  1. Nov 30, 2024 at 3:25 PM
    Azblue
    The Dirty T ( ^_^)_且
    I banished any light below 5k years ago. Any light with the slightest hint of yellow makes me angry.
    bmf4069, OldGuy03, Outbound and 4 others like this.
  2. Nov 30, 2024 at 3:50 PM
    NWPirate
    Zach
    WA
    I'm with you guys everywhere else but inside the house, I like 3500k-4k.
    5k feels like a Dr. office
  3. Nov 30, 2024 at 5:54 PM
    Yup, totally. I'm a 4k-all-day kinda guy. I can't handle anything that has that fluorescent Cool White appearance to it. I need a little bit of warmth. 5k is a little too arctic white.
  4. Nov 30, 2024 at 5:55 PM
    Our entire interior house is this way with these lights. I would need to change every single damn light on all floors (with the exception of main floor guest bath as I did that when I remodeled it). Pass
  5. Nov 30, 2024 at 5:56 PM
    I think our interiors are closer to 3k but still
  6. Nov 30, 2024 at 5:58 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    100% :thumbsup:
    Lighting is one of the things the wife and disagree about frequently...
  7. Nov 30, 2024 at 6:12 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    Hung Christmas lights and cleaned gutters
    OldGuy03, T-Rex266 and TaquitoBandito like this.
  8. Nov 30, 2024 at 6:29 PM
    TaquitoBandito
    Joel (AKA Bif)
  9. Nov 30, 2024 at 6:41 PM
    NWPirate
    Zach
    WA
    OldGuy03, Azblue, T-Rex266 and 2 others like this.
  10. Nov 30, 2024 at 6:43 PM
    :fistbump:
  11. Nov 30, 2024 at 7:02 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Kids school sells live wreaths and garland every year for a fund raiser (a big one for our school) and got our delivered from WA today. Hung up the 2 window wreaths and the garland around the door. Always adds a nice pop.
    I wrap the door garland with lights too
    Florida AF, bmf4069, OldGuy03 and 9 others like this.
  12. Nov 30, 2024 at 10:30 PM
    Looking at swapping some outlets to ones with usb-c. My question is, is what ampage to choose? Not sure what a good one would be for cell phones (mainly)?
  13. Dec 1, 2024 at 4:18 AM
    bfunke
    bfunke Tundra Curmudgeon
    If your phone supports fast charging and MagSafe you’ll want 30W USB-C. If your charging a laptop you’ll want 45-50W.
  14. Dec 1, 2024 at 5:52 AM
    trucksareforgirls2
    trucksareforgirls2 New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    Or his practice pole....
  15. Dec 1, 2024 at 7:33 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Your house is likely only wired for 15A outlets. Don’t put in 20A unless you are replacing one that already is (notice the extra little side slot?)
  16. Dec 1, 2024 at 7:48 AM
    NWPirate
    Zach
    WA
    Newer houses typically wire outlet circuits for 20A, even if they have 15A outlets (totally legal btw).
    Older homes or current cheap builders will wire outlets on 15A circuits.
    Sean, I would buy the 15A outlets. You'll likely never need more than the 12 amps allowed on the circuit.
  17. Dec 1, 2024 at 8:13 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    When I was installing new lights into the bedrooms of our new home, I bought the ones with a selection of light temps. We selected the one that the wife liked for the room.
  18. Dec 1, 2024 at 8:38 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Dig into the specs and see if what the advertised USB power rating is for each port or if it's shared across all the USB ports. On plug in chargers, the less expensive ones share the ratings across all the ports.
    Just remember, it's not the best idea to charge your phone as fast as possible every time.
    If you are one of those peoples who's phone is always at 20% charge then get as fast as possible charger.....I just slow charge my phone over night.
  19. Dec 1, 2024 at 9:01 AM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    Finished building these chairs for my in-laws for their Christmas present this year. Took about 25 hours to build the pair. All the slats were cut from some 1x10's as I get those for free from a stack at my parents house. The frame received 2 coats of primer and them 3 coats of paint.
  20. Dec 1, 2024 at 10:22 AM
    Thank you gents! no, I charge mine usually at night and on the way to / from the gym.
  21. Dec 1, 2024 at 1:23 PM
    Looks like others already said 15A, but a couple of tidbits to share from experience.
    If buying on scAmazon, make sure whatever you buy is at least UL-listed. But ideally, you want something that has some form of overcurrent protection so you don't blast your device.
    Some outlets have the older style rectangular USB setup in such a way that you can't use a standard plug while USB is plugged in. I've got one such outlet in my house.
    You want the output on the USB ports to be an individual* output of 3A + 15W or better if possible per port, or 5A + 30W total.
    Note that the depth of some units can be troublesome depending on your install, like if you're doing something in a basement area, where you may've used furring strips versus full studs.
    Not remotely trying to say you shouldn't use one of the bullshit ALLCAPS-GIBBERISH-BS brand names off scAmazon by any stretch, but ... knowing your outlet catching fire can leave you homeless, you may want to stick with a trusted name brand like Leviton. Don't save $5-10/outlet just to lose a 6-7 figure valued home. These are half-off thru Monday. They sell one with mixed USB, and one with dual-USB-C.
  22. Dec 1, 2024 at 1:53 PM
    As always, I love learning and respect your input. The above says not for laptops. Would this be acceptable for iPads?
    edit: says tablet, so should be good
    TaquitoBandito likes this.
  23. Dec 1, 2024 at 2:27 PM
    RainMan_PNW
    Casey
    Clark County, WA
    You’re not likely to find one of those outlets rated to charge a laptop. You’ll be fine with an ipad though.
    And I’d echo what shifty said.
  24. Dec 1, 2024 at 2:55 PM
    Welp, guess I know what I’m doing tomorrow morning….
  25. Dec 1, 2024 at 2:57 PM
    Cancelled the no name brand, and ordered the above. I have multiple of the Leviton outlets as is, so why not
  26. Dec 1, 2024 at 2:57 PM
    Re-caulk?
  27. Dec 1, 2024 at 4:50 PM
    AZTundra
    Paul
    Phoenix, AZ
    Need some advice. Working on the back patio ceiling to install some t&g boards once I get finished staining them. Does anyone have an idea how many 6” flush mount led lights I should install? The patio is 27ft long and 10ft deep. Ceiling height is about 7.5ft. I’ll be hanging a ceiling fan in the center and then doing the flush led’s on both sides of the fan. I bought a 12 pack and was going to do six on each side of the fan (3 rows of two), but a wondering if that will be overkill. The lights do have a remote control and they are dimmable, so the brightness can be toned down if it’s too much. Here is is a picture of the patio. The ceiling fan brace has been replaced, this picture was from a couple weeks ago. Just trying to figure out how many I should do before I start running the wiring.
  28. Dec 1, 2024 at 5:01 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Droppin a duece?
    Also, I’ve never understood the reason people caulk their toilets. I’d rather see the leak than have it contained in there and slowly rot through the floor.
    Ebrperk, TaquitoBandito, Kung and 5 others like this.
  29. Dec 1, 2024 at 5:03 PM
    Caulk stops potential gasses from escaping, looks nicer, shores up gaps. And it'll usually separate with moisture. Case in-point, let's zoom in on that pic, clearly I've got a failed wax ring.I only caulk the front U-circle, leave the back open. :
  30. Dec 1, 2024 at 5:07 PM
    Interesting, I decided to Google whether it's code in my area. Other results made it look like it was, but it appears International Plumbing Code requires it too.
