Rear window
Discussion in '3rd Gen Tundras (2022+)' started by Puddin1973, Dec 5, 2024.
  1. Dec 5, 2024 at 6:47 AM
    Puddin1973
    Puddin1973 [OP] New Member
    24 tundra
    First time using rear window, on accident. Now it won't go up. ... watched several videos and nothing is wrking. Any suggestions it is also 30 degrees out.
  2. Dec 5, 2024 at 6:55 AM
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    Is the window lock switch maybe turned on?? Just a pure guess, no clue if that switch locks the back window or not
    Puddin1973[OP] likes this.
  3. Dec 5, 2024 at 7:01 AM
    Rear passenger window? Or rear glass at the back of the cab?
  4. Dec 5, 2024 at 7:53 AM
    Puddin1973
    24 tundra
    Rear glass at back of cab.
    KNABORES likes this.
  5. Dec 5, 2024 at 8:12 AM
    Rockpig
    Rockpig You did what?
    08 Limited
    Does it move at all? Maybe something is hitting it when it tries to go up like the third seatbelt buckle. Check the track and make sure nothing is in the way and fold down the back rests to ensure that's not causing something to hit it.
