Rebuilt 2005 GX470 Project + random E46 M3 and JK updates
Discussion in 'Lexus GX Builds' started by M3Tundra-JK, Oct 23, 2023.
  1. Nov 23, 2024 at 10:55 AM
    #661
    M3Tundra-JK
    M3Tundra-JK [OP] New Member
    Scott
    2005 GX470
    Oh, and my drivers side door speaker isn't working. I haven't really checked all the others, but it's not terrible for stock speakers. I'll definitely upgrade them at some point though.
    e30cabrio likes this.
  2. Nov 23, 2024 at 11:10 AM
    #662
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    The interior looks amazing! Your body work looks dang good also! :)
    The title dealy here in Texas well,,,,, never mind that because lately my memory is crap! If you find a county court/tax collector annex (one in a small town are not that busy) you will have to go there and get a couple forms to get that registered and don't forget the insurance, plus inspection. You might be able to get the form thru DMV online??? I do not know. All the best luck in that.
    In the picture the dang interior looks brand spankin new!:)
  3. Nov 23, 2024 at 4:20 PM
    #663
    bfunke
    bfunke Tundra Curmudgeon
    I’ve used Simple green and a brush with great success on carpets and seats of cars I’ve salvaged from the wrecking yards. Just don’t use it on alloy engine parts.
    e30cabrio and M3Tundra-JK[OP] like this.
  4. Nov 23, 2024 at 4:36 PM
    #664
    M3Tundra-JK
    Scott
    2005 GX470
    just scheduled a windshield replacement for next Friday. Through Safelite. I was gonna do OEM but it was twice the cost.
    + $410
    e30cabrio and Black@Blue19 like this.
  5. Nov 24, 2024 at 10:03 AM
    #665
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Looks great!
  6. Nov 29, 2024 at 10:44 AM
    #666
    M3Tundra-JK
    Scott
    2005 GX470
    New windshield!
  7. Nov 29, 2024 at 1:22 PM
    #667
    M3Tundra-JK
    Scott
    2005 GX470
    FINALLY fixing an oil leak on the M3 (one of the many). Probably been this way for a year but it's been getting worse lately. I had done a valve cover gasket replacement at some point, and didn't realize I needed extra crush washers for a banjo bolt. So I reused the old ones. No Bueno. Been causing a slow leak right on top of the exhaust manifold heat shield. So rolling up to a stop light after a while cruising, smoke could be seen slowly coming out of the passenger side...
    Just went to Orielys and got some generic crush washers. Should work. Same inner diameter but larger outter...
    + $3.50
    Fobroader, Black@Blue19 and e30cabrio like this.
  8. Nov 29, 2024 at 1:50 PM
    #668
    e30cabrio
    I hate banjo bolts.
  9. Nov 29, 2024 at 1:53 PM
    #669
    M3Tundra-JK
    Scott
    2005 GX470
    Unfortunately I still have to replace the crankcase position sensor gasket also. That's a huge PIA to get to, being at the far backside of the engine. I'm probably gonna work up a list of things wrong and hand it over to a local BMW shop. Hand them the keys and warranty information, and my list of issues. Tell em fix whatever warranty will cover even if it's not on the list. Go to town on em lol
  10. Nov 29, 2024 at 1:58 PM
    #670
    M3Tundra-JK
    Scott
    2005 GX470
    Yeaaaaaa......it's definitely going into the shop soon. Not sure where exactly the rest of the leaks are coming from.
    Fobroader, e30cabrio and Black@Blue19 like this.
  11. Nov 29, 2024 at 2:56 PM
    #671
    Black@Blue19
    Ken
    SE Texas
    Gettin er done! Looking like it is coming to the end. Very nice, this has been an interesting follow along. Thank you for posting up the project/s progressions. :)
  12. Nov 29, 2024 at 4:09 PM
    #672
    M3Tundra-JK
    Scott
    2005 GX470
    Hmm, few things with the M3. I was feeling around the wires in the back and...wth...I guess I forgot to plug the cam sensor back in the last time...
