  1. Nov 28, 2024 at 5:03 AM
    phudz
    phudz
    Michigan
    2004 DC V8 4WD
    Swapped out the ATs for my Blizzaks on Sunday, and sprayed a fresh coat of clear Woolwax on the undercarriage last night at the local Rent-a-Hoist. Just in time for the snowstorm due to hit Michigan later tonight.
  2. Nov 28, 2024 at 5:21 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Yes.
    Two things:
    1) Are you certain that new drums are needed?
    2) If yes, the OE drums are expensive. But aftermarket drums can be ok. I have used both with success. Just have to consider is the money saved worth it.
    Have not seen Advics branded brake drums for sale for 1st Gens.
  3. Nov 28, 2024 at 8:13 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Can spec the drum to see if it can be turned.
    Can see if they are in spec and might turn and still run them instead of replace.
    https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-2188#post-3755296
  4. Nov 28, 2024 at 8:30 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I have the front bumper. I like it
  5. Nov 28, 2024 at 8:50 AM
    hpark21
    hpark21 New Member
    06 Black Tundra TRD Access cab 2WD 4.7L
    Well, it isn't binding or anything. It moves smoothly. Just that it does not flop around, I do have to use my hand to go left/right/up/down. I was very careful with needle bearings, though I can't, of course, discard the possibility. What I will probably do is do the other joints and see how it feels and decide.
    Maybe it is because of temperature. It isn't exactly COLD, but it is pretty cool.
  6. Nov 28, 2024 at 3:33 PM
    evanhmn
    evanhmn mmm chicken pot pie
    State of Taxes
    2001 TRD Off-Road AC 4x4 Limited in Black
    5100/2885s, 1.5" Add-Leaf, BFF Front Bumper, 265/70/17 KO2s
    Alright. Someone advise. Is this ATF burnt or what? Looks pink on a paper towel, but pretty dark in a bottle…
  7. Nov 28, 2024 at 4:41 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Coolant or atf?
    evanhmn likes this.
  8. Nov 28, 2024 at 5:04 PM
    evanhmn
    State of Taxes
    ATF*** derp Dee derp. Pink liquid gets confused in this brain of mine sometimes.
  9. Nov 28, 2024 at 5:07 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Definitely looks dark but if it was burnt it would smell like hell
  10. Nov 28, 2024 at 5:13 PM
    bfunke
    bfunke Tundra Curmudgeon
    Smell it. That will tell you if it’s burnt.
  11. Nov 28, 2024 at 5:57 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Pass it through a coffee filter & see how much clutch dust is in it.
    bmf4069 and FrenchToasty like this.
  12. Nov 28, 2024 at 6:02 PM
    Looks pretty normal to me. Especially the first pic in the bottle.
    CC80guy and evanhmn[QUOTED] like this.
  13. Nov 28, 2024 at 10:11 PM
    Bed Tundy
    Bed Tundy Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    VSC Tundra, so no LSPV for me to mess with and I’m glad of that.
    Do you think there would be any issues with me using SS braided lines with the increased pressure of the hydraulic VSC braking on my truck? For the moment I’m not going to order any until it’s determined that I need them. One of my front hard lines is all banged up, works fine but looks like it needs to be replaced.
    Happy Thanksgiving FGT fam
    shifty`[QUOTED] likes this.
  14. Nov 28, 2024 at 11:41 PM
    tbugnet15
    tbugnet15 New Member
    2001 Access Cab v8 4wd TRD Limited
    Finally driving and legal and all the lights work.
    bmf4069, sportbike37, BroHon and 6 others like this.
  15. Nov 29, 2024 at 6:50 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  16. Nov 29, 2024 at 7:46 AM
    Braided lines still contain rubber inside and are capable of collapsing with age/time. Hard lines won't, but will bend/break.
  17. Nov 29, 2024 at 9:40 AM
    BroHon
    BroHon Undisputed Shock-King
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    Started it, brushed the snow off. It's been 7 days since our last drive.
    EDIT: Something about getting her out in the snow, like a dog that finally gets to run free...
