy from our site! Merry Christmas.
    BroHon likes this.
  12. Dec 4, 2024 at 2:14 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Finally got the camper off. Actually really relieving. Truck is happier. Leaf springs may be old and tired, but I'm glad to see no sag back there. They sprung right back up.
    I'm getting quite a stockpile in the parking lot...
  13. Dec 4, 2024 at 2:21 PM
    Swapped chrome for black lugs and put the modified center caps back on. Will refinish the caps and add the heritage strips later.
    Before
    After
  14. Dec 4, 2024 at 3:09 PM
    MT-Tundra
    Montana
    What lug nuts? Interested to hear your experience. I did a lot of searching for black lug nuts that weren't total crap. Didn't come up with much. I bought some anyway. They worked, but hitting them once with the impact wrench was enough to scrape the paint and cause a lot of corrosion after just one winter.
  15. Dec 4, 2024 at 3:14 PM
    The lugs with a finish on them tend to come with instructions not to use an impact on them. Mine specifically said to use a lug / torque wrench only, no impacts.
  16. Dec 4, 2024 at 3:57 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Looks awesome! They don’t make those wheels anymore do they?
  17. Dec 4, 2024 at 4:45 PM
    shifty` Goons of Hazzard
    Sounds trippy.
    PNW15, bmf4069, CodyP and 1 other person like this.
  18. Dec 4, 2024 at 5:09 PM
    Chrisfrom1986
    Chrisfrom1986 New Member
    Central CA
    06 AC SR5
    Installed another used denso alternator from the sequoia I parted out after finding out the plugs are the same from 03-07 sequoia as 05-06 tundra.
    Everything tested good before install but I'm still getting a little movement on the voltmeter. Still need to replace the battery post but I dont have a way to crimp the wire right now.
    Steering bellows have been waiting for install too but I've been trying to wait out a move that's still weeks out.
    oscardog86 and 455h0le_dachshund like this.
  19. Dec 4, 2024 at 5:27 PM
    Hard to find them with the faux beadlock, but they still make the 8 hole wheels.
    Filthyphil[QUOTED] likes this.
  20. Dec 4, 2024 at 5:39 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Good to know. Isn't the Sequoia alt more amps or something?
  21. Dec 4, 2024 at 11:49 PM
    Bed Tundy
    Bed Tundy Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    Fit the tundra in my tiny garage today after much reorganizing. Had to take the light bar off the topper to get it in. After the rear lift gets installed the whole topper might need come off to get it back out, But it beats getting snowed on if I get stuck halfway through outside. Un-installed my front diff drop and safety tucked it back up above the skid plate. Made small steps to prepare for the removal, hit everything with wd40 and managed to crack all leaf spring eye bolts loose, greased all zerks, and stuffed 2 stumps under the tow hitch to keep the rear tires suspended. I’m not trusting harbor freight jack stands on this unlevel dirt floor. Parked it in 4hi and chalked the front tires. Realized we don’t have a locking center diff? I can spin the back tire and the other tire rotates the opposite direction.
    set up the 5160’s how Bilstein recommended.
  22. Dec 5, 2024 at 12:38 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    You're able to rotate the other rear tire? That's normal. If our trucks had a locking rear diff, then you wouldn't be able to spin both.
    A center diff would allow the front and rear driveshafts to spin at different speeds. There isn't a center diff at all in our trucks, so anytime the transfer case is in 4WD, both the front and rear driveshafts are locked together and rotate at the same speeds.
  23. Dec 5, 2024 at 8:26 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I did mine how you did the left Billy. I also got the fancy billet retainers :thumbsup: :cool:
  24. Dec 5, 2024 at 9:21 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I might make something happen today…
    Hey @shifty` , I can just use standard ATF, right? :rofl:(I’m kidding, don’t do this! DexronII or III)
  25. Dec 5, 2024 at 9:22 AM
    No work done yet but goodies have arrived. Hopefully temps will be favorable this weekend for laying on cold semi-underground garage floor
    oscardog86, bmf4069, KNABORES and 2 others like this.
  26. Dec 5, 2024 at 9:28 AM
    FiatRunner
    Jack
    What in the heck takes 3 gallons of oil?! Don't our trucks take like 6qts...?
  27. Dec 5, 2024 at 9:35 AM
    You don't fill it up, run it for 30 minutes at 3K RPM, then flush it, and add new oil? How else are you supposed to get it SUPER CLEAN? :rofl:
  28. Dec 5, 2024 at 9:38 AM
    FiatRunner
    Jack
    I believe in the Italian Tune Up. They say it only works on Italian vehicles but I'm a True Believer. No need for oil flush.
    NUDRAT and 455h0le_dachshund like this.
  29. Dec 5, 2024 at 9:47 AM
    I tend to buy enough for 2 changes in advance if 5qt. In this case, Walmart free ship limit is $35, which meant I had to buy two anyway, and at that point, if shipping is free, may as well add the 3rd so you can get another change out of it. Then the time after, I'll buy 5qt locally and use what's left in the 3rd bottle. But this is more of a "wanna test it out", and I think 2 OC is more reliable test than 1 OC.
  30. Dec 5, 2024 at 9:48 AM
    Italian tune up 100% worked on my 1992 BMW also.
    FiatRunner[QUOTED] likes this.
