Instrument Panel Reinforcement
Discussion in '2.5 Gen Tundras (2014-2021)' started by kingtwin, Nov 27, 2024.
  1. Nov 27, 2024 at 5:20 PM
    kingtwin
    kingtwin [OP] New Member
    2016 Tundra Crewmax Limited
    Bought my first 2016 Tundra Limited used from a Honda dealership last week. They had to take the dash apart and replace the heater box to fix the heat since that wasn’t working and I just noticed today the instrument panel reinforcement bolt on passenger side door jamb is stacked with washers. I’m not sure if they just used something lying around the shop or what. My question is can I just remove this and replace it with the factory bolt?
    Thanks!
  2. Nov 28, 2024 at 2:56 PM
    bfunke
    bfunke Tundra Curmudgeon
    I would try the factory bolt. Hopefully they didn’t enlarge the hole to fit the washers. BTW this is really shoddy workmanship. Wonder if they did this anywhere else under the dash.
  3. Nov 28, 2024 at 5:38 PM
    kingtwin
    I agree, this is petty bad. The bottom bolt has a washer that spins freely and it looks like the drivers side doesn’t even have a bolt now.
  4. Nov 28, 2024 at 5:42 PM
    bfunke
    Driver
  5. Nov 28, 2024 at 5:43 PM
    bfunke
    Passenger
  6. Nov 28, 2024 at 5:46 PM
    kingtwin
    OK that helps a lot. So drivers side looks ok based on your pics. I guess I’ll order the bolt for the passenger side and hope they didn’t make it worse. I really appreciate the responses and the pics.
