Amp or RC power running boards?
Discussion in 'General Tundra Discussion' started by tjacob95, Nov 25, 2024.
  1. Nov 25, 2024 at 6:43 PM
    tjacob95
    tjacob95 [OP] New Member
    2014 toyota tundra limited
    can anybody give your feedback on the difference between these two companies power boards, I have heard good things about the amp power steps, but nobody is running any sales on the at the moment and they are rather pricey, the rough country is a couple of hundred bucks cheaper but haven't heard of anyone running them... is it worth it to save a couple hundred bucks or should I go with the amp steps.... I really want mine to be hidden when not in use, any insight would be helpful thanks in advance! here are the links to the ones I'm talking about
    Amazon.com: Rough Country Power Running Boards with LED Step Lights for Toyota Tundra, CrewMax (2007-2021) - Dual Motor i-Force Electric Powerstep Board & Retractable Truck Steps : Rough Country: Automotive
    Amp Research Tundra PowerStep Running Boards 75137-01A (07-21 Tundra Double Cab, CrewMax)
  2. Nov 25, 2024 at 7:29 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    The AMP boards have been good by me for the last 6 years. I can’t speak for the others.
  3. Nov 25, 2024 at 7:30 PM
    tjacob95
    did you get just the regular ones you have to splice into the wiring or the plug and play? and have you had any issues?
  4. Nov 25, 2024 at 7:33 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    I have the splice in ones. I’ve had the bolts vibrate loose on the motor a couple times, but generally in all weather, under all conditions they have been solid.
  5. Nov 25, 2024 at 7:34 PM
    tjacob95
    would you recommend them over the rc???
  6. Nov 25, 2024 at 7:35 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Again, I have never used the RC so I cannot comment on them. I can only say that I have had a good experience with the AMPs.
  7. Nov 25, 2024 at 7:35 PM
    tjacob95
    10- 4 thanks for the input
  8. Nov 26, 2024 at 4:52 PM
    Prestoman13
    Prestoman13 New Member
    Preston
    2008 crewmax SR5