    Not bad here today. Big fluffy flakes in the air. Not bad traffic either for the day that it is. Win win.
  18. Nov 29, 2024 at 11:09 AM
    hpark21
    hpark21 New Member
    Answering my own post just as an update.
    I brought the drive shaft down to my mechanic. He moved it around, told me that while it seem a bit stiff, he says it feels fine and said it should loosen up.
    I installed the other 2 joints and they all feel the same so I am guessing it is normal - yes, I whacked it around and I can confirm it loosend a bit.
    Installed the shaft on the truck, drove around, squeeling noise is now gone and I did not feel any vibration or something so I think I am good.
    Thanks.
    oscardog86, des2mtn, w666 and 4 others like this.
  19. Nov 29, 2024 at 2:08 PM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    Here's what I did to my FGT today, I parked it in the garage for the first time ever! A lesson I have learned, if you keep buying tractors eventually you run out of room to park the truck. No more scrapping the frost off the windshield in the morning! :thumbsup:
  20. Nov 29, 2024 at 3:20 PM
    bfunke
    Replaced rotors and pads on my AC. Got Dynamic Friction fully coated rotor kit from Rock Auto. The rotors look really nice although rust is not a concerm in SC. I bought the hardware kit from the Rock but the pins were longer than my OEMs so I tossed them and cleaned up my originals. I did use two spreaders per side, however. Interestingly my passenger side the outboard pad was much more worn than the inboard. Pistons moved easily and cleaned up nicely with some Brakleen. No leaks seen. I’ll keep an eye on wear before deciding if I need to rebuild or replace caliper. I did have a friend help me with the lifting and torquing since I had surgery 3 weeks ago and not supposed to lift anything heavy or overhead.
  21. Nov 29, 2024 at 3:37 PM
    Openbaffle
    Openbaffle New Member
  22. Nov 29, 2024 at 3:47 PM
  23. Nov 29, 2024 at 5:38 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
    So many things one could buy haha. I’m looking at catch cans/oil separators now. I threw some fuel codes a couple weeks ago. My fuel trims were way off. I swapped the MAFs between my trucks and cleaned the throttle body without removing it on the offending truck that had codes. Codes went away. The oily buildup behind the throttle plate is my suspected culprit because nothing else has changed and both MAF sensors are reading well. Who has a good catch can recommendation to prevent some of this buildup?
    ideally it with be both safe/functional and not cost $500. Or is that too much to ask?
  24. Nov 29, 2024 at 6:22 PM
    You're not running an oiled filter, are you?
    des2mtn likes this.
  25. Nov 29, 2024 at 8:59 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    I had maybe the luckiest moment of my life today. I changed the oil. But get this - I greased all the zerks without having to move the truck back and forth to get access to all of them. All 8. First shot. Maybe some of y’all do that on a regular basis, but not me. It’s a good day!
  26. Nov 30, 2024 at 5:27 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I spy a 3G 4Runner
    CodyP likes this.
  27. Nov 30, 2024 at 5:29 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Don't be a Grinch. :santa: gon geit ya
  28. Nov 30, 2024 at 6:26 AM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    2001 4Runner. I've had it 9 years now. The interesting thing about it is it has just about all of the Limited features, including moon roof and leather seats, but is designated an SR5. It has two main jobs, towing my tractors around and snow plowing the roads. It's somewhat modified - Tundra brakes, Cruiser (?) rear suspension, aux trans cooler, roof rack, after market fog lights, LED's etc. She is a great workhorse. :thumbsup:
  29. Nov 30, 2024 at 6:30 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Factory E locker?
  30. Nov 30, 2024 at 7:13 AM
    Dook55
    Dook55 RCLB Guy
    Montana
    I have always liked that configuration and looked into buying one several times. The problem I had is I never found a used base model 4runner. They all had the girly stuff like sunroof, power seats and every "luxury" gadget and option imaginable. A more utilitarian, K.I.S.S. principle, green jeep-like no-nonsense workhorse 4runner would be right up my alley, but I guess they weren't targeting that market.
    455h0le_dachshund likes this.
