2012 Tundra Platinum issues
Discussion in '2nd Gen Tundras (2007-2013)' started by Troy S, Nov 28, 2024.
  1. Nov 28, 2024 at 11:53 AM
    Troy S
    Troy S [OP] New Member
    2012 Tundra Platinum crew cab
    Lifted but before me. Maybe 2" in front and maybe 1 or 2 in the back? Aftermarket wheels and tires. Aftermarket sound system and security with remote start.
    I found a great running 2012 tundra crew cab. 99K on it. Previous owner did some mods and not sure if they did something wrong or if this is just a problem that happens and can be fixed easily. The check engine light is on and keeps throwing the P0101 code. The mass air flow sensor has been replaced but still the code comes up. I noticed that even when I reset the Miles per gallon display on dash. Then drive it for 15-20 miles, it only shows that I'm getting 8-8.4 miles per gallon. I was told that the mass air flow sensor and other items that could be causing the code to come up, could also be causing bad mileage. Any suggestions?
  2. Nov 28, 2024 at 4:06 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Is there any mods to the air intake plumbing?
