Powertrax GripPro LSD vs. Speedmaster LSD
Discussion in 'Performance and Tuning' started by Silver17, Aug 16, 2022.
  1. Aug 30, 2022 at 9:01 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Man. That's a tough call. My first thought was to say "Save more money and regear since you'll already be paying for the install labor." Then I realized you're only tearing into the rear if you add the LSD. Big difference in dollars to add gears, as well as heavier labor costs to do the front. Gears are fucking awesome, but budgets are a real factor... If you can come up with a feasible way to swing it, do it. After having 5.29's with only 34" tires, I'd recommend it for anyone with tires that are larger or heavier than stock... I think that the added rotating mass has as much effect on performance (loss) as the added leverage from the increased diameter. I noticed that going to a heavy LT tire took a lot of pep out of my truck, even at stock diameter...
  2. Oct 31, 2022 at 11:57 AM
    Silver17
    Silver17 [OP] Used, but returned and sold as new member
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Those of you with it installed, does the Powertrax GripPro have a break in period that it should be babied for and followed up by a fluid change? I’d look at the install instructions but I’ve already handed it off to the installer. Thanks in advance.
  3. Oct 31, 2022 at 12:11 PM
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    I don't recall specifically, however I just went in line with Nitro's break in standards for the gears and its been fine. (Heat cycles, 500 miles I think, fresh fluid).
    Silver17[QUOTED][OP] likes this.
  4. Oct 31, 2022 at 12:22 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    No issues here with my Powertrax. Passenger slid in like a hotdog down a hallway and the driver side needed a little deadblow attention until I could get the bearing nuts started. Pulled right in, torqued up, and running silently.
    Silver17[OP] and Saltyhero13 like this.
  5. Oct 31, 2022 at 12:51 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    My installer did a short break in (100 miles or less) and change the oil. Not required. I don't get all the clicking and popping other have reported.
  6. Oct 31, 2022 at 12:57 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I don't think so, though I did gears at the same time. Considering the Powertrax has it's own gears and contact points it wouldn't hurt to be gentle for 50-100 miles.
    I also recently switched to the Valvoline gear oil per this threads recommendations: https://www.tundras.com/threads/gea...c-helix-torsen-grip-pro-differentials.101244/ I've been noticing lackadaisical slip limiting which I fully attribute after talking to people to be a result of the Amsoil Severe Gear being too slippery. So I would suggest you do indeed follow their oil recommendations, which I did not :D
  7. Oct 31, 2022 at 2:00 PM
    Silver17
    Eastern PA
    Thanks for the replies. At a minimum I’ll take it easy for a bit, and maybe change the fluid earlier than I otherwise would. I’m really looking forward to having this diff. The open diff definitely takes a lot of fun out of having the blower on the street when I can basically count on a lame 1 wheel peel every time I give it any throttle at all in 2wd. I wanna be able to get a little sideways sometimes! I have the solid offroad mounts going on too at the same time.
    :burnrubber:
    snivilous and Saltyhero13 like this.
  8. Oct 31, 2022 at 2:14 PM
    VWTim
    Corvallis, OR
    I'm planning to do a changeout after 500 or so miles on mine. Kept the same gears, but new bearings/etc. Cheap insurance for a new diff IMO.
  9. Nov 1, 2022 at 2:32 PM
    VWTim
    Corvallis, OR
    What weight do you run in winter?
    I'll prob run this stuff after a break in cycle. https://www.redlineoil.com/75w90-ns-gl-5-gear-oil
  10. Nov 1, 2022 at 2:33 PM
    snivilous
    SW UT
    Amsoil has some limited slip additive I saw, so that could be worth a shot as well. I was considering that option but it was hard to determine what the additive would actually do, and easier in my case to just run a different manufacturer for the rear.
  11. Nov 1, 2022 at 5:08 PM
    Ckatz53
    Ckatz53 Newish
    MD
    How cold does it get where you live? MD here and while it doesn't get crazy cold, we frequently see the high teens low 20s in the winter. I've swapped gear oil twice since install (3 years) through our version of bad winters with no signs of degradation or unusual wear with nonsynthetic in the rear and no hard shifts. I change it once a year since I tow so much.
