  1. Dec 2, 2024 at 2:06 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    Do you have any pictures of your truck with the 6112’s? What notch did you go with? I think this may be the way I go rather than mixing and matching suspension components. I only need 1” of lift for my tires, any more and I won’t fit in the garage at work.
  2. Dec 2, 2024 at 2:30 PM
    Maniac! Sanding those headlights without taping :rofl:
  3. Dec 2, 2024 at 4:23 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    I too rebuilt mine, saved some cash and they sound good. It was a fun little project.
    oscardog86 and shifty` like this.
  4. Dec 2, 2024 at 5:23 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    He lives
    Voss, oscardog86, dbittle and 8 others like this.
  5. Dec 2, 2024 at 5:30 PM
    Crackzilla never dies!
    Tundra2[QUOTED] and FiatRunner like this.
  6. Dec 2, 2024 at 5:38 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Crackie vibin on bootleg gasoline i made in a homemade whiskey still in 2039
    BroHon, bmf4069 and FrenchToasty like this.
  7. Dec 2, 2024 at 5:56 PM
    Mostly stubbornness. Today, I wish I would have just pulled the intake completely. But I suffered through.
    bmf4069 and Desert Dog[QUOTED] like this.
  8. Dec 2, 2024 at 5:57 PM
    And the starter issue was 100% contacts again.
    Old worn ones
    “New” refurb Toyota one
  9. Dec 2, 2024 at 6:03 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    I'm hoping to replace my starter contacts sometime in the next year or so. It is straightforward?
  10. Dec 2, 2024 at 6:05 PM
    Also installed my front tow hooks. I will revisit when I refinish my front bumper and skid plate. Had to use the factory tow hook on the drivers side until I get some shorter bolts.
    Voss, oscardog86, BroHon and 5 others like this.
  11. Dec 2, 2024 at 6:07 PM
    Replacing the contacts part? Easy. Get a plunger and both copper contacts. Getting the starter out? Bit of a bear. Don’t be dumb like me, just pull the intake like the TRQ video shows.
  12. Dec 2, 2024 at 6:12 PM
    There’s a decent amount of room under the intake to do the starter like I did. It’s just dumb and makes getting to the starter bolts unnecessarily hard. Lots of cussing.
  13. Dec 2, 2024 at 6:21 PM
    Bed Tundy
    Bed Tundy Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    Word around town is that the add a leaf is a hassle and does very little lift wise. I’m installing the 90-221HD springs this week I will let you know how it goes. Just watching my truck squat hauling firewood made me sad. I have a slight squat with just the topper and normal gear in the back anyway.
    I can’t remember my lift numbers but I posted them here at one point. Pretty sure it was 1-1.25” up front on the 6/4 setting. I’m running 255/85r16 toyo mt so 33x10. I love the 6112’s but they aren’t the best if you crave a higher lift and have an access cab. They suited me fine.
  14. Dec 2, 2024 at 6:30 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
    Despair! Discover the source or result of the swooshing noise made when turning.IMG_4424.png
    Ponder, how much of a PITA the front diff fluid change will be. Lexus plugs in the mail, but can I remove these IMG_4427.jpgIMG_4425.jpg
    Voss, noahrexion, oscardog86 and 7 others like this.
  15. Dec 2, 2024 at 7:46 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Heat, and gently beat
    Bed Tundy[QUOTED] likes this.
  16. Dec 2, 2024 at 7:47 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    mmmmmmmm conkcrete fooooooors taymsty
  17. Dec 2, 2024 at 11:21 PM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    Maybe so, but you still have my respect for pulling it off :thumbsup:
  18. Dec 3, 2024 at 5:42 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Finally got around to installing the 2884s on the already installed 5100s. I had the OEM springs on the 3rd perch, ride was OK. Installed the 2884s on the bottom perch, achieved almost the same height, maybe 1/2" higher, but expecting some settle. I do believe the truck corners better and has just an overall better feel to it. Not too bad of a job either. I went ahead and installed the Suspension Maxx sway bar end links also. The bushings on the OEM were CRUSTY.
