General Supercharger Thread
  1. Dec 3, 2024 at 7:29 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Either way, it looks like zipping the tunes/logs will allow us to share them here as well as comparing the differences in HPT so that we can make our own edits to the tune we're running with the caveat that the tune being shared is unlocked. If it isn't, we won't even be able to look at the tables.
  2. Dec 3, 2024 at 8:15 PM
    Anyone running methanol injection?
    I'm having some heat soak issues on my SC'd Mustang that I didn't think I would have under 75*F Where are you injecting? Been looking at port injection, and it seems to be the way to correctly do this. Others have had good success in other locations.
    I have also looked at different functional hoods that would help with heat removal. Already have functional fender vents that are working overtime.
  3. Dec 3, 2024 at 8:24 PM
    blenton
    blenton New Member
    Sonnax Zip Kit and Line Pressure Booster ordered...
    My ECU ID lacks most of the transmission options to tune with, so I think the Sonnax kit is a good place to start. Thanks @pursuit2550 for leading the way and helping me get a few things sorted out. Hoping to install over Christmas or New Years after I've finished up a few projects at work and have some downtime with the truck.
    Luckily, my recent transmission D&F looked pretty good (visually) so I'm hoping this is more preventative than anything. I'm also very curious to inspect the VB for wear; I'm sure there are worn parts, I just want to know WHAT parts and HOW MUCH..
    ARES35, pursuit2550 and Mdl like this.
  4. Dec 3, 2024 at 8:27 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'm injecting 500cc after maf before throttle body. Only using a 70/30 w/m mix on a single nozzle. It's a simple setup but aqua mist with multiple injectors would be ideal.
    In spring I'll be opening my hood right above the radiator with vents/louvers.
  5. Dec 3, 2024 at 8:33 PM
    I have been looking at ALKYControl, ProMeth, and Snow. Seems to be the ones these donkey owners have been using.
    e30cabrio, ZPhilip and Mdl[QUOTED] like this.
  6. Dec 3, 2024 at 9:43 PM
    JustDSM
    JustDSM New Member
    Justin
    We can add any changes you want in the background. Send me a message with what you want in any specific table and I can make those edits “behind the scenes” even if you don’t have access.
    e30cabrio, Mdl and blenton[QUOTED] like this.
  7. Dec 3, 2024 at 10:04 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    They dropped my IAT delta, I'm happy with them.
    Silver17[QUOTED] and Mdl like this.
  8. Dec 3, 2024 at 11:25 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I emailed them but have not heard back on thelead time for the aluminum spacer. Guess i could call. What was yours? Thanks!
    e30cabrio likes this.
  9. Dec 4, 2024 at 3:57 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    <cannon fodder post>
    113k miles on trk
    88k miles on Harrop S/C
    changed plugs
    changed coolant.
    changed pads & rotors.
    still using the 77.5mm pulley
    stock intake
    stock TRD exhaust
    truck is running awesome.
    still getting 17mpg avg.
    IAT delta is still 31 degrees. Harrop sensor.
    but,
    the IAT delta is 34 degrees if I turn off A/C compressor. It's cooler in Houston now.
    trans still pinned...hover ~ 165 degrees no matter what. maxed at 185 in Houston slo-ass traffic.
    MAP (boost) @ 62mph cruise = -10.5
    because I'm still on the 80mm tune, boost still comes on before PE.
    I can hit 6.5lbs before PE - on ramps & such.
    other than that, the tune is primo.
    AFR will still drop to low 10's in PE.
    Cal-Trac traction bars are typical...Houston is cooling off & I need to adjust them again.
    5k oil changes & it burns ZERO oil.
    still using Costco 5w-30.
    will try Valvoline restore & protect next round...the oil geek channel said it works.
    blenton, Mdl, helidave and 4 others like this.
  10. Dec 4, 2024 at 4:58 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I got the aluminum version, anodized black. I specified in the notes when purchasing, but was emailing them back and forth beforehand.
  11. Dec 4, 2024 at 5:02 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    6.5 psi before PE hits should get you a free update on your tune.
    Is that your first change of plugs?