  12. Nov 1, 2022 at 5:13 PM
    Ckatz53
    Ckatz53 Newish
    MD
    Oh hell lol. Disregard. It hits 32 here and I immediately book a flight to Puerto Rico. You can have that -40 shit :crazy:
  13. Nov 1, 2022 at 5:19 PM
    Ckatz53
    Ckatz53 Newish
    MD
    You're a brave soul.
  14. Nov 1, 2022 at 8:04 PM
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    Had my Powertrax installed for going on 2 yrs. Filled up with Amsoil Severe Gear 75w90 and it's still in there. No issues and all smiles since install
  15. Nov 1, 2022 at 8:38 PM
    snivilous
    SW UT
    It's not, but you're not supposed to run synthetic either :D my point was you might be able to tweak the synthetic to do what you want, but the amsoil limited slip additive wasn't particularly clear on if it'd make the powertrax more aggressive or not.
    And to be clear, I'm not saying the powertrax stopped working or had issues with amsoil. It just seems to need more throttle than I'd like to really kick in, and hopefully that's just a gear oil thing and trying to handle the torque from 5.29s and the blower.
    Saltyhero13 likes this.
  16. Nov 2, 2022 at 7:09 AM
    VWTim
    Corvallis, OR
    LS additives will make the Powertrax work LESS, the helical gears internally need some friction to properly torque bias. Synthetic with LS additives will "work" just fine with it, the LS action will just be loose or reduced.
    I'm using Mobilube currently and I can actually feel the LS working on uneven or sections of gravel/dust on pavement.
  17. Nov 17, 2022 at 12:38 PM
    SnowB0und
    SnowB0und New Member
    2013 SR5
    I just did a Truetrak in my Jeep and the manual specifically says not to use synthetic. They recommended Lucas 75w90. I appreciate that since it’s cheap and available everywhere. The Truetrak is a helical gear style as well.
    TX210Tundra likes this.
  18. Nov 30, 2024 at 2:57 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Has anyone put some miles on the speedmaster yet?
  19. Nov 30, 2024 at 4:46 PM
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    300 miles
    got a little off-road with it. Worked great. Got 2 wheel peelage and way more traction. No 4x4 needed yet
  20. Nov 30, 2024 at 4:52 PM
    #50
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Myself and @carn_dogg will be installing the speedmaster.
    Seems the carrier splines may have tight tolerances and need a bit of finese getting the axle splines in.
    carn_dogg likes this.
  21. Nov 30, 2024 at 4:53 PM
    #51
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Cool deal!
  22. Nov 30, 2024 at 5:45 PM
    #52
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    How much is everyone paying for install of one of these?
    Mdl likes this.
  23. Nov 30, 2024 at 6:02 PM
    #53
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    I’m planning to take a weekend and do it for the price of 1-2 terrific lady days. Aka dad watches the kids while mom gets some time to herself.
    bflooks, Danimal86[QUOTED] and Mdl like this.
  24. Dec 1, 2024 at 4:15 AM
    #54
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    1500 all parts supplied
    Mdl likes this.
  25. Dec 1, 2024 at 4:29 AM
    #55
    carn_dogg
    Pat
    Eastern Shore MD
    That a front and rear statement with gears and lsd?
    Mdl likes this.
  26. Dec 1, 2024 at 5:25 AM
    #56
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    Masters and gears front and rear and rear lsd
    Mdl likes this.
  27. Dec 1, 2024 at 5:26 AM
    #57
    carn_dogg
    Pat
    Eastern Shore MD
    Not too bad at all
    masters 900 f and r
    LSD 518 for speed master for BF sale
    Gears 150 f and r for motive
    1600 parts and 1500 labor.
    Mdl likes this.
  28. Dec 1, 2024 at 7:45 AM
    #58
    Chad D.
    Chad D. New Member
    Western Oregon
    Think I paid $1,600 for labor and oil. I supplied gears, master kits, and LSD.
    Mdl and FrenchToasty like this.
  29. Dec 1, 2024 at 7:46 AM
    #59
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    $500 for rear gear and powertrax install, but that's with me removing/installing the center section from the axle.