    Tlar25, bmf4069, noahrexion and 4 others like this.
  19. Dec 3, 2024 at 8:37 AM
    So OEM on 3rd perch was "OK". How do the new ones ride? Any softer?
  20. Dec 3, 2024 at 8:48 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Doesn't necessarily feel "softer", just less harsh, if that makes sense. Better feel in the steering as well.
    KNABORES[QUOTED] likes this.
  21. Dec 3, 2024 at 8:49 AM
    What's your center hub to fender measurement now?
  22. Dec 3, 2024 at 8:54 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    About 22 1/2". About 1/2" more than than the stock coils on the 3rd perch. I expect some settling in though.
  23. Dec 3, 2024 at 9:25 AM
    bmf4069, 455h0le_dachshund and CodyP like this.
  24. Dec 3, 2024 at 9:28 AM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    So, as currently measured from hub to fender, my rake is 2.5 driver side, 2.25 pass side. My thought is that the bilsteins will probably give me 2.25ish of lift up front. I don't expect a full 1.5 of lift in the rear from the wheelers. Probably more like 1. So if that works out, I'll end up with about 1.25ish rake drivers side and about 1 on the passenger side. At least that's the plan. Don't check my math.
    I figure these add a leafs will give me some flexibility. I think if things don't go as planned in one way or another, it's gonna be that I still have a lot of rake. In which case I'll just pull the add a leafs and roll with just the leaf pack. In the off chance that I'm squatting, I'll put the overload back in to get a little height. If it all hits the fan, I've got my old leaf pack and could cut it up to make some new leafs in a pinch.
    MT-Tundra[QUOTED] likes this.
  25. Dec 3, 2024 at 9:37 AM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    So the ICON add a leaf supposedly doesn't do much. I've heard better things regarding the wheeler's add a leaf, which is what I ordered. I didn't do the HD leafs because I'd rather have a little smoother ride and I don't see myself going with a topper or a bunch of added weight in the back.
    455h0le_dachshund likes this.
  26. Dec 3, 2024 at 9:48 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    IMG_0592.jpg I ended up going with the Firestone Ride Rite airbags on the rear with stock leafs. I had a bit of sag because of the bed topper and tools that I carry around in the bed. I'm running 17-20 psi in the bags which gives me good body control and level front to back. I also like the adjustability for when I tow or carry a bunch of weight in the bed. I bought a small battery powered inflator off of ScAmazon which works great for airing and deflating the bags. I did not tee the bags for a single inflation point, so I have ability to level from side to side. So far I'm happy with the set up.
  27. Dec 3, 2024 at 11:06 AM
    After I reassembled the intake last night following the starter swap, at first start up I smelled gas. Popped the hood and #2 drivers side injector was leaking everywhere. I inspected thoroughly and cleaned up all the gas. Gave the injector a couple of back and forth rotation wiggles and fired it back up to see where the leak originated. Nothing. No more leaks. Odd it wasn’t seated when I didn’t mess with them at all. No leaks this morning when I drove it either. Who knows.
    BroHon, bmf4069, ATBAV8 and 2 others like this.
  28. Dec 3, 2024 at 12:21 PM
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    Outside of PDX OR
    2003 SR5 V8 AC TRD 4x4
    Installed these yesterday, was tired of the stock horns but I'll wait till I really use it in anger to see how I like it. Currently only gave them a quick honk at the end of the street. Does look vaguely like a subaru now with the horns visible through the grill.
    Voss, sportbike37, Tlar25 and 4 others like this.
  29. Dec 3, 2024 at 1:03 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    How do you like the dynamic friction pads? I put them on my Sequoia about 6,000 miles go and I'm not sure about them. Initial pad bite is good, but when I really get on them, they don't seem to grab as much. I may go back to the EBC I had before.
  30. Dec 3, 2024 at 1:06 PM
    https://www.youtube.com/watch?v=761MwtYpK3Q