  12. Dec 4, 2024 at 5:14 AM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    I’d be pissed, wouldn’t want the truck in boost with it that lean.
    nobodyintexas likes this.
  13. Dec 4, 2024 at 5:21 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yes, first change of plugs
    ZPhilip[QUOTED] likes this.
  14. Dec 4, 2024 at 5:27 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    it's my fault.
    I changed the pulley...and have been too lazy to bring it back to re-tune.
    my work around is to just hit the pedal a smidge harder, then PE happens.
    Wynnded likes this.
  15. Dec 4, 2024 at 6:34 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    I feel better about mine occasionally hitting 1 or 2 psi before pe at lower elevation now
    nobodyintexas, Mdl and Wynnded like this.
  16. Dec 4, 2024 at 7:09 AM
    carn_dogg
    Pat
    Eastern Shore MD
    Yeah just be careful. My biggest concern would be towing. Enough throttle to get into boost while towing but not enough to get fueling right. Easy tune change though…so worth an email ask to your tuner asking if he can reduce PE TPS and get you closer to aligning boost and PE when on throttle
  17. Dec 4, 2024 at 7:10 AM
    carn_dogg
    Pat
    Eastern Shore MD
    Yeah wouldn’t worry about that. Again unless it’s for prolonged instances. Ie towing up a mountain pass at 1-2 psi and 14.7 afr
  18. Dec 4, 2024 at 7:17 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    you're right.
    I just emailed him for a re-tune.
    Mdl likes this.
  19. Dec 4, 2024 at 7:28 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    It would be a good time to do the magnuson airbox w/ SABM and TRD accelerator too! Plus any other mods you may be eyeing. Might save a few bucks on future tuning adjustments.
    nobodyintexas[QUOTED] likes this.
  20. Dec 4, 2024 at 7:33 AM
    Silver17
    Eastern PA
    pursuit2550 likes this.
  21. Dec 4, 2024 at 7:37 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    stop.
    just stop.
  22. Dec 4, 2024 at 7:42 AM
    pursuit2550
    pursuit2550 New Member
    I had seen that awhile back. IPT made a metion on one of his videos/website that he was the only one moding AB60 VB.
    Mdl and Silver17[QUOTED] like this.
  23. Dec 4, 2024 at 7:43 AM
    pursuit2550
    I feel the same way. Always something
  24. Dec 4, 2024 at 7:43 AM
    helidave
    flagstaff
    2015 DC 4x4
    SABM is pretty cheap and easy as far as mods go
  25. Dec 4, 2024 at 7:53 AM
    Silver17
    Eastern PA
    Im going to try and learn more about it. I’d like to do something, may go this route. Initial thoughts is they look like a reputable company and I’ve started watching this install video which looks promising. Reviews on the other options seem hit or miss. Haven’t seen a bad review on this one yet but will keep an eye out. https://m.youtube.com/watch?v=DxbvobUqcI8&pp=ygUYVHVuZHJhIG5vbWFkIHZhbHZlICBib2R5
    pursuit2550[QUOTED] likes this.
  26. Dec 4, 2024 at 7:53 AM
    pursuit2550
    Does it make a big difference on our SC?
  27. Dec 4, 2024 at 7:54 AM
    pursuit2550
    That's the video I saw when looking into mods for our VBs.
    Silver17[QUOTED] likes this.
  28. Dec 4, 2024 at 7:56 AM
    helidave
    flagstaff
    2015 DC 4x4
    I don't know if it makes a BIG difference, but more airflow is always a good thing. There's a big thread on here somewhere about it and I dont recall ever seeing any negative results
    pursuit2550[QUOTED], Mdl and Wynnded like this.
  29. Dec 4, 2024 at 7:57 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Sticker shock averted...
    Ruh roh...
    This will also add the following products to your cart:
    • Valve Body Refundable Deposit $650 Australia ($850 International) - $850.00
  30. Dec 4, 2024 at 8:02 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    With mine, I noticed a little bit more intake noise at the airbox as I approach 0psi. More available metered air isn't usually a bad thing, particularly at elevation.
