  1. Dec 2, 2024 at 6:48 AM
    Yeah, just saw your other post above about your experience with the oil coolers. When we scoped out his, the failure appears to be at the front of the cooler, where the metal meets plastic. That's where I'm seeing the majority of the spillover, and it looks like he has about 1qt of oil and lost several more quarts down the back of the engine, the block and trans are absolutely coated. It's a mess. I dunno why shops would torque down so hard, that o-ring on the filter cap is beefy as hell. Just oil it and snug it and call it a day! Damn gorillas working at lube places.
    My thoughts exactly. Or potentially grey market. Any other oil companies using a yellow jug? If so, they probably peeled the sticker off and taped a new one in its place. You can't trust anything on Temu. It's scAmazon, AliBaba edition...
  2. Dec 2, 2024 at 7:04 AM
    Bottom of the oil cooler just has a set of O rings that get flattened over time. I replaced them and torqued it back down and no leaks
  3. Dec 2, 2024 at 7:11 AM
    One of the videos I watched showed similar. Guy in the video sounded Aussie, mentioned it was typically the one large one, alternately the two smaller diameter ones. Is definitely showing signs it’s coming from where the metal meets plastic, though. And a ton of oil at that.
  4. Dec 2, 2024 at 7:15 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    I'm pretty sure TEMU is Chinese.....
    455h0le_dachshund likes this.
  5. Dec 2, 2024 at 11:00 AM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    This makes me smile.
    whodatschrome[QUOTED] likes this.
  6. Dec 2, 2024 at 11:06 AM
    Some shorty's for sale locally
  7. Dec 2, 2024 at 3:05 PM
    REMINDER: For anyone that needs to see this, Toyota's 25% off parts sale ends at 2am EST, unless my math is jacked. You got about 8 hours left.
  8. Dec 2, 2024 at 4:27 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Stupid question. How fast do our trucks go?
    Somebody at some point told me they were limited to 105. Anyone confirmed this? I don't think I've ever done more than 85.
    I only ask because I found myself in a situation recently when I could safely, controllably see how fast my Lexus would go. Highway in the middle of nowhere Illinois, dead straight road, zero hills, zero traffic, and in the daylight.
  9. Dec 2, 2024 at 5:12 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Got a 4x8 sheet of ¾" pine for $40
    FrenchToasty and FiatRunner like this.
  10. Dec 2, 2024 at 5:13 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I've hit 110 on the speedo but this mf felt like it was gonna come apart
    bmf4069, BroHon, FirstGenVol and 3 others like this.
  11. Dec 2, 2024 at 5:15 PM
    With gears, on the @speedo i could only do 85 before the govna kicked it, but supposedly that’s probably closer to 90-95
  12. Dec 2, 2024 at 5:22 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Anyone doing a junkyard run soon?
  13. Dec 2, 2024 at 5:24 PM
    Dook55
    Dook55 RCLB Guy
    Montana
    I've had my 2006 RCLB up to 95 a few times. The speed limit here is 80 on the interstate so it's easy to get up to 90 accidentally. It was pretty smooth at that speed, but I don't have a lifted truck or giant knobby tires.
  14. Dec 2, 2024 at 5:26 PM
    FiatRunner
    Jack
    Yeah, I've got no need to go that fast in the truck. I bet it would do it fairly well though with the new well balanced tires and the rear sway bar. It's super smooth and stable at 70. Maybe I'll try it once (in a safe, controlled environment) just to try it out.
    Top speed in my Lexus was pretty anticlimactic. It's so aerodynamic and powerful that it's 132mph governor really didn't feel much faster than 80.
    bmf4069 and Tundra2[QUOTED] like this.
  15. Dec 2, 2024 at 5:30 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yeah I had those ancient worn out MTs on the truck at the time and that was before I did all the suspension work
    Much better now
    FiatRunner[QUOTED] likes this.
  16. Dec 2, 2024 at 5:34 PM
    Whatchoo need, Hoss? Local Pullaparts are finally starting to get 1st gen trucks in more regularly now, one or two per month.
  17. Dec 2, 2024 at 5:39 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I need one o' these, if you're offering :oops:
  18. Dec 2, 2024 at 5:40 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    A throttle body. Specifically the piece the cable goes into.
    I can probably swap that piece onto my throttle body but I think each one is tuned to the whole throttle body
  19. Dec 2, 2024 at 5:43 PM
    FiatRunner
    Jack
    What's wrong with your current one? The drum that the cable attaches to is actually a sensor. It's hard to find an OEM one, and especially difficult without it costing an arm and a leg. I do believe you can swap them out without needing to recalibrate.
  20. Dec 2, 2024 at 6:06 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    110ish was the fastest. Got scared the back window of my cap was gonna come out.
    Got a pic at 99. & that run made my oil pressure gauge start working.
  21. Dec 2, 2024 at 6:08 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I got scared at 105
    bmf4069 and G_unit3000 like this.
  22. Dec 2, 2024 at 6:46 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
  23. Dec 2, 2024 at 6:52 PM
    bmf4069 and JakeJake[QUOTED] like this.
  24. Dec 2, 2024 at 6:55 PM
    JakeJake
    2000 Tundra AC 4X4
    bmf4069 likes this.
  25. Dec 2, 2024 at 7:11 PM
    How fast have you guys gone in any vehicle? I hit 143 in my 2003 Maxima. As a passenger we did 150 in my friends Mustang GT. I haven't been that fast in a long time. 12-15 years.
    bmf4069 likes this.
  26. Dec 2, 2024 at 7:12 PM
    I’ve only done a buck thirty seven. It was in a 1979 Pontiac Transam with the 6.5L engine.
    bmf4069 and 455h0le_dachshund like this.
  27. Dec 2, 2024 at 7:16 PM
    About 140 in my buddies 2001 Camaro Z28.
    About 160 on my 1999 Suzuki GSXR 600
    bmf4069 likes this.
  28. Dec 2, 2024 at 7:20 PM
    I knew a guy that hit 191 on his Honda motorcycle. I can't even imagine what that would be like.
    bmf4069 likes this.
  29. Dec 2, 2024 at 7:37 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    177 on a zx6r. It's like looking through a toilet paper tube.
    bmf4069 likes this.
  30. Dec 2, 2024 at 7:51 PM
    FiatRunner
    Jack
    Fastest I've driven is 132 in my Lexus, as a passenger my dad and I did 167 in my grandpas C5 corvette. Both felt super planted and controlled. I wouldn't want to do anything above 110 in a vehicle that isn't as aerodynamic as one of those.
    bmf4069 likes this.
