New to me 2021-Help-what lift is on my truck?
Discussion in 'Suspension' started by wadejg, Nov 28, 2024.
  1. Nov 28, 2024 at 12:35 PM
    wadejg
    wadejg [OP] New Member
    I bought a 2021 platinum that came with aftermarket wheels (icon 20x9), 2 inch wheel spacers, nitto ridge grapplers (295/60-20), and blistein 5100s. I’m trying to figure out the suspension details.
    I think the front are stock springs with 5100’s at top setting? Is that right based on pictures?
    I think the rear is lifted with shackles. The bolts don’t look OEM to me. But I’ve never seen stock parts. Is that correct? If so can you tell what brand? I don’t see markings.
    My goal is to return to OEM tundra pro forged 18 inch wheels without spacers. If I do that what size tires can I run?
    Thanks for helping an owner new to the tundra world.
    regards,
    Justin
  2. Nov 29, 2024 at 10:18 PM
    wadejg
    Someone must know more than me. Cuz I don’t know much. If you need more pictures I’ll take them.
    thanks,
    Justin Wade
  3. Dec 3, 2024 at 9:37 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    You should be able to find a part number on those front shocks. The rear is definitely a bracket.
  4. Dec 3, 2024 at 9:46 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Go get the BBS pro wheels and put 285/75r18 tires on. Take the wheel spacers off and put new wheels and tires on. Shouldn't have any issues but if you do put the current setup back on until you figure it out. Worst case scenario is you will have to keep the wheel spacers, 1-1.25", and have to remove some mud flaps and bend some wheel liners. But I'm willing to bet you'd have no issues, even without the wheel spacers.
    Good luck. Any shops nearby that can possibly help measure and explain to you what you can and can't do?
  5. Dec 3, 2024 at 9:53 AM
    Looks to be nothing other than Bilsteins on the front and rear and the shackles don't appear to be stock.
  6. Dec 3, 2024 at 10:04 AM
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Definitely Bilstein 5100 shocks front and rear. Hard to tell what clip setting the front is set too, but could be the top and are using the stock coil springs.
    Rear end is 5100 shocks as well. No lift blocks and it does appear the rear lift is from aftermarket lift shackles and stock leaf springs.
    Tundra234 likes this.
  7. Jan 15, 2025 at 9:09 AM
    2019Tundra_KY
    2019Tundra_KY New Member
    2019 VooDoo Tundra TRD Pro
    I got Wildpeak A/T LT285/65R18. Shown in the bottom pic vs Mich tires. Great ride with minimal sound. Large enough for my taste. See a 2 mph variance on the speedometer to actual. You can go larger but I was told you would have to remove the front small mud flap.
