HVAC Trouble Code 41
Discussion in '2nd Gen Tundras (2007-2013)' started by MyCamTowersLeak, Oct 29, 2020.
  1. Oct 29, 2020 at 6:11 AM
    MyCamTowersLeak
    MyCamTowersLeak [OP] New Member
    Will
    2011 Platinum CM
    Started my 2011 Platinum, with auto climate controls last week and the blank control panel issue occurred. By the time I had driven across the parking lot the system kicked on and defaulted to 75 degrees. I performed the diagnostic self test and it came back with CODE 41. I'm assuming based off B1441/41 Air Mix Damper Control Servo Motor Circuit (Passenger Side) - Air mix control servo motor fault code that this is on the passenger side of the vehicle but cannot find any info relating to part numbers or installation. I can find all kinds of info for the what appears to be the issue on the driver servo motors.
  2. Jun 4, 2024 at 4:46 PM
    swoc3647
    swoc3647 New Member
    ever find anything on this? having the same issue and code on my 07 DC. passenger side doesn't get any cold air/heat.
  3. Jun 7, 2024 at 5:06 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    I’m betting it’s the dual servo blend door actuator on the drivers side. Not a fun or cheap job unless you do it yourself. The part is less than $200, but the labor can be extensive. Several videos on YouTube. I’ve already done mine. Good Luck
  4. Nov 27, 2024 at 11:03 AM
    Revned911
    Revned911 Denver
    Denver
    Missouri
    08 Tundra TRD, 72 FJ40
    At present, none. Planned: leveling kit, 33s, android head unit, 360 degree view cera's, front and rear dashcam, android head unit, front/rear bumpers, multifunction steering wheel, secret savings account.
    Can this be replaced WITHOUT taking the whole blend door assembly apart? Can I just pop out the actuator and put a new actuator in?
