2020 Headlights on a 2016 ??
Discussion in '2.5 Gen Tundras (2014-2021)' started by brandostundra, May 21, 2020.
  1. May 21, 2020 at 9:11 AM
    brandostundra
    brandostundra [OP] New Member
    i have an opportunity to purchase OEM headlights off a 2020 Tundra.
    can I install these on my 2016 without any issue?
    If it matters my 2016 is a limited with daytime running orange lights
    I heard there might be an issue with wire harness ???
    do I need some other wire harness adapter ??
  2. May 21, 2020 at 9:14 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    If I remember right, it can be done. You just need to get the "iHacker harness" to convert the wiring. Someone that's done it will chime in I'm sure.
    iHacker and TOYOTRD8 like this.
  3. May 21, 2020 at 9:20 AM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    I’m assuming 2020 is LED correct? If so you need a harness from @iHacker as he mentioned above. There are couple options to choose from. I got non dimming which is easiest option plug and play.
  4. May 21, 2020 at 9:28 AM
    brandostundra
    yes the headlights are LED from a 2020.
    If I dont get this wire harness , would everything work except for the daytime running lights ?
    Is this ihacker harness mainly to convert my orange daytime running lights to the white daytime running lights that are around the headlight ?
    If I decide to get this ihacker harness, where would I purchase? is there a website? ebay ? or?
  5. May 21, 2020 at 9:35 AM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    I believed the wiring is different and it will not work without his harness. You can PM him for more questions as he’s on this forum and I tagged him for you on earlier post and hopefully he gets back to you. @iHacker
  6. May 21, 2020 at 9:57 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
  7. May 21, 2020 at 10:09 AM
    brandostundra
    would the HD Revolution H126 harness work for what I want it to do?
    it is 2014-2018 LED headlight conversion harness
  8. May 21, 2020 at 10:26 AM
    brandostundra
    it looks like HD revolution makes the harness for 2014-2018 led headlight conversion part number H126
    Im assuming this will work as well ?
  9. May 21, 2020 at 11:10 AM
    Mgmtundra
    Mgmtundra MGM Crew
  10. May 21, 2020 at 11:19 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    WFD473 likes this.
  11. May 21, 2020 at 4:00 PM
    Waynef3413
    Waynef3413 New Member
    2016 Tundra SR
    I just recently put the same lights on my 2016 using the iHacker harness.
    I got the nondimming model and kept the amber daytime running lights along with the LED DRL's.
    The harness literally took minutes to install and was very simple even for a knuckledragger such as myself.
    The harness is very well made and looks better than the factory stuff. I can't reccomend it enough.
    WFD473 likes this.
  12. May 21, 2020 at 4:05 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Agree. Go with the Ihacker harness. It is what I put in mine.
  13. May 21, 2020 at 4:20 PM
    Elduder
    Elduder New Member
    Might want to consider going with a HID retrofit, light projection distance will be much better with HIDs. I know everyone loves LEDs but they have some disadvantages.
  14. May 21, 2020 at 6:30 PM
    gdiep
    Syracuse, New York
    I had an HID retrofit. It had to be taken apart and repaired 3 times in 18 months. Each time, I had to remove the lights, put my halogens back in and send them back to the builder. Build quality sucked. It may have just been mine, but it is what you risk when buying a retrofit. They were brighter than the LEDs, but the aim was terrible and they were a headache.
  15. May 21, 2020 at 7:12 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    That one will work as well, it's the one I have. The DRL on the new lights do stay full brightness though while the iHacker harness has an option to dim like its from factory. Both harnesses are the same install except for the optional dimming through the firewall.
  16. May 21, 2020 at 8:46 PM
    Elduder
    Elduder New Member
    That sucks, I knew that was a concern for sure. I've been lucky, never had any leaks or failures, but its a bitch to do yourself.
  17. May 21, 2020 at 11:17 PM
    Hunterdan
    Hunterdan New Member
    2017 Inferno DC SR5
    OEM TRD led lights, TRD exhaust, s&b intake
    Yes that harness will work, it's what I'm running in my 2017. As a note, when you are done, the Amber DRL will still function, so you'll need to disable it. It's pretty easy and takes 10-15 minutes to do.
    https://youtu.be/m0WBZMPKoss
  18. May 22, 2020 at 7:35 AM
    bft305
    bft305 New Member
    2016 tundra limited
    How expensive are the LED headlights? I got these: https://www.protuninglab.com/axhl-tun14-tled-lb-a.html
    Yes, the online reviews for company protuninglab are not great, but at the price I figured I would give them a shot. Have not had any issues so far. The housings are alpharex. I started a threat about them, if you want to check it out. I have a ‘16 limited as well. They come with one harness to wire in which is not hard. Just need a low profile mini wire tap with 10 amp fuse. Some people feel better with OEM quality and that is cool but thought I would bring up an second option for you.
    https://www.tundras.com/threads/new-led-headlights-tundra-pro-style.61059/
  19. Nov 24, 2024 at 4:43 AM
    clazz
    clazz New Member
    Hi, new to forum. Bought OEM 2021 lights for my 2016. Installed yesterday. Signals worked when tested. But when the headlights are on they go hyper in the back and not blinking in the front. I used the headlight revolution harness. Anyone else have this issue? Is there a cure?
  20. Nov 24, 2024 at 5:52 AM
    Not sure how many times we can say iHacker harness.
  21. Nov 24, 2024 at 6:06 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    How about one more? Lol I used ihacker as well. No way I would use some overpriced Chinese made harness from anywhere else.
  22. Nov 24, 2024 at 6:47 AM
    clazz
    clazz New Member
    I see that now. My issues is why I joined the forum. I’ve purchased the headlight revolution harness. Looks as though I need to change the original blinker harness polarity. Anyone have experience with this?
  23. Nov 24, 2024 at 7:16 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I ordered brand new headlights from sparks
    https://autoparts.sparkstoyota.com/products/product/headlamp-assy-rh-811100c211
    and replaced the stock lights in my 2015 tundra. Using @iHacker harness everything works fine
  24. Nov 24, 2024 at 8:03 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I see the problem.
    Call HR and see if you can return it or they can help you with the product they sell.
    Then never buy from them again...:thumbsup:
    Welcome to the forum..:cool:
  25. Nov 24, 2024 at 2:25 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Return the harness or take the loss and do yourself a favor and buy @iHacker harness. I used his harness and it was plug and play and works great. Also top notch quality
  26. Nov 28, 2024 at 1:08 AM
    Leedaar
    Leedaar New Member
    2016 Tundra CM
    iHacker
  27. Nov 28, 2024 at 11:26 AM
    DirkS
    DirkS New Member
    Dirk
    Abbotsford, BC
    2016 Tundra Limited
    Gee, has anyone mentioned the iHacker harness? :) Another vote for it - worked perfectly to put factory LED headlights on my 2016.
    1lowlife likes this.
