OEM replacement engine air filter
Discussion in '3rd Gen Tundras (2022+)' started by Silver23, Nov 26, 2024.
  1. Nov 26, 2024 at 9:48 AM
    Silver23
    Silver23 [OP] New Member
    2023 Silver 1794 TRD
    Was on the Toyota parts online store and they list two different model numbers for the engine air filter. #17801-F4010 and #17801-YZZ17, both of which say it fits my 2023 Tundra hybrid. There's about a $10 price difference between the two. Although it doesn't state it, could one be the TRD filter?
    Yaboy likes this.
  2. Nov 26, 2024 at 9:59 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    17801-F4010 is the OE replacement and will be identical to what was factory installed.
    17801-YZZ17 is the MVP (value line) replacement.
    Both are Toyota parts made by Denso, but the value line sometimes have less media. Usually, the pleats are not as deep.
  3. Nov 26, 2024 at 10:23 AM
    Silver23
    Thanks!!!
  4. Nov 26, 2024 at 11:10 AM
    dJunior
    dJunior New Member
    CT
    Is it the same thing with the oil filters too? 90915-10010. Vs 90915 yzzf1 ?
  5. Nov 26, 2024 at 11:37 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Not sure there. Toyota usually offers only one oil filter at the dealer level.
    The latest literature still shows 10010 as the correct filter. It would not surprise me if it has similar specs as an existing filter (YZZF1), and Toyota has authorized YZZF1 as a substitute. Seems there was supply issues for a while with the 10010 filter.
  6. Nov 26, 2024 at 11:58 AM
    Tom976
    Tom976 New Member
    Tom
    One oil filter came with the truck and the others are the ones available through the dealer.
    I purchased the originals ones that came with the truck. Working fine.
  7. Dec 21, 2024 at 4:02 PM
    PWRGENgasturbine
    PWRGENgasturbine New Member
    Thomas
    2025 Tundra limited wind chill pearl
    I just bought a 2025 Tundra Limited and it came with the TRD air filters. I’ve had lots of experience with K&N air filters for many years. We live in the dusty west and I’ve had K&N’s on my motorcycle in the east coast with no issues. Moved west 11 years ago and the K&N’s leak fine dirt through so I’ve switched to stock style filters that don’t leak dirt.
    I would like to use a WIX filter on the Tundra and ask if anyone else is suspect of the dirt leak through as I am?
    Thank you in advance for all your help.
  8. Dec 21, 2024 at 6:56 PM
    737fixer
    737fixer New Member
    I can't find pics for the two P/N's you gave but I can show you the BS Toyota did with the value line for the 5.7L. I'm sure you can guess which is the original and which is the value garbage they try to push you towards. Also be care of the dealer putting in the value one and charging for the original.f6f7056956308009aea406167f64bb27.jpg s-l1600.jpg
    Ausfahrt and MAC25Tundra like this.
  9. Dec 23, 2024 at 4:04 PM
    bailey bulldog
    bailey bulldog New Member
    That's crazy!