    And it seems the leak is coming from either one of the new valve cover bolt gaskets, or this part that I replaced. forget it's name but has a red circle on it
  13. Nov 29, 2024 at 4:11 PM
    #673
    M3Tundra-JK
    Scott
    2005 GX470
  14. Nov 30, 2024 at 6:05 AM
    #674
    e30cabrio
    The one positive of having to R&R my S52 is fixing a bunch of little things that had been pissing me off.
    Black@Blue19 and M3Tundra-JK[OP] like this.
  15. Nov 30, 2024 at 9:12 AM
    #675
    M3Tundra-JK
    Scott
    2005 GX470
    Found a few more oil leaks. From the front vanos side of the valve cover gasket, the rtv failed. And the crankcase vent that I had replaced last time, it's gasket also failed. And these are just the top passenger side oil leaks! I have bottom drivers side oil leaks too...
    Fobroader likes this.
  16. Nov 30, 2024 at 9:15 AM
    #676
    e30cabrio
  17. Nov 30, 2024 at 9:31 AM
    #677
    M3Tundra-JK
    Scott
    2005 GX470
    Ordered 2 crush washers, #8, and one o ring, #11.
    + $17
    But SOB the hood clicked closed on one side and I can't get it open lol. I guess because of the ramps I drove up
  18. Nov 30, 2024 at 9:34 AM
    #678
    e30cabrio
    Boo parte deux
    M3Tundra-JK[OP] likes this.
  19. Nov 30, 2024 at 9:37 AM
    #679
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    It’s a BMW, if there’s no oil under it, there’s no oil in it,
  20. Nov 30, 2024 at 10:25 AM
    #680
    e30cabrio
    Mine is leaking no liquid, but oil is belching out of the tailpipe like the Union Carbide plant in Bhopal.
    Thank you broken ringland :(
  21. Nov 30, 2024 at 10:43 AM
    #681
    M3Tundra-JK
    Scott
    2005 GX470
    Aaand while I'm here, ordered the crankcase position sensor o-ring. Knew that was leaky last time and didn't replace it. Almost forgot about doing it this time.
    + $22!! for an o-ring!
  22. Nov 30, 2024 at 10:45 AM
    #682
    M3Tundra-JK
    Scott
    2005 GX470
    PIA to get this one bolt out. It's essentially upside down and at an angle
  23. Nov 30, 2024 at 10:52 AM
    #683
    e30cabrio
    Gotta love BMWs build practices. Everything is in odd locations.
  24. Nov 30, 2024 at 10:53 AM
    #684
    M3Tundra-JK
    Scott
    2005 GX470
    Aaaand it's a freaking Allen or hex or whatever bolt!
  25. Nov 30, 2024 at 11:03 AM
    #685
    e30cabrio
  26. Nov 30, 2024 at 11:03 AM
    #686
    M3Tundra-JK
    Scott
    2005 GX470
    Ok, i told them the wrong thing. it's actually the CAM positin sensor that I need the o-ring for
    only + $7
  27. Nov 30, 2024 at 11:20 AM
    #687
    M3Tundra-JK
    Scott
    2005 GX470
    Pro move if i don't say so myself. Put the magnetic sleeve down and it just barely caught the bolt
    armyoffoo and e30cabrio like this.
  28. Nov 30, 2024 at 2:06 PM
    #688
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    You should think about shaving those arms.
  29. Nov 30, 2024 at 2:43 PM
    #689
    M3Tundra-JK
    Scott
    2005 GX470
    That's already the trimmed down version lol
    Black@Blue19 likes this.
  30. Nov 30, 2024 at 2:44 PM
    #690
    M3Tundra-JK
    Scott
    2005 GX470
    E46 M3 - New (left) vs old cam position sensor o-ring
